Freon Freon
Old 06-06-2011, 07:33 PM
MaxPrime's Avatar
Freon Freon
Do anyone knows how many pounds/cans of freon you need in the 2004 maxima.
MaxPrime is offline
Old 06-06-2011, 08:05 PM
revvinMAXto11's Avatar
depends on what your doing.
is your car completely empty,
air not blowing cold at all
air just now blowing cold enough
your question is too vague.
if your completely empty 2-3 cans should do it.
revvinMAXto11 is offline
Old 06-06-2011, 08:06 PM
MaxPrime's Avatar
Originally Posted by revvinMAXto11
2 cans at a car parts store should do it.
Ok so i will put 3 thats good right , is empty my mechanic said and i might have a small lick and the 3 cans i will add he said might last me the whole summer so i will give it a try not costing me nothing so dont hurt to try.
MaxPrime is offline
Old 06-06-2011, 08:26 PM
ooh ok, no don't just put in the cans.
go to pep boys or autozone. buy some A/C sealant. it is works like an epoxy and will fill in any leaks you may have. when you are finished with that, put in the 2-3 cans of R-134a and your ac should be fixed permenantly
Old 06-06-2011, 08:56 PM
MaxPrime's Avatar
So the seleant counts as a can or , I can still add 3 can after that.
MaxPrime is offline
Old 06-07-2011, 10:35 AM
MaxPrime's Avatar
Ok how long from the time I add te sealant I can put the 2 cans of freon in?
MaxPrime is offline
Old 06-07-2011, 11:31 AM
Willing to learn
oldngivout's Avatar
The correct R134a charge on a 2004 Maxima is between 18.5-20 ounces.
Since each can contains 12 ounces, the installation of two full cans will result in 4 oz. overcharge.
1 1/2 cans is closer to correct.
oldngivout is offline
Old 06-07-2011, 11:35 AM
MaxPrime's Avatar
Ok when I put the sealant in so I have to drain it or do I have just add the 1 1/2 cant of freon after.
MaxPrime is offline
Old 06-07-2011, 11:39 AM
Willing to learn
oldngivout's Avatar
I wouldn't advise using any aftermarket sealants.
The refrigerant leak (if you have one) should be repaired properly. Junk in a can won't do that.
Old 06-07-2011, 11:43 AM
MaxPrime's Avatar
Ok thanks , but do that can't count as 12ounces or or I have to drain it out the put 18.5 ounce again.
MaxPrime is offline
Old 06-07-2011, 11:48 AM
Willing to learn
oldngivout's Avatar
Ok then, just read the label and it should tell you how much actual 134a the sealant can contains. They are mostly refrigerant, with a little sealer mixed in.
Subtract that from 18.5.
Old 06-07-2011, 11:56 AM
MaxPrime's Avatar
Ok will do thanks for your help.
MaxPrime is offline
Old 06-07-2011, 06:26 PM
Nismo4life07's Avatar
do NOT put in the stop leak. that ruins your AC system.
you need to find the leak and replace whats leaking. when you use the recharge kits that just stops your problem for a little bit. i GARAUNTEE you it will not last the whole summer without you having to put more in it.
in MOST cases, the 6th gens leak out of the Low Side AC hose where the metal crimp is right behind the front air dam. if that is the cause, get a new hose (like $120 at courtesyparts.com) and get it replaced and recharged by a mechanic with an AC machine. those cans do not have the power to recharge the whole system properly.
and i say get it done by a mechanic because to change the hose, you have to completely purge the system, then install, then recharge.
my shops sees cars come in all the time that had a small leak to begin with and just kept using those recharge kits and it actually made the leak bigger and made the compressor seize up due to the lack of oil and refrigerant. so get it fixed THE RIGHT WAY before your bill goes from 100 + labor to 500-700 + labor.
Nismo4life07 is offline
Old 06-07-2011, 07:04 PM
QwikKota's Avatar
If you are going to be adding any more than 1/2 a can I suggest getting a set of gauges so you don't damage your system. Probably best to pay a mechanic since a set is $100 or so. It is easy to over pressurize (overfill) the system.
I bought a set of Mastercool gauges and they work well. Only fill with low side open etc.
Made in the USA
QwikKota is offline
Old 06-08-2011, 05:53 AM
MaxPrime's Avatar
Oh man i put the stop lick in before i seen any of your post about stop lick missing up your system i hope it dont but for sure it will be the last time i put that thing in the car for sure thanks.
MaxPrime is offline
Old 06-08-2011, 02:02 PM
if you only used one can of it, you may be fine... but you need to get it serviced by a licensed mechanic whenever the problem comes back.
Old 06-08-2011, 03:07 PM
Sterling2000's Avatar
There is one sealant that I can recommend. It is called Red Angel A/C Stop Leak from USA Sealants. It has a money-back guarantee and will not do any damage to your vehicle. I am an ASE certified AC tech. This is the only product Robinair (the manufacturers of our AC service machine) will allow without voiding our warranty. Others are notorious for clogging the filters on the service machine. This product plus 19 ounces of refrigerant will give you a full charge on an 04 Maxima. If the product does not work it does have a money back guarantee. Good Luck.
Sterling2000 is offline
Old 06-08-2011, 03:23 PM
twentyeggs's Avatar
i would say replace your hoses, its easy. if you don't know how to do work and you don't want to pay a mechanic then use the stop leak. I've head horror stories, but they were all being used in a situation where stop leak wasn't acceptable.
if you have a small pin hole leak, then use it. My buddy used it in his 67 trans am, and its been solved for 7 years and going. all it is is a liquid that hardens when it reaches air, its an epoxy. it breaks down when its compressed and mixed with R-134a. so it work instantly on your leaks and then the epoxy component become inactive. its not dangerous for your system, if there are no leaks its just doesn't do anything.
twentyeggs is offline
Old 06-08-2011, 06:36 PM
except clogs the filters.
dont use stop leak.
Old 06-09-2011, 03:53 AM
MaxPrime's Avatar
I am hearing to many sides lol going to get the leak fix thanks for the input.
MaxPrime is offline
pears
09-18-2015 05:25 AM
drakken789
12-14-2003 05:21 PM
MAX89'
06-10-2003 03:16 PM
Dave Shalita
06-03-2003 02:03 PM
JAYinAK
04-26-2002 11:27 PM
Quick Reply: Freon Freon
