How to: Reading and Clearing Diagnostic Trouble Codes
Old 12-18-2011, 09:48 PM
Laevateinn's Avatar
READING DIAGNOSTIC CODES
The stored malfunction codes are accessed using the red diode on the ECM. The codes are interpreted by the number and duration the diode flashes.
A long flash (0.6 seconds) indicates the "tens" digit while a short flash (0.3 seconds) is the "ones" digit. All flashes will have a short pause in between.
For example, if the red diode flashes once and then flashes twice rapidly this should be interpreted as code 12. The codes are displayed in numerical order starting with the lowest and ending with the highest.
If more than one code is in the memory, the ECM will always display the lowest number first, pause for about two seconds and then go to the next higher number. This will continue until all the stored codes have been displayed. The ECM will then go back to the lowest numbered code and repeat the cycle.
EXTRACTING DIAGNOSTIC CODES
1. Access the ECM and position it for observing the diode.
2. Turn on the ignition switch on (do not start engine).
3. Confirm that the "CHECK ENGINE" lamp in the instrument panel illuminates. If not check the bulb and/or the bulb circuit. Repair as necessary.
4. Turn the diagnostic mode selector on the ECM fully clockwise for at least two seconds then turn the selector fully counterclockwise. The ECCS system is now in mode 2.
5. Observe the diode and note the code(s) displayed.
Note: Code 55 indicates all systems are OK.
ERASING DIAGNOSTIC CODES
1. Turn the ignition key on.
2. Turn the diagnostic mode selector on the ECM fully clockwise and wait more than two seconds then turn the selector fully counterclockwise. The ECCS system is now in mode 2.
3. Turn the diagnostic mode selector on the ECM fully clockwise and wait more than two seconds then turn the selector fully counterclockwise. The ECCS system is now in mode 1.
ECM memory is now erased.
SOURCE: ALLDATA REPAIR 2011
Laevateinn is offline
sctludwig
09-01-2022 01:32 PM
HOKUSMAX
11-13-2017 04:34 AM
bryants95max
10-02-2015 12:52 PM
Dennis Twohy
10-01-2015 06:01 PM
sdotcarter
09-02-2015 09:53 PM
Quick Reply: How to: Reading and Clearing Diagnostic Trouble Codes
