where is the bank 1 sensor 2? pls see my pictures
Old 08-21-2010, 12:12 PM
kisas's Avatar
I'm sorry to ask the question again, but when I got under the car, I only saw 3 o2 sensors, not 4 as shown in the picture below:
my car is 99 infiniti I30. I only saw 3 sensors:
please point out for me which one is the bank 1 sensor 2? thanks!
1. the one closest to muffler, with white cable
2, the one close to drive axle on passenger side.
3. the one under the driver side
kisas is offline
Old 08-21-2010, 12:43 PM
Whatchyou say?
JtzMax's Avatar
Why did you start another thread? You have a thread asking for help with this issue already.
Fail -----
JtzMax is offline
Old 08-21-2010, 12:50 PM
dgoodhue's Avatar
I went out and looked under my 99 I30 with Cali Emmisions. I have 4 sensors, One sensor can be seen by opening the hood in the exhaust manifold. My exhuast looks like the 01-03 diagram exhaust except I have a pre-cat in the front exhaust manifold. Your exhaust looks different than mine, I wonder if you have the federal exhaust.
dgoodhue is offline
Old 08-21-2010, 01:27 PM
kisas's Avatar
sorry, I thought that question was already answered. already deleted.
Fail -----
kisas is offline
Old 08-21-2010, 01:30 PM
kisas's Avatar
you might be right, when I looked at the emission control tag, I didn't see califorlia, here is the tag:
is this a federal one?
kisas is offline
Old 08-21-2010, 01:34 PM
Kevlo for President
Kevlo911's Avatar
It is the first picture, the one after the cat. This one only checks the cat, it has no bearing on performance.
Kevlo911 is offline
Old 08-21-2010, 01:44 PM
dgoodhue's Avatar
I don't know from that picture. Look at the plate on the Passenger side metal plate on the firewall. The 2nd row of numbers will have either a V (cali) or U (federal) for the emissions code.
dgoodhue is offline
Old 08-21-2010, 01:45 PM
kisas's Avatar
thanks! this one is easy to get to, but the wire seems to go through the floor to somewhere. I read a lot of posts, some say get a plug-and-play, but for this one, I guess the universal one may be the easiest way because you don't have to worry about wiring ??
kisas is offline
Old 08-21-2010, 02:10 PM
kisas's Avatar
this one? I didn't see a V, so i guess this is a federal ?
kisas is offline
Old 08-21-2010, 02:16 PM
Kevlo for President
Kevlo911's Avatar
So how do I tell if my car is Cali or Fed spec?
Raise your hood. Look for a shiny metal identification tag fastened to the passenger side of firewall. The top row is the Vehicle Identification Number, starting with J. The second row is model information. The first five characters are BLHUL. The 12th character is the destination:
N = Canada
V = California
U = US, not California
Yours starts with CL...
Kevlo911 is offline
Old 08-21-2010, 02:19 PM
kisas's Avatar
Thanks for decoding
mine is a federal, got it!
kisas is offline
Old 08-22-2010, 03:58 AM
eddie982's Avatar
Great thread goin on here.... I'm trying to find the O2 sensor locations in my 98 FSM, like the picture posted here, but dunno what page it's on????? Can anyone chime in?
eddie982 is offline
Old 08-22-2010, 06:12 AM
Kevlo for President
Kevlo911's Avatar
Section FE.
Should in the FAQ's as well
Kevlo911 is offline
Old 08-22-2010, 07:04 AM
eddie982's Avatar
Thanks, needed to know so i can put in the two new denso O2 sensors i bought.. no CEL, just doing maintenance, i wonder if there will be a noticeable difference in performance?
eddie982 is offline
Old 09-03-2010, 04:21 PM
pjgreek's Avatar
Just to be clear, bank 1 sensor 2 is between the 3-way cat and the rear exhaust tube assembly as shown on page FE-4 of the 1999 FSM????
I need to get my car inspected this month and the CEL just came on. Autozone pulled codes P0138 and P0139 which is this sensor (I hope).
pjgreek is offline
Old 09-07-2010, 04:56 PM
pjgreek's Avatar
Anyone?
pjgreek is offline
Old 09-07-2010, 05:12 PM
Trini Boom's Avatar
Yes, that's the correct sensor. Get it replaced and be careful of tightening..
Trini Boom is offline
Old 09-07-2010, 05:16 PM
atriuum's Avatar
Those two codes are for the rear 02 sensor, which you can reach with your hand from under the driver's side door of your car. It's on the exhaust, you can't miss it.
atriuum is offline
Old 09-09-2010, 05:43 PM
pjgreek's Avatar
Thanks for the help Trini and atriuum.
Paul
pjgreek is offline
Old 09-09-2010, 06:04 PM
supergondi's Avatar
oh that sensor on the top behind the cat no fun on a 12 year old ny car i sheared off the entire hex with my o2 socket and i used alot of lube and a lot of heat oh well good think the sides of that pipe are flat, drill bit and tap worked awesome and now i have more tools! if anyone needs to know the tap size and drill bit send me a shout
supergondi is offline
220k+ A32
09-11-2015 02:18 AM
Quick Reply: where is the bank 1 sensor 2? pls see my pictures
