New Duralast Gold brake pads and they squeak!
Old 07-30-2010, 12:52 AM
zcar@hotmail.com's Avatar
I replaced my brakes on my 03 Maxima at 35K miles for the first time. I took it to the local cheap repair shop and they turned the rotors and replaced all the pads with Duralast Gold (NOT Cmax) pads.
When braking lightly at speeds normally above 40MPH, they squeak!. If you brake hard they don't squeak or if braking at low speeds.
The shop has replaced the pads both front and rear already, and the new pads still squeak exactly the same. I should mention there is nothing wrong with the braking or how the brakes feel. They feel just fine and brake just fine. It's just the damn annoying squeak! Sounds more from the front than the rear, but I could be wrong.
Can anyone help? Maybe a shim problem or something? Anyone else have this happen?
Any suggestions before I go back to the shop and complain again? What is reasonable to ask the shop to do to fix this?
Thank you!
zcar@hotmail.com is offline
Old 07-30-2010, 01:26 AM
Chocolate_Boi_1Der
Cant_Get_Ryte's Avatar
Sounds like they didn't lube the back of the pads with graphite gel. All moving parts should get a generous application when changing. It's cheap.
Cant_Get_Ryte is offline
Old 07-30-2010, 01:38 AM
Gram Lights addict
QT1 5MT AE's Avatar
lube the hardware.......
QT1 5MT AE is offline
Old 07-30-2010, 01:52 AM
BronxSleeperMax187's Avatar
I got the same crappy pads sometimes they sqeek sometimes its gone but free for life
BronxSleeperMax187 is offline
Old 07-30-2010, 02:24 AM
RLW001's Avatar
IMHO - Brakes and Tires are areas where you should not go cheap.
RLW001 is offline
Old 07-30-2010, 07:54 AM
Wildcat_Max's Avatar
I'm not expert but did you had a chance to bleed the brakes after installation ?
Wildcat_Max is offline
Old 07-30-2010, 08:11 AM
luvlexus101's Avatar
Hawk pads ftw?
luvlexus101 is offline
Old 07-30-2010, 11:17 AM
Chocolate_Boi_1Der
again. as stated by us. this is your issue. hawks would/could do the same if not lubed.
Old 07-30-2010, 11:21 AM
perkman87's Avatar
first issue Dur-a-last"
perkman87 is offline
Old 07-30-2010, 12:39 PM
Demodded and Forgotten
rroderiques77's Avatar
that
rroderiques77 is offline
Old 07-30-2010, 02:47 PM
I looked at the pads are there are globs of purple lube between the shims and the caiipers already so I don't know if that's the problem.
Also, anyone use Duralast Gold CMAX pads with the rubberized shims? And if so, do they have the same problem as the standard Duralast Gold pads?
Old 07-30-2010, 04:03 PM
Cletus
SoonerFan's Avatar
cheap pads + not enough lube + not properly beding them in
SoonerFan is offline
Old 07-30-2010, 10:10 PM
DennisMik's Avatar
Remove the brake pads and 'break the glaze' on them. Take a piece of 100 grit sandpaper, lay it on a flat surface and sand the brake pad to remove the glossy look. then sand the 90 degree edges down, especially the leading edges (the edge towards the front of the car. After you re-assemble the brakes and are driving the car, do nice easy, gentle stops for the first maybe 10 times.
DennisMik is offline
Old 07-30-2010, 10:25 PM
mendezrj03max's Avatar
OEM FTW!
mendezrj03max is offline
Old 07-30-2010, 10:58 PM
I appreciate the suggestion. However, I paid to have my brakes done and not going to fix their problem myself. I am mainly looking for the cause and solution to take back to the shop on what's wrong and how to fix it since they don't seem to know how to.
Old 07-30-2010, 11:15 PM
cheap pads = no need to bed them in.
BPuff57
04-16-2020 05:15 AM
NmexMAX
05-23-2016 07:38 PM
leatherneck
09-30-2015 09:16 PM
HerpDerp1919
09-29-2015 02:02 PM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: New Duralast Gold brake pads and they squeak!
