Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Dyno Before & After 17 Degree Timing Advance
Old 12-16-2011, 01:44 PM
ranmas2004's Avatar
2002 Maxima 6 Speed (Mods in signature):
Finally got the dyno done today after I changed the timing from 15 degrees to 17 degrees using Cipher. Not much change in PEAK numbers (gained 4 ft-lbs on peak and HP stayed the same) BUT if you look at the midrange I picked up 10hp & 12 ft-lbs at 4100rpm over the last dyno.....torque increased some on the lower end too. I know I felt something!!
ranmas2004 is offline
Old 12-16-2011, 07:19 PM
036mtmax's Avatar
Nice man, I bumped mine to 17 on my old 03 but it was after i dyno'd it so i never got the chance to see what it did but i noticed the throttle response seemed better.
036mtmax is offline
Old 12-16-2011, 08:17 PM
OOmaxSE's Avatar
I thought 5.5 gens didn't hold the timing advance. It would retard itself after a few cycles making the 00-01's more successful in this field.
OOmaxSE is offline
Old 12-16-2011, 09:22 PM
ranmas2004's Avatar
Thats not true...it will hold from 13 to 17 degrees of timing. Stock is 15.
Old 12-16-2011, 09:42 PM
Correct. I gotta do this as well.
ChrisMan287 is offline
Old 12-16-2011, 10:39 PM
randalk's Avatar
this is somthing thats done with a consult right? anybody ever try it with a snap on soulus?
randalk is offline
Old 12-17-2011, 11:47 AM
Or with a Cipher from UpRev. The A32's wont hold it.
Nice.
NmexMAX is offline
Old 12-17-2011, 12:59 PM
Talkin' A33B here lol I know A32's won't hold.
Old 12-17-2011, 03:36 PM
036mtmax's Avatar
I know you can do it with the snap on Verdict
036mtmax is offline
Old 12-18-2011, 12:01 PM
ajcool2's Avatar
I love before and after dynos. Its all about area under the curve ftw!
ajcool2 is offline
Old 12-18-2011, 06:16 PM
7speed's Avatar
Thats whats up. True before and after dyno showing gains. This should clear up any doubts.
7speed is offline
Old 12-19-2011, 09:23 AM
That was my point, ALL A33's will. 00-03.
Been done before. ranmas reinforces it though.
http://forums.maxima.org/all-motor/4...ive-proof.html
NmexMAX is offline
Old 12-19-2011, 03:44 PM
Mr. Brett's Avatar
You can advance and retard timing with the Solus, but no, it will not stick. My friend tried to do it when he demoed the Solus last winter. It wouldn't stay no matter what we did.
Mr. Brett is offline
Old 12-19-2011, 04:55 PM
Rods03Max619's Avatar
Nice...
Rods03Max619 is offline
Old 12-20-2011, 06:37 PM
Grand_hustle17's Avatar
hey great dyno, is it possible for you to confirm in 48hrs that the timing didnt retard itself??? ive advanced timing but it went back to stock after a few days
Grand_hustle17 is offline
Old 12-20-2011, 08:24 PM
ranmas2004's Avatar
Timing and idle are still there.....I just checked today, funny you just mentioned that.
Old 12-20-2011, 08:34 PM
036mtmax's Avatar
I checked if it held on my old car when i bumped it with Cipher and it held.
036mtmax is offline
Old 12-20-2011, 08:55 PM
on mechanic said its possible it was still there but his obdII didnt pick up on it.... made no damn sense lls
Old 12-21-2011, 11:13 AM
My timing's kept for years. 3 batteries, numerous ECU code resets, weeks without use, etc. I check it every now and then for the hey of it.
NmexMAX is offline
Old 12-23-2011, 02:29 PM
Good to know, had mine done on the other car, looking to do this one soon....
Old 03-04-2012, 06:20 PM
any dates on dyno?
Old 09-10-2014, 06:20 PM
Mr Ten's Avatar
need my 11 dyno
Can your shop tune my 11 to eliminate the factory tune? just got it a couple months ago and im looking to do some cool things to it. I dont have a problem driving. Im in the Cleveland area
Mr Ten is offline
Old 10-03-2014, 11:48 PM
Nitehawk11sv's Avatar
I just took my 11 to a local shop here today and ill tell you that a consult 2 doesnt work for the 7thgen. And yes these guys are nissan techs for 40 years.
Nitehawk11sv is offline
Old 05-07-2015, 04:10 PM
Itz Shak's Avatar
How exactly do you ask a mechanic to advance your timing? Seems like no one has a clue as to what i'm talking about, and the ones that know are strongly against it. Where should i go to get this done?
Itz Shak is offline
Old 05-23-2015, 08:05 AM
NeedForSpeedGuy's Avatar
i would like to know this as well
NeedForSpeedGuy is offline
Ben2003GLE
31
07-17-2016 08:13 AM
305head
08-26-2015 09:03 PM
t6378tp
08-24-2015 07:03 AM
MaximaDrvr
08-19-2015 08:20 PM
Maxgig
08-18-2015 09:17 PM
Quick Reply: Dyno Before & After 17 Degree Timing Advance
