How do you "warm up" your manual transmission ?
Old 05-15-2011, 06:18 AM
mahanddeem's Avatar
This morning , as every morning , shifts in my 2k2 6SPD transmission are really slow , hard and stiff .... It was for sure much worse during the winter days , but stil bad during the first 10-15 min of driving in these mornings (when temp is in the 40s range) ... I know many will say it only takes 2 to 3 shifts in cold start after which they would be normal ... But it is definitly not the case,especially the 2nd and 4th gears.....So I have to take it easy on the transmission during these cold times !!! and it is really embarrassing to accelerate in an ultra-granny fashion , praying not to stop on a stop sign or a red light ...
I already know the drill ... Use synthetic gear oil , which I already have , Amsoil GL4 75w90 (for the last 5k miles).....I doubt redline MT85 would make a world of difference .... Although I might try it someday.
My qustions for you :
1.Do you suffer from the same issue ? what would you do to overcome ?
2.How much time approximately your 6SPD takes to shift smoothly ?
3.Is shifting when tranny is cold , harmful to it ?
Please share your thoughts here..
thanks
mahanddeem is offline
Old 05-15-2011, 06:32 AM
Bad *** Newb
Child_uv_KoRn's Avatar
I have nothing to add but I have no clue about these symptoms.
It has to be synchro related b/c it can be 0 degrees and both 6 speeds that I've had shifted just fine.
Child_uv_KoRn is offline
Old 05-15-2011, 07:05 AM
nismopc's Avatar
thanks
1. Yes. Nothing.
2. Within a block of my home.
3. Not that I am aware
Using Valvoline GL-4 Hypo Gear Oil...
nismopc is offline
Old 05-15-2011, 07:26 AM
TallTom's Avatar
With the original fluid, it would be hard to shift in the winter, like the fluid was maple syrup. I switched to MT-85 a little over a month ago and noticed a big improvement.
85 weight is slightly lighter than 90, but you may have other problems as well.
I wouldn't say shifting while cold is harmful, but I wouldn't be slamming gears. Then again, your engine is also cold so I wouldn't be putting stress on the car.
TallTom is offline
Old 05-15-2011, 07:39 AM
datsunzcar84's Avatar
You have seen NO improvement using Amsoil? It was night and day difference for me.
How many miles are on your max?
datsunzcar84 is offline
Old 05-15-2011, 10:26 AM
mahanddeem's Avatar
I didn't say I saw no improvement,indeed I couldn't .. I changed the gear oil 4 days after I bought the car..It has 118k miles.
Old 05-15-2011, 03:59 PM
joeltender's Avatar
When it gets below freezing up here in the great white north, double clutching works great until the 6spd warms up. As well as motul 75 85 gear oil - 85 is truly necessary!
joeltender is offline
Old 05-15-2011, 04:00 PM
Da Roller Coaster!
foodmanry's Avatar
Buy her a bottle of wine and whisper sweet nothings to her...
foodmanry is offline
Old 05-15-2011, 06:17 PM
Toolie
knight_yyz's Avatar
motul
knight_yyz is offline
Old 05-15-2011, 07:22 PM
mahanddeem's Avatar
Originally Posted by knight_yyz
motul
Is it better than redline 85MT ? what does Rochester use ?
Old 05-16-2011, 05:38 AM
matt06's Avatar
i have only experienced this a couple of times up here in the winter but i have had MT90 within a month of buying the car.
seems great for me now
matt06 is offline
Old 05-16-2011, 09:44 PM
trooplewis's Avatar
I have MT90 in mine.
Shifts just as bad as it did with Nissan lube in it.
Shifts just as bad in cold weather as hot weather.
We just don't have smooth, *snick snick* shifters in out cars. I've driven worse, but I have also driven way better.
I find the the best shifts I get are ones where I really pay close attention to the RPM's at the shift point. There seems to be a sweet spot for each gear usually around 2300-2600 rpms. LOL, that leaves a lot of you guys out, eh?
trooplewis is offline
Old 05-17-2011, 11:16 AM
MintVQ35's Avatar
Mine shifts great with the stock 118k fluid in it, a bit clunky when it's really cold but nothing I've not experienced before in other manual transmission vehicles.
MintVQ35 is offline
Old 05-17-2011, 12:02 PM
NAVY00MAXIMA's Avatar
I'd try using a block/pan heater.
NAVY00MAXIMA is offline
Old 05-17-2011, 12:15 PM
Rochester's Avatar
Redline MT-85, for about a month now. The product is new, but a number of people here are using it now and have posted some great reviews.
As for "what does Rochester use..." There are some actual gearheads here (Hi, Ray) who's opinions carry far more weight than mine.
Rochester is offline
Old 05-17-2011, 01:21 PM
mahanddeem's Avatar
With respect to all the gearheads here , but I like your opinion.......
Old 05-17-2011, 01:38 PM
Rochester's Avatar
Alright then. Thanks, OP.
My tranny shifted different, but neither better nor worse than OEM after installing MT-90. However, the changes were welcome and noticeable after swapping in MT-85. That's all I know.
There was a really good thread about this around a month ago.
Old 05-17-2011, 01:50 PM
exandr's Avatar
What he (Rochester) said. This Saturday I put MT-85 in and the difference bw it and MT-90 are quite noticeable for me. Smoother, more crisp shifts and less "crunch", but it's still there.
I live in FL...so we don't see any snow and it doesn't get cold.
exandr is offline
hcarter1112
42
07-18-2022 03:35 PM
tarun900
19
12-20-2021 06:57 PM
Miket2006
03-01-2021 03:55 AM
Quick Reply: How do you "warm up" your manual transmission ?
