P0031 and P0037 codes - anything to worry about?
Old 02-05-2011, 01:35 PM
viperboy's Avatar
I see that these are heater codes for the o2 sensors, not the actual o2 sensors. Is this something that is robbing me of power or making my MPGs go down or just an annoying code? I wanted to get this fixed if it's not a minor issue. Also, when the codes were pulled, I had 2 of each, one said pending the other didn't.
Did a search on here and no one ever said what they did about their 0037 code. Hoping for a little help from the 5th gen gods lol thanks!
viperboy is offline
Old 02-05-2011, 07:43 PM
viperboy's Avatar
Bump
viperboy is offline
Old 02-05-2011, 08:06 PM
That's Mr. Detail to you
Scottwax's Avatar
Won't affect performance but for me, it did single the end of the precats. As soon as I got the secondary O2 fixed, the dreaded P0420 code popped up and didn't go away until I replaced the precats.
Scottwax is offline
Old 02-05-2011, 08:09 PM
viperboy's Avatar
Thanks for the info, however, I have headers so I don't think I'll be having any precat issues
viperboy is offline
Old 02-05-2011, 08:44 PM
Scottwax's Avatar
In that case, I'd just get O2 sims and be done with it.
Scottwax is offline
Old 02-05-2011, 09:07 PM
a.k.a. STuNtMAN
JonBlz's Avatar
P0031 - Heated Oxygen Sensor 1 Heater Low Voltage (Bank 1)
P0037 - Heated Oxygen Sensor 2 Heater Low Voltage (Bank 1)
JonBlz is offline
Old 02-07-2011, 05:46 AM
ken85's Avatar
Hrmmm that usually means the sensor is bad doesn't it? I always get o2 sensor codes switched. If it's a primary sensor: Yes it will rob power. Primary sensors do alot on a newerish vehicle. They control the timing and fuel maps. It will also cause massive misfire issues at partial throttle when the vehicle is warm because when you go wot it runs off a certain map and when it's cold it runs off a certain map
ken85 is offline
Old 02-07-2011, 08:51 PM
josueboca's Avatar
P0031 and P0037 codes???
josueboca is offline
Old 02-08-2011, 11:41 AM
Rob510's Avatar
The sensors have heaters in them and need to be at a specific temperature to work properly. So if the heaters are no good they are not functioning properly and should be replaced
Rob510 is offline
Old 11-27-2011, 12:14 AM
clintb3astwood's Avatar
I have the same issue! P0031, bank 1 sensor 1, it was replaced with a new one today "/
clintb3astwood is offline
Old 11-28-2011, 07:19 AM
luvlexus101's Avatar
02 sim ftw.
and i dont have headers
luvlexus101 is offline
maxinout93
10-31-2015 02:04 AM
Kyle Lee Cleveland
09-28-2015 09:01 PM
dshinn
09-26-2015 08:07 PM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: P0031 and P0037 codes - anything to worry about?
