2001 Maxima Hard Starting
Old 08-11-2012, 02:17 PM
donnie j's Avatar
My 2001 3.0 L Maxima has become hard to start and has set code P1335 . I have changed crank sensor 4 times and cam twice. I have also checked resistance and are within the ohms specs. I've also mixed the sensor combinations and have no changes. Once it finally starts, it runs great. Can anyone shed light on my frustrating situation before I burn it!
donnie j is offline
Old 08-11-2012, 03:47 PM
andrewmac's Avatar
Pull the ecu connector out and test for continuity between the right pins and each of the sensors. I did it with a speaker wire and a voltmeter. Check the FSM for which pins to check. Could be a damaged wire.
andrewmac is offline
ah2002
03-09-2016 01:42 PM
02PearlSE
10-07-2015 02:12 AM
District
08-15-2015 08:23 PM
kirkhilles
08-08-2015 10:53 AM
wpr
08-05-2015 03:28 AM
Quick Reply: 2001 Maxima Hard Starting
