Air Bag Light flashing and fail codes.
Old 05-31-2012, 08:43 PM
R_M_Nissan_Max's Avatar
95 Maxima, V6 and Manual. Can anyone instruct on how to reset the air bag warning light controller? We removed all airbags to fix an electrical problem. Now the light flashes. On older Infinity it was a combination of key strokes and door switch engagements.
Does anyone have a translation for ECU fail codes? What is 77? We want a list of all...
R_M_Nissan_Max is offline
Old 05-31-2012, 09:29 PM
DennisMik's Avatar
For the ECU codes, you can use this web site:
http://boredmder.com/ecucodes/index.php
Select the year of your car and enter in the 77 as 0707. The program will tell you that the code is the rear heated oxgen sensor. It also gives you the OBD II code, which in this case is P0136.
You can also get this information from the Nissan FSM, section EC. Within the first 5 pages or so is a chart that has the OBD II codes and the ECU blinking code.
If you don't have a FSM, you can download one from here:
http://boredmder.com/FSMs/Nissan/Maxima/
DennisMik is offline
Old 06-01-2012, 05:34 PM
Trini Boom's Avatar
Also, to reser air bag light, with driver's side door open, turn key to ON position and press door switch 5 times within 7 seconds.
Trini Boom is offline
Old 06-04-2012, 12:47 PM
clint240sx's Avatar
Does having the blown air bags in the car matter to resetting the light? (stupid question im sure..)
clint240sx is offline
Old 06-04-2012, 01:12 PM
It's a good thing you mentioned that you have a V6 in your Maxima, otherwise we wouldn't have been able to assist you.
The Wizard is offline
Old 06-04-2012, 03:13 PM
Use logic, you'll see the light...
Old 06-04-2012, 03:19 PM
Old 06-04-2012, 03:25 PM
VQ'rInWLA's Avatar
LMMFAO
VQ'rInWLA is offline
Old 06-04-2012, 03:46 PM
Tyutyunnik's Avatar
This is a two second google search but I'm feeling nice today.
Open Driver Door.
Get In.
Shut Door.
Turn ignition to the ON position.
(all the way, but do not start car).
Open Door.
Reach down with your left hand and
Press the door ajar sensor button (7) times.
(on Infinity I30 button covered in rubber)
Shut Door.
Start your car...
This should reset the airbag lamp and it will stop blinking.
Tyutyunnik is offline
Old 06-04-2012, 03:53 PM
VQ'rInWLA's Avatar
Will give it a shot now. Ive tried it before and it didnt work. Maybe the procedure was incorrect?
Old 06-04-2012, 05:37 PM
VQ'rInWLA's Avatar
Open Driver Door.
Get In.
Shut Door.
Open Door.
Shut Door.
Start your car...
Now this works. Just tried it and succeeded. Thanks mang.
Old 06-04-2012, 06:16 PM
Tyutyunnik's Avatar
No problem, this is the same thing that worked for me about a month ago, I wouldn't have recommended it otherwise. It gives me peace of mind to know that my airbags are functional without that light flashing.
Old 06-04-2012, 07:13 PM
You already knew this....
http://forums.maxima.org/4th-generat...gain-99-a.html
Old 06-04-2012, 07:25 PM
VQ'rInWLA's Avatar
Oh yeah mustve slipped my mind.
Old 06-05-2012, 08:07 PM
Trini Boom's Avatar
Epic...
Old 08-10-2012, 07:06 PM
clint240sx's Avatar
Bunch of JERKS!!! lol what I meant was, will the light reset or come back like a CEL
It's not everyday I have to reset an airbag light...And I'm trying not to waste my time. I'd rather ask on here.
Dennis Twohy
10-01-2015 06:01 PM
Shock_and_Awe
08-23-2015 01:02 PM
Samedi
08-13-2015 04:05 PM
yat70458
08-03-2015 01:16 PM
Quick Reply: Air Bag Light flashing and fail codes.
