thought it was a dead battery. Car still dies after jump starting.
Old 06-25-2002, 08:30 PM
hokiemax's Avatar
Could a really worn out battery do that? This symptoms occuring on my mom's newly gotten used maxima, and if its not the battery, I need to return the car. I need quick answers!!
hokiemax is offline
Old 06-25-2002, 08:59 PM
2k2maxima's Avatar
Re: thought it was a dead battery. Car still dies after jump starting.
Could it be the alternator???
Not sure, just thought I would try to help....
Later...
2k2maxima is offline
Old 06-25-2002, 09:12 PM
finny's Avatar
does the car die right when ya jump it, or after you take the cables off. if it dies after takin the cables off its most likely the alternator otherwise im clueless
finny is offline
Old 06-25-2002, 09:21 PM
hokiemax's Avatar
The car died like 30 secs after I took the cables off.
hokiemax is offline
Old 06-25-2002, 09:25 PM
lcf
lcf's Avatar
you say the car still dies after jumping.
does it die immediately?
i am assuming you mean that it wont start the next time you try to turn it on?
my sisters g20 had a problem like this.
she called me from applebees and said her car wouldnt start and told me to come with cables.
i did.
it jumped okay.
everything was cool.
we ran the car for 15 minutes to let the battery recharge.
then we drove to walmart (had nothing else to do and we wanted to run the car longer).
we went into walmart and when we came back out her car still wouldnt start.
for some reason it couldnt keep the juice.
jumped it again.
drove it home.
slept.
woke up in the morning.
it still wouldnt start.
jumped it again and took it to the dealership.
got a new battery and it works fine.
lcf is offline
Old 06-25-2002, 09:28 PM
Maxima_Van_WA's Avatar
I'm glad you got it fixed
Maxima_Van_WA is offline
Old 06-25-2002, 09:32 PM
hokiemax's Avatar
My car dies after I take the cables off to drive it home. I was on the road, idling in D, when it died. I think its the alternator..
hokiemax is offline
Old 06-25-2002, 09:33 PM
chinaonnitrous1's Avatar
hmmm best case scenario..youve let the battery drain way too many times..killing the electryolites inside of it..so it wont hold a complete charge....and its getting worse...So id reccomend getting your battery tested at a auto parts store..call around to your local ones..they usually do it for free....if that dosent work..id think your alternator is to blame...and thats $$
chinaonnitrous1 is offline
Old 06-25-2002, 09:42 PM
Moderator running more PSI than all the boosted Maximas... combined
1MAX2NV's Avatar
Once the battery starts the car, all the eletrical power comes from the alternator. The only time the battery comes into play is when you overtax the alternator's power or when the alternator is bad. In your case, it's the latter. The car runs until all the energy is exhausted from the battery, then it dies. Does your battery light come on even when the car is running? If so, it's for sure is the alternator.
1MAX2NV is offline
Old 06-26-2002, 05:45 AM
Lime's Avatar
exactly.
Lime is offline
Old 06-26-2002, 08:16 AM
maxima4me's Avatar
Originally posted by lcf
I had the same problem:
Car wouldn't start.
Jumped the car, car ran fine.
Shut the car off, then it wouldn't start again.
Tested/Replaced battery, worked.
My suggestion: If you jump it and it runs fine until you shut it off, go get the battery tested. It's probably bad, and you need to replace it. If it doesn't stay running after you jump it, then it's probably your alternator
maxima4me is offline
Old 06-26-2002, 10:27 AM
Myrv's Avatar
It definitely sounds like your alternator then.
Myrv is offline
Old 06-26-2002, 10:35 AM
DaddyMac's Avatar
I have an alternator for sale.
if anyone needs one, see my homepage.
it is excellent, only reason I'm selling is because I am parting out my car.
DaddyMac is offline
Old 04-18-2024, 01:27 AM
kayle121's Avatar
Same thing happened to me after searching i find this guide which help me fix it. Read Here
kayle121 is offline
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
King_Ten_Ahead
09-30-2015 04:27 PM
MaximaDrvr
08-19-2015 08:20 PM
doobadoo
08-15-2015 06:43 PM
Quick Reply: thought it was a dead battery. Car still dies after jump starting.
