How much does 1 gal. of Gas weight?
Old 06-14-2002, 01:47 PM
MAX2000JP's Avatar
I was wondering how much one gallon of gasoline weighs? If I remember correctly it was something like 7 lbs. Just wondering so I can figure out how much weight is in my gas tank at certain times.
MAX2000JP is offline
Old 06-14-2002, 02:02 PM
webboy's Avatar
Re: How much does 1 gal. of Gas weight?
Being a huge NASCAR fan I believe their gas cans gold 11 gallons of gas at a weight of 75 pounds so that what 6.8 lbs?? almost 7 so your right.
webboy is offline
Old 06-14-2002, 09:51 PM
emax02's Avatar
I thought it weighed 8 lb's a gallon
emax02 is offline
Old 06-14-2002, 09:54 PM
SLOW
Nealoc187's Avatar
Different fuels weigh different amounts, but gasoline is about 6.6lbs per gallon. Water is 8lbs/gal.
Nealoc187 is offline
Old 06-15-2002, 01:21 AM
BriGuyMax's Avatar
for avaition weight and balance we use 6 pounds per gallon...granted this is 100 octane low lead not lead-free 93 octane.
BriGuyMax is offline
Old 06-15-2002, 02:41 PM
azhelipilot's Avatar
Right on the 6lbs per gal. Also 231cu in per gal. Just in case you wanted to know that also.
azhelipilot is offline
Old 06-15-2002, 04:34 PM
Licensed to Spell
ptatohed's Avatar
:o)
1 gallon of gasoline equals 5.8 to 6.5 lbs.
http://www.santacruzpl.org/readyref/...gasoline.shtml
ptatohed is offline
Old 06-17-2002, 05:56 AM
2DMax's Avatar
Re: Re: How much does 1 gal. of Gas weight?
Uh, NASCAR does not use gasoline.....
2DMax is offline
Old 06-17-2002, 06:29 AM
Albertt's Avatar
Uh, yeah they do. >>
Straight from the FAQ of Team Conseco website (http://www.conseco.com/csp/team_cons...r_team_car.htm):
"Q: What kind of gasoline do the cars use?
A: NASCAR Winston Cup and NASCAR Busch Series both use only one kind of fuel, 76 Gasoline. Each car holds 22 gallons of 110 octane racing fuel."
I think you're thinking of drag racing...
Albertt is offline
Old 06-17-2002, 08:16 AM
Licensed to Spell
ptatohed's Avatar
Re: Uh, yeah they do. >>
I think what 2D means is anyone who is into NASCAR calls it FUEL, not GAS.
ptatohed is offline
hcarter1112
42
07-18-2022 03:35 PM
maxinout93
10-31-2015 02:04 AM
ef9
10-04-2015 08:43 AM
Quick Reply: How much does 1 gal. of Gas weight?
