does anyone know where the mode door motor is located at on 1999 maxima
Old 12-11-2010, 04:18 PM
lux97Max's Avatar
sup guys does anyonme know where does anyone know where the mode door motor is located at on 1999 maxima
lux97Max is offline
Old 12-11-2010, 05:02 PM
asand1's Avatar
What is the mode door?
Are you talking about heater blend door?
asand1 is offline
Old 12-12-2010, 08:27 AM
bobflood's Avatar
Mode door is the one that shifts air flow from defrost to vent to floor. It's either right above or right below the heater blend door.
bobflood is offline
Old 12-12-2010, 05:34 PM
lux97Max's Avatar
is it under the driver side kick panel
lux97Max is offline
Old 12-13-2010, 07:24 AM
bobflood's Avatar
You apparently have access to a FSM for the '97 Maxima. Check out page HA-38 - it deals with the HVAC wiring harness, and shows locations for all the various motors. Looks like the mode door motor is behind the center console on the passanger side.
bobflood is offline
Old 12-13-2010, 12:09 PM
lux97Max's Avatar
ok thanks dude, see im trying to do a swap i want to chane my ecc to a newer looking ones that are in the 98s and 99s i have done all the wiring to match up the 99's and 98;s but i need to swap out the air mix motot and air door motor and this project is complete, but i need to figure out if the both of these things will fit. which i need to figure out. any help if you know they will fit
lux97Max is offline
Old 12-13-2010, 12:33 PM
4th Gen Parts King
Maxima_Joe's Avatar
FWIR the motors should be the same for all digital climate controls.
Maxima_Joe is offline
Old 12-13-2010, 12:51 PM
lux97Max's Avatar
are you sure, i dont know man you could be right,
lux97Max is offline
Old 12-13-2010, 01:05 PM
4th Gen Parts King
Maxima_Joe's Avatar
I'm almost sure there the same. It's been several years since I have dealt wth any of this though.
Old 12-13-2010, 01:11 PM
lux97Max's Avatar
can you show me where you read that
lux97Max is offline
Old 12-13-2010, 01:12 PM
lux97Max's Avatar
well see ikm swaping the ecc from 97 to 99
lux97Max is offline
Old 12-13-2010, 01:15 PM
lux97Max's Avatar
the guy who is swaping it from me said i need to swap out the air mix door motor and the air door motor, but i gotta see if the 99 of the two things i listed is compatiable with my 97.
lux97Max is offline
Old 12-13-2010, 01:32 PM
The are more sensors in the 99 ecc as well. Did you get all those swapped over?
Old 12-13-2010, 01:36 PM
4th Gen Parts King
Maxima_Joe's Avatar
lol I didnt read it anywhere. This is from first hand knowledge. Send a PM to vipervadim or something similar to that name. He would know what is needed.
Old 12-13-2010, 02:18 PM
lux97Max's Avatar
yea i got all the wiring matched up and everything i need. all i need to do is swap out 2 lil mootors and im done. ill have the 99 se model withe the amb button in the 97 maxima
lux97Max is offline
Stagnet04
09-02-2015 07:53 AM
kjm900r
08-05-2015 07:14 AM
Quick Reply: does anyone know where the mode door motor is located at on 1999 maxima
