Replacing Transmission mount...
Old 05-24-2011, 10:36 AM
TallTom's Avatar
Did some searching for it and think I found one thread describing the swap, but need clarification.
Can you really replace the Trans Mount from above? From what read, you need to remove the intake piping, battery & tray, and then just support the trans with a jack while you swap it out.
It can't be just that easy.
Read it here: http://forums.maxima.org/6333350-post4.html
TallTom is offline
Old 05-24-2011, 11:33 AM
I actually wouldn't even attempt it from the bottom. So yeah, it is that easy.
NmexMAX is offline
Old 05-24-2011, 11:57 AM
Suspension Yoda
djfrestyl's Avatar
+1. You may also have to move some power and starter wires out of the way.
Oh and a really long socket extension helps.
djfrestyl is offline
Old 05-24-2011, 12:49 PM
TallTom's Avatar
Thanks guys. It just seeemed too easy. I had my mechanic replace the torque mounts and pass engine mount with ones form ebay, but I think I am going to do the trans one myself when I get it ordered from the dealer.
TallTom is offline
Old 05-25-2011, 01:03 PM
bullet187's Avatar
The trans mount may be easier in the sense that you don't have to go under that car, but it takes the most time too replace out of all the mounts because there are a lot of bolts and hardware to remove to get to it. Then once you get to it you will have to disconnect the starter wire and other wires that are in the way of the mount to pull it out. It may be easier to remove to starter completely to give you more room to pull out the mount.
bullet187 is offline
Old 05-27-2011, 09:46 AM
TallTom's Avatar
OK, thanks for the heads up. I appreciate it.
TallTom is offline
CorollaULEV
30
08-09-2021 08:11 PM
Matt93SE
05-24-2019 02:58 PM
Cotozic
06-28-2017 08:01 PM
PH98I30
08-20-2015 04:25 PM
Tanvirkamal
08-05-2015 01:32 AM
Quick Reply: Replacing Transmission mount...
