Can an exhaust leak trigger the Service Engine Soon light?
Old 02-06-2011, 12:38 PM
michaelm815's Avatar
My engine light came on today...
I'm up to date with maintenance on her and I don't really know what the problem could be.
I have a pretty bad leak in the Flex Pipe and haven't got around to getting it fixed yet, could it be that the leak got bad enough to illuminate the light?
I'm going tmr to have my mechanic run the code but trying to figure out what may be wrong.
michaelm815 is offline
Old 02-06-2011, 01:20 PM
Rochester's Avatar
Step 1. Read codes.
Step 2. Listen to your mechanic.
Step 3. Research what you need to know.
Step 4. Fixed.
You jumped right to Step 3. Take a deep breath, and wait it out until tomorrow.
Rochester is offline
Old 02-06-2011, 02:46 PM
zzmmrx0xmzz's Avatar
Possibly. I know my test pipes are not snuggly fitted and there is a leak which i need to retighten soon and my check engine light has been coming on pretty often the past few months.
zzmmrx0xmzz is offline
Old 02-06-2011, 05:05 PM
Stormzusmc's Avatar
yes it can
Stormzusmc is offline
Old 02-06-2011, 05:21 PM
captain jack's Avatar
get cheap code reader on ebay. comes in handy more than you think.
captain jack is offline
Old 02-06-2011, 05:38 PM
Nexus67's Avatar
^Otherwise Autozone= free code check
Nexus67 is offline
Old 02-07-2011, 05:43 AM
ken85's Avatar
test pipes usually set off the rear o2 sensor because the readings are different.
But yes an exhaust leak CAN cause a cel. It is EXTREMELY RARE it has to be a massive leak at the right spot.
ken85 is offline
Old 04-27-2011, 09:55 AM
chico102388's Avatar
i have a check engine light for the rear o2 sensor wich i changed but keeps coming back on after reseting it. i have a massive leak in the flex pipe which is getting repair right now should get it back in an hour ill see if the light goes away.
chico102388 is offline
Old 04-27-2011, 12:38 PM
MerlotMax's Avatar
Think about it now - o2 sensor is a Oxygen sensor, it is looking for changes, from a preset value, in the oxygen in the exhaust. You have a "massive leak" ahead of the OXYGEN sensor
MerlotMax is offline
Old 05-04-2011, 07:05 PM
bmwmike's Avatar
if the leak is before the o2 sensor then yes.
bmwmike is offline
Dennis Twohy
10-01-2015 06:01 PM
maxinout93
08-16-2015 07:25 PM
Flores94
08-11-2015 12:53 PM
Quick Reply: Can an exhaust leak trigger the Service Engine Soon light?
