Possible Transmission Problems
Old 07-23-2011, 08:37 PM
bizzurk31's Avatar
Hello all,
Please go easy on me because this is my first new thread. I have tried to do a lot of research on my own, but you guys seem to give good advice. If anyone has experienced this, I would appreciate any input...
My Maxima:
2004 SE
153,000 miles
Automatic Transmission
Symptoms:
After the car is warmed up, after roughly a 10 minute drive, it "hesitates." Specifically, it hesitates when I am shifting to Drive. It will pause for as many as 3-4 seconds before harshly jerking into gear.
I have also noticed lately a similar hesitation while accelerating, which I have already seen as a problem from others on the forum.
I used Gumout Regain a month or two ago, and it didn't affect the problem at all. I am beginning to be afraid the transmission is shot, and therefore my wallet... Any ideas or advice?
bizzurk31 is offline
Old 07-23-2011, 08:53 PM
rawmax1's Avatar
Have you changed your fluid? How are your mounts?
rawmax1 is offline
Old 07-23-2011, 09:11 PM
bizzurk31's Avatar
I have changed the transmission fluid. Concerning the mounts, I really don't know. I haven't come across any advice saying to check mounts, so I haven't checked. Sorry, I'm not very car-savvy.
Old 07-23-2011, 10:17 PM
NiZMo1o1's Avatar
what fluid did you replace back with ? Nissan K-Matic ?
Bad mounts usually cause jerking, in your case
Delay shifts could be the bands being worn internally , or low fluids.
NiZMo1o1 is offline
Old 07-24-2011, 05:18 AM
bizzurk31's Avatar
I really don't remember what kind of transmission fluid I used. I replaced it nearly a year ago.
So far, possible trouble spots: Low fluid, bad mounts, worn transmission bands
I really appreciate all the feedback
Old 07-24-2011, 07:27 AM
Costee's Avatar
First things first: scan the car
Costee is offline
Old 07-24-2011, 06:41 PM
bizzurk31's Avatar
Thank you for the response, but what exactly do you mean by that? Take it in for a general inspection?
Old 07-24-2011, 06:58 PM
chris350's Avatar
sounds like a bad transmission. Hesitation followed by shifting in hard means something internal.. i had similar situation on my 06. You can start simple and see if you can start ruling out things. First take it to a mechanic, describe your problems, he should check for codes, yours mounts and fluids.. if its none of those then its the transmission and you should be able to advise you on what to do...
chris350 is offline
Old 07-25-2011, 01:54 AM
Costee's Avatar
lol. You've been so lucky with your car. You seem to know little about it because it had given you no problems till now. By scanning it means the engine/tranny is checked for possible problems, some form of diagnosis. I'm told this is done free at Auto zone. If there are problems some codes will be indicated and solutions found to the issue. Yes, your mechanic should be able to advise you accordingly.
Costee is offline
Old 07-25-2011, 05:37 AM
BossMaxima's Avatar
I had the same problem and it ended up being the valve body. Dont replace the transmission if you dont have to.
BossMaxima is offline
Old 07-25-2011, 05:51 AM
bizzurk31's Avatar
Thank you all for the replies. I really appreciate it.
There is a Firestone Complete Auto Care next to my work. I am thinking about taking it there and having a "Complete Vehicle Inspection."
Costee, I might also go to an AutoZone and see if they will scan my car.
Old 07-25-2011, 06:40 AM
Costee's Avatar
Nice. The valve body is usually the culprit in these matters; but it's better to confirm through the scan. Good luck.
Costee is offline
Old 10-20-2017, 08:27 AM
Dulce Cristina's Avatar
Ni
Did you ever find out what was wrong with your transmission? I ask because I'm having the same exact problem and as of right now I'm being told the labor alone will run me $3800. Conteplating selling it .
Dulce Cristina is offline
sctludwig
09-01-2022 01:32 PM
hez8813
03-12-2020 12:06 AM
boomerbrian
10-31-2018 10:25 AM
The Wizard
24
10-01-2015 08:47 PM
Quick Reply: Possible Transmission Problems
