water pump drain plug
Old 06-13-2011, 04:26 PM
Decoy036SPD's Avatar
I am in the process of changing the water pump and it says there is a drain plug for it located right near it. I do not see one at all. I removed two bolts and no coolant came out. It would be nice to get any extra coolant out just so less goes into the oil however if not no big deal. I am definitely changing the oil anyways. Any help would be appreciated.
-Charlie
Decoy036SPD is offline
Old 06-13-2011, 04:48 PM
"I'm just sayin'..."
nelledge's Avatar
The FSM illustrates it as being to the lower right of the pump as you're looking at it. Nothing there? Also, the drain plugs are a pain to get out. I've done it before, but I can't believe most people would give the effort.
nelledge is offline
Old 06-14-2011, 03:42 PM
three.fiveSE's Avatar
It is there. I just did this myself.
It is recessed quite a bit into the engine. I think it was either a 12mm or 14mm, not too sure off the top of my head.
three.fiveSE is offline
Old 06-14-2011, 04:04 PM
05SickSer's Avatar
Its there as they stated. Its a little ways in. IIRC its near the center right side of the timing cover towards the front of the engine bay, and is a 12mm or 14mm as stated above
05SickSer is offline
jmlee44
10-02-2022 02:13 PM
Miket2006
03-01-2021 03:55 AM
gigabyte
01-06-2017 06:05 PM
Forge277
06-13-2016 09:26 PM
Quick Reply: water pump drain plug
