help identify where this vacuum hose should go
Old 04-11-2012, 03:09 PM
surban1's Avatar
[IMG][/IMG]
[IMG][/IMG]
this hose comes off the top steel vacuum line setup pictured. i looked for something near for it to connect to and didn't see anything. am i blind and just don't see where it connects or should it be longer and connect somewhere farther away? this area is the vacuum hose cluster near the fuel inlet line area. any ideas? thanks.
surban1 is offline
Old 04-11-2012, 03:30 PM
tigersharkdude's Avatar
its possibly the transmission vent hose (which doesnt connect anywhere)
I cant tell from the pics though, you took them too close
tigersharkdude is offline
Old 04-11-2012, 03:36 PM
2brosgixxer's Avatar
Imo it doesn't look like the transmission hose, but like said above, the pic is too close. Back away cor the next pic and point to the hose while you take the pic hopefully we can help.
2brosgixxer is offline
Old 04-11-2012, 04:01 PM
surban1's Avatar
[IMG][/IMG]it's not the trans vent hose; that's bigger and appears in the second pic right on top of the positive battery terminal cover.
[IMG][/IMG]
i've tried to look at the fsm but couldn't figure out anything from that either (diagram too small to figure out what's what).
surban1 is offline
Old 04-11-2012, 06:31 PM
Interesting, any error codes? Is there vacuum at the hose end when the car is running?
Old 04-11-2012, 06:43 PM
You're not talking about the one I circled in Red are you??
Old 04-11-2012, 07:10 PM
surban1's Avatar
to njmaxseltd: no error codes; i'll check tomorow if there's vacuum on it!
2brosgixxer: no; that's the trans breather. look by the wooden stick in the picture.
surban1 is offline
Old 04-11-2012, 07:17 PM
Ok, thats what I was gonna say if it was that one. So, to clarify is it THIS one in this pic? And where does it connect to on the other end EDIT: I just saw where you said this already
Old 04-11-2012, 07:31 PM
Trini Boom's Avatar
That hose is suppose to connect to the EGRC Solenoid right next to it. That hose with the lines on it is not the original hose and from the pic, it looks like it was rerouted somewhere else.
Trini Boom is offline
Old 04-11-2012, 07:35 PM
surban1's Avatar
yes; it's the one you marked "This One". i should have mentioned no codes in my original post. just went and checked for vacuum...none (at least while engine is still cold and hasn't run long enough to warm up...i'll check again tomorrow after it's run enough to warm up and report back).
surban1 is offline
Old 04-11-2012, 07:45 PM
surban1's Avatar
back in 2005 (at ~110k miles with ~ 180k miles now), a new EGR solenoid and BPT valve were put on by the dealer. yeah, that ridged od hose is oddball looking (only one i've seen like that on there so far) and is routed kinda meanderingly around.
surban1 is offline
Old 04-11-2012, 07:58 PM
sparky1562's Avatar
Here is shot straight down at mine. Hope this helps.
sparky1562 is offline
Old 04-11-2012, 08:08 PM
surban1's Avatar
from spark1562's pic and trini boom's insight, and the fact that the unconnected hose has no vacuum on it, i'm guessing that when the dealer changed the egr valve, they found no vacuum on the original hose & connected the ridged od hose (from who knows where) to bring vacuum to the egr valve. when i'm changing the valve cover gaskets and cleaning the egr tube, iacv & etc. sometime over the next few weeks, i'll locate where the ridged od hose goes, try to determine why original hose has no vacuum and attempt to repair & reconnect original hose to egr valve if possible. thanks everyone.
surban1 is offline
Miket2006
03-01-2021 03:55 AM
D Mason
06-21-2016 04:43 AM
conansriver
11-18-2015 02:46 PM
HerpDerp1919
09-29-2015 02:02 PM
followthadollar
09-13-2015 09:55 AM
Quick Reply: help identify where this vacuum hose should go
