Oil Leak = Oil Pressure Sending Unit
Old 12-14-2001, 03:12 PM
dko
duck and cover
dko's Avatar
Recently I noticed little oil stains on my driveway and decided to have the car checked out. I just came back from Fergus Nissan, they said it was the Oil Pressure send unit. They replaced it under extended waranty +$50 for labor, etc. Is this a decent price and could it really have been the oil-presdure sending unit?
Thanks in advance.
dko is offline
Old 12-14-2001, 03:16 PM
I'm needing a caw
Jeff92se's Avatar
Ah what kind of warranty is that? Should be free
Search the stickies if you want more information on the procedure and how long it takes.
Dealers usually charge anywhere from $50-$75 per hour.
Jeff92se is offline
Old 12-14-2001, 03:27 PM
dko
duck and cover
dko's Avatar
Was it likely that it solved the problem?
dko is offline
Old 12-14-2001, 03:29 PM
I'm needing a caw
Jeff92se's Avatar
Does it leak?
Jeff92se is offline
Old 12-14-2001, 03:33 PM
dko
duck and cover
dko's Avatar
Originally posted by Jeff92se
Does it leak?
they didn't say anything about whether it leaked or not but if it did the problem is likely fixed. just wanted to be sure, you know...
thanks jeff
dko is offline
Old 12-14-2001, 04:06 PM
ericdwong's Avatar
I also have this problem, amongst my many problems of this car. I read in the FAQs that the nissan OEM unit should be avoided, unless covered under warranty... Since my car is busted again I guess I could replace this guy too...
ericdwong is offline
Old 12-14-2001, 04:24 PM
Eric L.'s Avatar
Yeah the oil pressure sending unit is problematic on 4th gens. Mine leaked at approx 22,000 miles and was replaced under warranty.
Eric L. is offline
Old 12-14-2001, 07:49 PM
dko
duck and cover
dko's Avatar
looking over the work order again, it does say that the sender unit was leaking...
oh, btw... i just put on my FSTB... WEEEEEEEEEEEEEEEEEEE!
dko is offline
Old 12-14-2001, 08:59 PM
Ad·min·is·tra·tor
DanNY's Avatar
YES!! the maxima is a POS!! sell right now!
quite your b1tching..you're complaining to the wrong people. go send a letter to nissan.
don't make me look up TSBs for hondas and toyotas.
DanNY is offline
Old 12-15-2001, 04:09 AM
Micah95GLE's Avatar
Re: Oil Leak = Oil Pressure Sending Unit
Thanks in advance.
That was probably the culprit. I replaced mine at about 90K miles.
Micah95GLE is offline
Old 12-15-2001, 08:37 AM
ericdwong's Avatar
What did I say in that thread that made it sound like I was complaining at all? And yes, the maxima is a POS
Old 12-15-2001, 01:47 PM
2DMax's Avatar
Had my sending unit replaced too.....
2DMax is offline
Old 12-15-2001, 01:49 PM
Rooster286's Avatar
I had the same problem when I had a Camry, At about 75,000 miles, the unit went, well.....it BLEW up. I thought I blew the engine actually....pulled up to a stop light, and THICK white smoke started pouring from my car When the switch went, it sprayed oil allover the engine, which was hot from driving and damn near gave me a heartattack, it was about a 5 minutes repair job on that though, and the OPU was like 20.00....I dunno if it's that easy on the max though...mine hasn't gone yet.
Rooster286 is offline
Old 12-15-2001, 02:19 PM
SLOW
Nealoc187's Avatar
I replaced mine last month. Cost me $50 with an oil change thrown in. Took them about 10 minutes.
Nealoc187 is offline
Old 12-16-2001, 12:14 AM
tmax's Avatar
I had the same problem and the dealer replaced the oil pressure sensing switch. However, the problem reoccurred. This time the dealer replaced the PCV unit. Apparently it was stuck. I did notice a big jump in gas milage after it was replaced, so I think that's it. I'm taking it in for a checkup this week.
TMAX
tmax is offline
9aj9
04-05-2020 12:11 AM
kjlouis
10-03-2015 05:29 AM
cruce91
09-20-2015 10:23 AM
ag90fox
09-09-2015 12:22 PM
Quick Reply: Oil Leak = Oil Pressure Sending Unit
