can i use a 96 motor in 99 max?
Old 02-08-2012, 08:31 AM
nismo maximus's Avatar
i need to get the max running again. the cheapest/closest thing to me is a motor from a 96 max. i plan on keeping most, if not all of my sensors from my bad motor. as well as my intake manifolds. im also keeping my standard trans. (i think the new motor has auto trans)
but ive been hearing about a difference between motors this far apart. i know the 99 had to be different from all the others which makes it a PITA. im talking about differences as the odometer reading, and i think the vacuum lines have a small difference.
but anyways, should it just be plug and play essentially without having to get ecu and such? or would i be better off getting motor from a 99 max.
nismo maximus is offline
Old 02-08-2012, 08:45 AM
Bassbreaker's Avatar
Same motor. MAY be a few minor things like you mentioned, but they are of the same generation so you should be a go
Bassbreaker is offline
Old 02-08-2012, 09:35 AM
Grand_hustle17's Avatar
yes................... /thread
Grand_hustle17 is offline
Old 02-08-2012, 10:00 AM
alright. was just trying to clear things up. me and the local max guys have been discussing this for awhile now
Old 02-09-2012, 05:49 PM
MAXIMA_STYLE's Avatar
You guys are lying to him....ALL 99 engines are cali and 96 is not...therefore he will throw codes for swirl valves precar heated o2 sensors...
MAXIMA_STYLE is offline
Old 02-10-2012, 03:37 PM
imaking133's Avatar
you can use the motor. you just have to swap the vacuum lines, intake manifold (including the egr stuff), and the fuel rail from your 99
imaking133 is offline
HOKUSMAX
11-13-2017 04:34 AM
captchaos
17
03-15-2016 12:18 PM
Vequity
09-10-2015 05:26 AM
MaxLife17
09-08-2015 02:36 PM
Quick Reply: can i use a 96 motor in 99 max?
