Car won't stay running
Old 08-18-2013, 05:53 PM
JEFF6898's Avatar
1998 Maxima GXE 6 cylinder
When I start the car it runs for a few seconds then spits and sputters and dies. If I give it gas it acts like it only is running and 3 cylinders and quickly dies. I pulled the codes and it shows 75, 71, 41.
One I know is a Evap code. I think the 41 is the egr valve? Would this by symptoms of a bad egr? Would a blown head gasket cause this as my son did run the car hot.
JEFF6898 is offline
Old 08-19-2013, 07:51 AM
cashoit's Avatar
Sounds like a bad MAF sensor.
If Blown head gasket, the car would still run. Just would overheat EGR and Evap would not cause the car to stop running.
cashoit is offline
Old 08-19-2013, 09:27 AM
JEFF6898's Avatar
Well decided to put gas in the car even though son insisted it had gas in it, fuel gauge does not work. CRanked right up and stayed running except it runs very rough and shakes at idle. Give it gas and it hesitates real bad.
I one by one disconnected the coils one at a time of course and 5 of them change when unplugged, one of them no change at all. Could one bad coil cause it to run so rough? I am going to change it and put all new plugs in to see what happens. I suspect I still have other problems
JEFF6898 is offline
Old 08-19-2013, 09:36 AM
Yes, 1 bad coil is a misfire that shakes.
Old 08-19-2013, 10:35 AM
JEFF6898's Avatar
Well changed the coil out with a brand new one. Still no change in running. Still no change when I disconnect the new coil. Other five noticeable change when I disconnect them
JEFF6898 is offline
Old 08-19-2013, 10:41 AM
then it could be the fuel injector.
Old 08-19-2013, 12:06 PM
JEFF6898's Avatar
I tried the old put a screw driver on top of the injector and it clicks so I am guessing it is working. All the injectors have the sound clicking noise when I do that. It looks like to change the rear injector the manifold has to be removed.
I am going to do a compression check next on that cylinder. I have great spark out of the new coil and new plug. At a loss
JEFF6898 is offline
Old 08-19-2013, 01:00 PM
Please keep us posted on the compression check.
Old 08-19-2013, 04:20 PM
JEFF6898's Avatar
Compression on cylinder I am having problem with is 180 and holds steady trying to find what it should be
JEFF6898 is offline
Old 08-19-2013, 04:59 PM
jokster's Avatar
Don't forget to check the spark plugs too. that will also cause the car to shake violently if they are bad.
jokster is offline
Old 08-19-2013, 05:48 PM
JEFF6898's Avatar
I went and replaced all 6 today
JEFF6898 is offline
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
MaximaDrvr
08-19-2015 08:20 PM
acw
08-13-2015 12:50 AM
Bruceharrison
08-09-2015 07:56 AM
Quick Reply: Car won't stay running
