Changing Inner tie rod
Old 03-25-2011, 03:48 PM
carrottop's Avatar
Does any 1 have a write up of how to do this? also, does any1 know the size of the tie rod tool i need to get?
carrottop is offline
Old 03-25-2011, 04:03 PM
datsunzcar84's Avatar
Well buy this tool . http://www.harborfreight.com/inner-t...set-96558.html
when you remove the outer tie rod Take a mental note of how many turns it takes to remove so you can get the alignment close ( you still should align your car) . Then remove the gear bellows boot over the inner rod . Select the right size adaptor for the inner tie rod tool. Then rachet it off. Install in reverse order.
Then go buy yourself some beer from all the money you saved by not taking it to the stealership!!
datsunzcar84 is offline
Old 03-25-2011, 04:04 PM
carrottop's Avatar
kk thanks i found a picture write up also, im jw what the exact size for the tie rod tool i need because i plan on renting it from autozone
Old 03-25-2011, 04:09 PM
Well just take your new tie rod into autozone when you rent the tool.
Old 03-25-2011, 04:21 PM
carrottop's Avatar
good thinking lmao im an idiot thanks for talking me through
Old 03-25-2011, 04:26 PM
carrottop's Avatar
should i buy new lock plates or can i just use the old ones? where would i find these ?
Old 03-25-2011, 04:45 PM
VQP0WER's Avatar
I don't think Autozone rents these. The only place around us that even had it was Napa.
When I changed mine I went down the street to this tire place and bribed one of the mechanics to borrow the tool for 20 mins. Gave him $20 and he let me take his set home and replace the inners which took no time.
VQP0WER is offline
Old 03-25-2011, 05:21 PM
"I'm just sayin'..."
nelledge's Avatar
Go to Oreilly Auto Parts to rent this tool. It's perfect. Much better than the Autozoo one. It comes in a case with three different size adapters. I believe it's the middle size that fits our inners. If you do go the Autozoo route, I believe you need to get the tool and the adapter.
nelledge is offline
Old 03-25-2011, 05:22 PM
No prob man ..
VQpower you must have found a very trusting mechanic! I hate to lend the guys I work with my tools .
Old 03-25-2011, 05:49 PM
VQP0WER's Avatar
Originally Posted by datsunzcar84
No prob man ..
Thing is, never met the mechanic in my life. I did get my tires and crap from them, but never seen this mechanic. He was very trusting to let me borrow them and I let him know how much I appreciated him helping me out.
VQP0WER is offline
Old 03-25-2011, 06:00 PM
You are very lucky to find such a trusting person. If you ever need service you know you can trust him . Lol
Old 03-25-2011, 06:23 PM
pinellas50's Avatar
I bought the Harbor Freight tool to do mine as well. The rentals from Autozone and Advance Auto Parts sucked.
My 01 did not have locking plates. I used blue locktight on the threads when putting the new one in.
This job was actually very easy to do with the right tool. You will need to get the alignment done ASAP after replacing.
Good luck.
pinellas50 is offline
Old 03-25-2011, 07:02 PM
carrottop's Avatar
yeh plan on getting one within the next 3 days, should i buy or rent? im not tight on money , but am i gonna get that much use out of it?
Old 03-25-2011, 08:20 PM
I would say you probably won't get much use out of it . I used mine maybe a handfull of times a year when I worked at a garage... If you can rent what you need it will save you money . Or you can buy it then rent it out to your friends. Lol
Old 03-25-2011, 08:48 PM
nelledge's Avatar
Rent. See my previous post.
nelledge is offline
Old 03-26-2011, 09:02 AM
carrottop's Avatar
so i called autozone and they do have the inner tie rod, but the only problem is that they said they only have 1 adapter which is 1 7/16", but when i measured mine it was 1 5/16". do u think i could still rig this up to work by just placing a metal bracket of 1/8 " to make up for the play?
Old 03-26-2011, 09:15 AM
It's possible... I would try to call a different parts house to get the right size.
Old 03-26-2011, 09:18 AM
Do you have a wrench that will fit it? If you do , you can turn the wheel the opposite way of the tie rod your replacing. Bringing the tie rod as close to the outside of the car as possible. You may then have enough room to get at it with the wrench.
Old 03-26-2011, 10:03 AM
carrottop's Avatar
ok, well i assume the autozone one will fit because on the site it says the stock tool fits 1 3/16" and 1 5/16" so i shuld be all set.. wish me luck, and the llast time i tried i culdnt get that damn thing to move at all
Old 03-26-2011, 02:04 PM
Well just get a section of pipe and slip it over the rachet to give yourself more leverage. Good luck And may the Force be with you ! LOL
Old 03-26-2011, 02:40 PM
pinellas50's Avatar
Good luck. If you are getting the same Autozone tool I rented then you will soon be looking to buy from Harbor Freight. Haaaaa.
Old 03-26-2011, 02:42 PM
nelledge's Avatar
OP, where do you live? Is AZ the only parts store around you?
nelledge is offline
Old 03-26-2011, 05:49 PM
carrottop's Avatar
nope, i have napa, harbor freight, advanced auto parts... how can the autozone one be that bad?
Old 03-26-2011, 06:23 PM
nelledge's Avatar
It's not bad, it's just worse than good. The tool at Oreillys has an adapter that fits snugly on the tie rod while the one AZ has slips. Sure you can shim it, but it's kind of a PITA with the clearance you'll be working with. To each his own. Wear gloves if you're going to use the AZ tool. Your knuckles will thank you.
nelledge is offline
Old 03-27-2011, 10:58 AM
carrottop's Avatar
ok, so i got the one from autozone, is the tool supposed to fit over the inner tie rod or just press against the edge of it?
Old 03-27-2011, 11:22 AM
nelledge's Avatar
The adapter fits over the flat ends of the ITR.
nelledge is offline
Old 03-27-2011, 11:27 AM
carrottop's Avatar
damn, it doesnt fit that far wtf
Old 03-27-2011, 12:23 PM
nelledge's Avatar
I can probably assist you if I have more information. You have PM.
nelledge is offline
Old 03-27-2011, 01:24 PM
woosh's Avatar
Hey Carrottop,
Would you mind posting the link to the write up you mentioned above?
woosh is offline
Old 03-27-2011, 01:47 PM
nelledge's Avatar
Originally Posted by woosh
Hey Carrottop,
This should help you out. It's a 4th gen, but they're nearly identical. You don't need the gear puller if you're replacing the tie rod with new. You can just tap the shaft with a hammer.
nelledge is offline
Old 03-27-2011, 04:27 PM
carrottop's Avatar
yeh this is the link i used too
Old 03-28-2011, 05:58 AM
pinellas50's Avatar
The adapter part of the tool fits on the end of the tie rod where it screws into the rack. Put that on and then slide the entire tie rod arm into the pipe of the tool. Slide the pipe all the way down until the adapter fits into the end of the pipe headed towards it. I don't know how else to explain that one.
Old 03-28-2011, 04:39 PM
carrottop's Avatar
the autozone pipe was too small, i ended up buying the kit from harbor freight for 55$, did both the tie rods, sprayed the tool black to give it the new look and returned it back the next day...they didnt even look in the box! getting an alignment tommorow
Old 03-28-2011, 04:51 PM
VQP0WER's Avatar
Lol. I've done that before. I'll need a tool only once but the store won't loan them out. I then ask, "whats your return policy?" and smile. They'll just put it back on the shelf and not lose any money from it anyways.
VQP0WER is offline
James92SE
142
01-02-2024 09:23 AM
hcarter1112
42
07-18-2022 03:35 PM
Need help
23
10-02-2015 08:56 AM
londonflu
09-19-2015 02:33 PM
Quick Reply: Changing Inner tie rod
