2002 Maxima SE 0-60 times?
Old 06-07-2002, 09:31 AM
fpblue's Avatar
I just bought a new 2002 Maxima SE. Unfortunatley for me my wife can't drive stick shift, so I got the automatic. I can't believe how fast and smooth this car is. My other car is a 330 horsepower Pontiac Firehawk, so I know when a car has power. I was wondering if anyone knows what the 0-60 times are for the Maxima SE with the auto tranny. I know the commercial used to show 0-60 in 6.4 seconds. Thanks in advance.
Frank
fpblue is offline
Old 06-07-2002, 11:20 AM
Bulldawg's Avatar
Re: 2002 Maxima SE 0-60 times?
Frank
I got a 6.46 0-60 using a gtech pro. But I have a six speed and I can't drive worth a sh**
Bulldawg is offline
Old 06-07-2002, 11:31 AM
jkratzer's Avatar
The 2K2 auto does 0-60 in 6.8-7.0 seconds. That is assuming you drive your auto without manually shifting it like some org members do.
jkratzer is offline
Old 06-07-2002, 11:37 AM
Sanduguero
Playero's Avatar
is it safe to manually shift a auto 2k2???
Playero is offline
Old 06-07-2002, 11:41 AM
Matthew's Avatar
...Yes, but don't rag out your engine hitting the rev limiter, you have to drive it like a clutchless stick, and time your shifts so you don't go out of the power band. But there is no question that shifting the gated shifter manually from a stop position will yield better acceleration times... If Motor Trend can get the same curb weight, 15 hp less auto Altima to 60 in 6.6, I am certain that the 02 Max auto can duplicate that, if not improve upon it...
Matthew is offline
Old 06-07-2002, 12:39 PM
fpblue's Avatar
How do you manually shift an automatic?
I've never done this before. How is it done? Thanks.
fpblue is offline
Old 06-07-2002, 02:27 PM
Sanduguero
Playero's Avatar
Re: How do you manually shift an automatic?
how do i know whats the max on the 1,2,3 gears when is close to RED!
Playero is offline
Old 06-07-2002, 02:36 PM
MONTE 01&97 SE's Avatar
You can run lower than a 6.8 I run a 6.61 and some other guys here run similiar times to me in my 02 Auto.
MONTE 01&97 SE is offline
Old 06-07-2002, 02:50 PM
Matthew's Avatar
...You should really only do this if you have an 02, with the gated shifter, because it has all the gears laid out 1-2-3-D so you can row through them with the 'slushbox' instead of the clutch, but at least it gives you a little more control as to when the car shifts. I think 6.6 0-60 is definitely attainable with a little practice.
Matthew is offline
Old 06-07-2002, 03:43 PM
lcj2002se's Avatar
Re: Re: How do you manually shift an automatic?
On manually shifting the 2002 auto, what do you guys think of this:
Because it is very difficult to get from 1st to second, start in 2nd gear, and shift to 3rd and OD. Will this hurt the tranny? It just seems when you manually shift, it really does ni get to the next gear until the trans itself is ready to.
lcj2002se is offline
Old 06-07-2002, 03:47 PM
I miss the .org!
Triple8Sol's Avatar
Re: Re: 2002 Maxima SE 0-60 times?
Which G-Tech do you have? There's a newer one that came out, with double the features for double the price. I wonder how accurate those things are...
Triple8Sol is offline
Old 06-07-2002, 04:07 PM
dino1063's Avatar
Re: Re: Re: 2002 Maxima SE 0-60 times?
I was curious on times for all the 2k2 with 6-speeds?!
dino1063 is offline
Old 06-07-2002, 04:09 PM
F23A4's Avatar
Frank
I just bought my 2K2 Max back in March and got an auto tranny because of the wife also.
As for the 0-60 time, that commercial sounds right on. At the track, I consistently run about 15 flat which roughly equates to about a mid-6 0-60 time.
F23A4 is offline
Old 06-07-2002, 05:03 PM
ford5litre's Avatar
I did 1 run with my G-Tech and got a 14.97 quarter mile... I really don't remember my 0 to 60 time. I think it was in the mid 6's. I think with more runs and cooler weather (I live in deep South Texas..HOT!), I could improve those numbers a little.
ford5litre is offline
Old 06-07-2002, 05:08 PM
ford5litre's Avatar
I just did a search on my old thread... my correct quarter mile time was 14.99 and my 0 to 60 was 6.4 in my '02 Auto.
Old 10-21-2002, 09:52 AM
soopermax02's Avatar
Re: Re: Re: How do you manually shift an automatic?
I agree the shift from 1st to 2nd is physically the most difficult, as you have to kind of work it around. Unfortunately I think manually shifting from 1->2 will net you the biggest gain.
I've found that for whatever reason (even under full throttle) the tranny shortchanges 1st and shifts into 2nd very early. If left alone (like in "D" or "3") the tranny will shift 2 -> 3 much better (closer to redline) than it will 1 -> 2.
Just be sure to give it a few 100 RPMs or you will hit the rev limiter.
soopermax02 is offline
Old 10-21-2002, 12:42 PM
WILLSE's Avatar
Re: Re: Re: Re: 2002 Maxima SE 0-60 times?
i havent ran my car for awhile but last time i did i set the g-tech up on a perfectly straight road and had everything set up perfect. i did 3 runs 0-60 i consistanly ran between 5.7-5.9 (my clutch probably didnt like it too much). reference note- i ran a 14.3 @ 97 at the track. i wish i had HLSD life would be much more enjoyable.
will
WILLSE is offline
fastcarny
05-18-2020 10:40 AM
fastcarny
08-12-2015 03:50 PM
papo99
08-09-2015 07:24 AM
yat70458
08-03-2015 01:16 PM
Quick Reply: 2002 Maxima SE 0-60 times?
