Motor Mount Questions
Old 02-23-2011, 03:37 PM
Nissanx54's Avatar
I know that on the 5.5 gen maxima's there are motor mounts with sensors in them. Which mounts have the sensors? I have had some people tell me the front and rear and some tell me just the front
Nissanx54 is offline
Old 02-23-2011, 03:45 PM
Only the front mount has a sensor, and only in the AT version.
NmexMAX is offline
Old 02-23-2011, 04:16 PM
tcb_02_max's Avatar
As long as this question was already answered, I have another: do most people swap only the lower motor mounts? IIRC there are two on the side of the engine as well. Is this only due to an available upgrade/greater failure of the lower mm versus the side ones? I'm assuming I'll just take a peek at all four and see if any or all need replacement.
tcb_02_max is offline
Old 02-23-2011, 04:40 PM
Ghost_54's Avatar
The lower mounts (also referred to as) torque mounts, if you want the engine to sit perfectly still without any rocking front to back the guys will swap these mounts for ES polyurethane mounts. Changing these mount out reduces wheel hop, and torque steer allowing the engine power to go straight to the wheels and ground. The side mounts usually get changed when one notices any tears in them or experience hearing any clunking noises. Mine is an automatic so yes there is only the one electronic front mount which is left unplugged when you swap the mount out. You will notice an increase in the cars vibration when you are at idle, but you would experience no vibration when the car is in motion.
This is an excellent mod, and I am very happy that I had mine swapped out.
Ghost_54 is offline
Old 02-23-2011, 05:33 PM
Nissanx54's Avatar
thanks for the answers guys. i am not going for performance just tryin to keep the car on the road until i have enough cash to get something better.
Old 02-23-2011, 09:47 PM
DennisMik's Avatar
This is interesting. The 2000 has front and rear electric mounts - so Nissan decided two weren't needed. But even more interesting is that the 2003 FSM shows a front and rear electric mount (EC-713).
DennisMik is offline
Old 02-24-2011, 01:26 AM
Intrepid1's Avatar
I have a 2001 GLE and it has 2 electric mounts
Intrepid1 is offline
Old 02-24-2011, 02:39 AM
nismopc's Avatar
Intrepid1: Repeat yourself much?
nismopc is offline
Old 02-24-2011, 04:32 AM
Nissanx54's Avatar
guess i will just have to get under the car and look for myself when the weather is a little better down here.
Old 02-24-2011, 06:22 AM
When I did headers, I only unplugged the front mount, not the rear. And I removed the entire assembly w/both F&R mounts. Maybe it's CAN/bluetooth.
Mine is an 03, B/D 10/02.
NmexMAX is offline
Old 02-24-2011, 07:36 AM
kukx30de's Avatar
It's not really a sensor. The mounts have some kind of ferrofluid in them which when activated by an electrical signal makes them stiff. Thus, when you are at idle the mounts are soft and they get hard once you hit a certain RPM.
In my 01 GLE I swapped out the mounts for non fluid filled mounts from eBay. I put them in at about 167K and am now at 199K without any issues.
There is a minor vibration at idle which is barely noticable.
One of the biggest reasons folks swap out mounts is:
A short in the mount will cause your ECM to go bye bye... and yes other put in the poly mounts as a mod too!
By switching them out... if you have high miles is a kind of save yourself move.
Thats what I did.
kukx30de is offline
Old 02-24-2011, 05:05 PM
Nissanx54's Avatar
my car vibrates at idle sometimes now
Old 02-25-2011, 05:30 PM
JavY's Avatar
my front motor mount is cracked. I am looking to replace it myself soon. Any one know where i can buy these ES polyurethane mounts and are they direct fit ?
JavY is offline
Old 02-27-2011, 11:52 AM
cabernet's Avatar
Anyone find a good price on OEM mounts? Best I could find was $155 for the front mount for a 2K Max from an online Nissan dealer.
cabernet is offline
Old 02-27-2011, 11:59 AM
nismopc's Avatar
eBay. That price will get you all 4 mounts. ;-)
nismopc is offline
Old 07-26-2015, 02:00 PM
b0nes's Avatar
What does AT mean ?
b0nes is offline
Old 07-26-2015, 02:08 PM
cornholio's Avatar
Originally Posted by b0nes
What does AT mean ?
Automatic transmission
cornholio is offline
Old 07-27-2015, 06:32 PM
b0nes's Avatar
Thank you
Is there a website where I can look up how to put on the motor mounts?
b0nes is offline
AcuraLegend
10-17-2016 08:47 PM
vingodine
45
05-21-2016 12:46 PM
AcuraLegend
09-22-2015 04:22 PM
Johnny9595
09-03-2015 05:18 AM
sdotcarter
09-02-2015 09:53 PM
Quick Reply: Motor Mount Questions
