Tranny problems
Old 11-01-2012, 12:43 PM
Bo'
Bo''s Avatar
Tranny problems
hello everyone....im farely new here, own a 2004 nissan maxima.
maybe im looking in the wrong place, but i havent found a related problem i have have with my transmission, here is as follows:
1) from park to drive it takes a good 2 seconds for it to kick in gear but with a hard shift though....almost like a donkey kick from behind,
2) from 2nd to 3rd gear......it lags. and some very weird shifting....almost like the car hesitates to kick in gear.
now....is that some cam/ crank sensor....which ive replaced only the cam (front of car)....and maybe have to replace the crank?
ive done a diognostic....and doesnt throw any codes...but when i bought the cam the first time...it was doing the same thing...only that it was stuck in 5th....
my check engine light is not on...but shifts hard from park to drive really ugly....
been reading to also do a tranny oil change drain/ refill but not to change the filter ....
car has 120k miles....
any in put would help......thank you
Bo' is offline
Old 11-01-2012, 02:12 PM
theblackone3.5's Avatar
Just change the tranny fluid. Do it every 3,000 miles or so for like 2 or 3 times and it should shift better. If it doesn't get any better just slap a transgo shift kit on it, that will fix the problem for sure. changing ur fluid should help though.
theblackone3.5 is offline
Old 11-01-2012, 02:30 PM
Bo'
Bo''s Avatar
Should i replace the the filter as well?
Bo' is offline
Old 11-01-2012, 02:55 PM
no need, just get tranny fluid
Old 11-01-2012, 05:51 PM
po8pimp's Avatar
there is a thread on this already that has been viewed 121,374 times with 1,069 replies in it at the top of the 6th gen forums. It explains everything you are experiencing. http://forums.maxima.org/6th-generat...ssion-fix.html
po8pimp is offline
Old 11-02-2012, 09:42 AM
04BlackMaxx's Avatar
If you need a new tranny, search http://www.findashemalelover.com/
04BlackMaxx is offline
Old 11-02-2012, 07:12 PM
po8pimp's Avatar
That's probably the best post I have ever seen.
po8pimp is offline
Old 11-04-2012, 06:56 AM
Well especially considering the donkey punch issue hes also having "....almost like a donkey kick from behind"
Old 11-05-2012, 09:59 PM
Bo'
Bo''s Avatar
called up sunbelt....place in florida, some dude fabian...really nice guy,...ran me throught a series of questions...and confirmed it was my valve body,
now...ive also been told to just change the fluid....about 10 bucks a quart...and drain/fill 3x's.....about 150 total...could be money down the drain if it doesnt solve my problem.....especially them donkey kick...from park to drive...
Bo' is offline
Old 11-05-2012, 11:21 PM
oem ftw!
CRiME's Avatar
Just change the valve body. If you want, drain and refill with fresh fluid after the VB change.
CRiME is offline
Old 11-12-2012, 06:10 PM
Bo'
Bo''s Avatar
about to purchase my valve body.....
just a quick question....is it safe to mix A/T MATIC K fluid with something else....
although some AT fluids meet matic k standards?
Bo' is offline
Old 11-12-2012, 07:10 PM
Max streets's Avatar
no k matic only , i had the same porblem u might need the clutches also if its still a delay on the shifting afther u cahnge the valve body.
Max streets is offline
Old 11-12-2012, 07:28 PM
Bo'
Bo''s Avatar
k bro....im lost here....
not one person on the transmission fix said...i need new clutches...
elaborate more on this please
Bo' is offline
Old 11-15-2012, 08:28 PM
PLAYNU2's Avatar
Tranny issue
I've got the same issue. Hard shift from park to drive or park to reverse. I've only noticed it though after I have been driving for a while. Almost like the tranny fluid has heated up some. I definitely do not have the problem when I start it off in the morning for work or at night when I leave to come home. Only after driving all day shopping trips with the wife.....lol
So I'm going to do some draining and filling for a while and see if that clears it up. I had a flush and refill at 83K and now I'm at 105k and the fluid looks like light brownish....not reddish.
PLAYNU2 is offline
Old 11-16-2012, 01:01 AM
oem ftw!
CRiME's Avatar
This is how my problem started. Fine when cold, terrible once warmed up. I would advise you to just replace the valve body now rather than spending money on swapping out the fluid. Have the trans evaluated if you can. It's possible that the other internals of your trans are still good and you can have it return to normal operation with just a VB change.
CRiME is offline
Old 11-19-2012, 09:47 AM
Bo'
Bo''s Avatar
When replacing fluid (car says to use matic k) can i replace with anything else....or equivalent?
Bo' is offline
Old 11-25-2012, 10:18 PM
Bo'
Bo''s Avatar
clutches????....my car is auto
Bo' is offline
pktaske
05-06-2016 07:49 AM
Socalstillen
09-20-2015 11:46 PM
iamute
09-20-2015 05:22 PM
pktaske
09-04-2015 08:40 AM
Lowered_a33
09-01-2015 07:49 PM
Quick Reply: Tranny problems
