Cant Find Fuse for Cig Lighter... and Im no dummy.
Old 10-03-2010, 03:02 PM
jaysonbr's Avatar
Hi,
I need a little help. Here's the deal.
1. Two Power Outlets in my 2005 Maxima do not work.... the one next to the shifter and the one in the cubby console between the seats.
2. The one near on the passenger side (down by the passengers left foot) does work.
The fuses look OK. Is there something I am missing? This is driving me nuts.
JB
jaysonbr is offline
Old 10-03-2010, 04:18 PM
6.5affiliate's Avatar
Good luck on that one man.......I wouldn't know since I have a 6.5 and for some reason it doesn't even have a cig lighter
6.5affiliate is offline
Old 10-03-2010, 04:24 PM
NYCMAXIMA's Avatar
i had the same problem when i bought mine. go to strauss or auto zone and buy the right type of fuses and just change all three fusesfor the three power outlets. when take the cover off the fuse box next to the steering wheel it should have a label that tells you which fuses are for the power outlets. i think all three fuses have to be good so that they all work cause you gotta close the circuit or something like that. i'm far from an expert but that's what i did and it worked. if you change the fuses and it still wont work there might be somethingwrong with the outlets or the wires. hope this helps. good luck
NYCMAXIMA is offline
Old 10-03-2010, 05:32 PM
BadBlackMaxSL's Avatar
3 power outlets? I'm jealous, I only have 2.
I would have to guess that you need to change all of the outlet fuses and that should be it.
BadBlackMaxSL is offline
Old 10-03-2010, 08:14 PM
SuPeRmOd
NismoMax80's Avatar
i swapped the fuse to the left of the steering wheel when my outlets blew. Use the diagram on the little door. if for some odd reason they all are okay or not there... Another fuse box is under the hood.
NismoMax80 is offline
Old 10-14-2010, 11:25 AM
djyoung's Avatar
oh well just learned something lol.
djyoung is offline
Old 10-17-2010, 07:58 PM
bryantrachi's Avatar
you should have 3 too lol
bryantrachi is offline
Old 10-18-2010, 05:16 AM
SuPeRmOd
NismoMax80's Avatar
not if you have an 04.
figure it out yet? was it a fuse?
Old 10-18-2010, 11:17 AM
BOOTZ's Avatar
What?
I have 2. One next to the aux jack and one in the console under the arm rest.
BOOTZ is offline
Old 10-18-2010, 11:31 AM
SuPeRmOd
NismoMax80's Avatar
Originally Posted by BOOTZ
What?
i think he mean the actual lighter you insert into the "plug" to light cigs?
Old 10-18-2010, 03:15 PM
DAlastDON's Avatar
Check the 15amp fuses #7 and #17 under the dash and 15amp fuse #28 in the fuse box next to the battery.
6.5gen here but alot is the same between the two.
DAlastDON is offline
Old 10-18-2010, 05:22 PM
What?
Don't you have one in the passenger side footwell?
Old 10-20-2010, 03:18 PM
SuPeRmOd
NismoMax80's Avatar
didn't even catch that...
bet he gets all when he realizes after all these years
Old 10-20-2010, 03:49 PM
BOOTZ's Avatar
HAHAHAHA!! I never even looked! Imma check now!
BOOTZ is offline
Old 10-20-2010, 03:53 PM
BOOTZ's Avatar
What is this a game of made you look!?
No outlet there. Must be different on the 6.5 gens.
BOOTZ is offline
Old 10-20-2010, 04:16 PM
Damn, I think they did move ip up next to the shifter in the 6.5 Gen. Sorry Bootz, but....Gotcha!! Made you look!
Old 07-19-2016, 06:24 PM
macakin's Avatar
that's the one
macakin is offline
Violator
09-09-2015 10:14 AM
jwright36
09-08-2015 11:45 AM
Jamie Bowen
09-06-2015 09:59 PM
mikebla
09-03-2015 05:37 PM
Quick Reply: Cant Find Fuse for Cig Lighter... and Im no dummy.
