Do I need an alignment after net end-links?
Old 08-16-2010, 03:28 PM
jgilbs's Avatar
So I am new to suspension work(have done nearly every other repair on the car). I just ordered new motor mounts with new bushings, and I figured while I am ordering from ES, might as well order some end links and sway bar bushings to help tighten up my front end. If I replace the end links and bushings, will I need an alignment after? I ask, because I also want to put on new shocks, and if I need to get an alignment after each thing, might as well do them all at once, and get one alignment as opposed to multiple ones. Will this be necessary? Or do endlinks not affect the alignment?
jgilbs is offline
Old 08-16-2010, 03:31 PM
2slow's Avatar
No.
2slow is offline
Old 08-17-2010, 06:36 AM
BlackMacks's Avatar
Originally Posted by 2slow
No.
My name is Chuck, and I approve this message.
BlackMacks is offline
Old 08-17-2010, 10:30 AM
ghostrider17's Avatar
Agreed with above.
But if you WERE to replace separate components like struts and TIERODS on separate occasions, u could simply buy a 2/3yr or LIFETIME alignment, for not too much more $$$ than a one-time alignment.
Just a suggestion.
gr
ghostrider17 is offline
Old 08-17-2010, 11:51 AM
yogi's Avatar
yogi is offline
Old 08-17-2010, 07:17 PM
CMax03's Avatar
No........but, if you like giving away your money yes!
CMax03 is offline
JoshG
09-16-2015 08:56 PM
bbsitum
09-11-2015 04:55 PM
adamgalazka
09-09-2015 03:39 PM
Quick Reply: Do I need an alignment after net end-links?
