Sponsored by:
Sponsored by:
How to listen to music using Bluetooth...
Old 10-19-2012, 11:02 PM
Timmy's Avatar
Hey guys Im sorry if this was asked already but does anyone know how to play music using bluetooth? I spend about an hour going through the manual but got annoyed and stopped lol. Thanks in advance
Timmy is offline
Old 10-20-2012, 12:17 AM
1BADMAXIMA2011's Avatar
You can't. Our vehicles Bluetooth does not support the function to play music. You are only able to use it for call functions only. Sucks they Diddent incorporate it.
1BADMAXIMA2011 is offline
Old 10-20-2012, 05:25 AM
job pimp's Avatar
when i bought my 2012 limited i got contacted by nissan for the survey they ask all new owners to do and i slammed them for that, and the fact that there are no usb ports and the locations of the charging ports they are in the worse places, inside the console and inside another compartment. such a stupid design, when i complained about the no charging usb port their come back was everything was capable through the blue tooth option, but i have not been able to make it work that way either. it is driving me nuts, i am almost ready to take my 3month old ride and trade it in for a car that has all those tech needs that seem to come standard in most other new cars standard.
on a different note, they were talking about on here about commercials for maxima, i just wish they would take that money and put it back into the car! cause i am surprised to see what was offered package wise with this car, they made so many different packages to compete price wise, i would of paid the money if i knew how bad the tech issues would be....i wanted performance-tech-good brand-and leader in the market and that is why i bought my first nissan----starting to wonder if i should of bought a loaded versa for 15grand cheaper, at least i would have the simple bells and whistles that should be standard at this point in the game, OH before my tangent, know the honda odeyseey commercial i swear they were ****bagging nissan in that commercial---the cubic zarconia tech package----you have to upgrade!
job pimp is offline
Old 10-20-2012, 02:39 PM
wtgkb8's Avatar
You can stream music through Bluetooth with my 2012 Maxima. This includes music on your phone and from apps like Pandora (can't control Pandora with car however). However, I believe it's only available with the Tech package, which I have. Mine also has both the USB and Aux ports inside the center console. It just depends on what option packages you have.
wtgkb8 is offline
Old 10-20-2012, 03:43 PM
Timmy's Avatar
Originally Posted by wtgkb8
You can stream music through Bluetooth with my 2012 Maxima. However, I believe it's only available with the Tech package, which I have. Mine also has both the USB and Aux ports inside the center console. It just depends on what option packages you have.
Oh ok I see... I have the A/V port in center console along with the USB. I actually just looked at the package options on the Nissan package you have to have the tech package for that. I guess that answers my question lol
Timmy is offline
Old 10-20-2012, 05:02 PM
PalmettoFellow's Avatar
My 2012 streams music just fine over blue tooth. I know that the 2009 doesn't support this feature.
At some point between 2009 and 2012 they started supporting blue tooth streaming. I don't know which model was first. A2DP is the protocol needed to stream music over blue tooth. It's as simple as updating the firmware I think...I don't think there is a hardware issue but I could be wrong.
PalmettoFellow is offline
Old 10-20-2012, 11:20 PM
Timmy's Avatar
I didnt understand any of it but thanks for the info lol
Timmy is offline
Old 10-20-2012, 11:56 PM
I stand corrected. Thanks for the correction guys.
Old 10-21-2012, 06:49 AM
PSU09MAXIMA's Avatar
If you have a 2009 Maxima and want to stream music go and by a BlackBerry Stereo Gateway and you can than basically in the center console thing connect down there and will only draw power when the car is on and your phone will pair and you can wirelessly stream
PSU09MAXIMA is offline
Old 08-10-2017, 07:31 AM
Laineejon's Avatar
You can still play music using BT adapter. I recommend the tune2air WMA1000 from viseeousa.com. It is a very simple device but works flawlessly. Stream music via bluetooth, can also play, stop, next and previous using steering wheel controls. I have mine and I am completely enjoying it.
Laineejon is offline
Old 08-22-2017, 09:48 AM
jhana546's Avatar
(For 7th gen max) check out a device called bovee 3000, its a small Bluetooth transmitting device that plugs into the factory ipod connection in your center console. Works great and almost never cuts out.
you can control (pause play skip return) with your steering wheel and on screen controls, but if you're using an android OS or other non-ipod operating systems you wont see a song or artist title preview on screen.
jhana546 is offline
Old 08-22-2017, 02:36 PM
blackmax14's Avatar
I stream via blue tooth with my Iphone on my 2014 I think you have to have tech,
blackmax14 is offline
Old 08-24-2017, 04:16 AM
Antoine Lynn's Avatar
i have a 2012 sports version but i dont think i have that thing in the center console. Is there anywhere else i can look for?
Antoine Lynn is offline
Old 11-21-2018, 06:38 AM
Nixhaus's Avatar
I have the sports package and mine has the connections in the lower compartment of the console box. You have to raise the upper part to see the connections and charge port.
Nixhaus is offline
Old 12-03-2018, 06:19 AM
medjestic's Avatar
I don't see anywhere to plug in that BoVee device?
medjestic is offline
Old 12-15-2018, 06:57 AM
alexdi's Avatar
I have the base 2010 Maxima. I ran a cable from the Aux-in to the fuse box, then hardwired USB 5V from the fuse box to a Homespot receiver that sits in front of the fuses and switches on and off with the car. Costs $35 all-in, works as well or better (supports AAC and AptX) than the factory setup.
alexdi is offline
Old 12-15-2018, 12:52 PM
medjestic's Avatar
If it's not too much trouble could you post a picture of what your fuse box looks like right now? Thanks for the response.
Old 12-15-2018, 04:29 PM
medjestic's Avatar
Nevermind, I got it all sorted out. Bought the Insignia Portable Bluetooth Audio Receiver. Plugs into the USB port for power and into the AUX ports for audio and everything fits nicely in the center console.
Old 06-05-2019, 09:34 PM
Samuel Hillis's Avatar
I have tried the Bovee VMA 1000 with no luck. I have a 2010 maxima without nav. I have power coming from USB input in console and also got connected to my phone but the stereo won't recognize the device. Any tips?
Samuel Hillis is offline
Old 06-06-2019, 03:17 PM
VeeQue35DE's Avatar
You can find the answer in this post. https://maxima.org/forums/7th-genera...ution-ask.html
VeeQue35DE is offline
Old 06-25-2019, 07:46 AM
nicksfifthmaxima's Avatar
Amazon Amazon
problem solved
nicksfifthmaxima is offline
Max_Lando
06-13-2015 07:02 PM
ccfunk
04-16-2013 03:18 PM
Ghost_capo
24
06-01-2012 06:41 AM
ttt3
02-26-2012 05:11 PM
Quick Reply: How to listen to music using Bluetooth...
