Low Battery or Something Else?
Old 06-26-2010, 09:31 PM
HoustonMaxima's Avatar
Hey guys, wanted to run a couple things by you and see if you came up with the same conclusion I did.
I have an '07 Maxima, stock, 46k miles on it. I have only replaced the front brakes and all tires, nothing electrical/under the hood. In the past 1-2 weeks it feels like it's struggling to start and has gotten consistently harder to. It has always started on the first try but went from right away to 1 second to about 2 seconds tonight. The instrument panel lights get very dim when it's cranking and the headlights don't get fully bright until about 5 seconds after the engine's running. The crank is really really slow and eventually the engine turns over. Once everything's running, the car acts like nothing's ever wrong -- no dash lights, no performance hit, no electrical problems...JUST starting the engine.
It's getting harder to start every day, and I was convinced tonight we were going to get stranded on the town.
I remember PetitFrereMaxima telling me at the last Houston meetup that the stock batteries are notorious for going bad, and I think my battery's serial number was in the range he mentioned of being bad/faulty. (The battery in there now is the factory battery, made in second half of 2006, so 3.5 years old.)
Is this a dying battery or something else? The battery fluid levels are right on target and the connections are secure. Could the belts be loose and not fully charging the battery? Could it be the alternator or another part?
Any/all help is appreciated; thanks in advance!
HoustonMaxima is offline
Old 06-26-2010, 09:33 PM
NiZMo1o1's Avatar
replace the battery !
NiZMo1o1 is offline
Old 06-28-2010, 01:19 PM
the macedonian's Avatar
+1 w/ Nizmo -> changed my battery to the optima redtop and difference is night and day bro
the macedonian is offline
Old 06-28-2010, 01:22 PM
New battery did it...got a 750 CCA DuraLast Gold, starts up just like a brand new car. Thanks for the help everyone.
Old 07-11-2010, 03:09 PM
dash10299's Avatar
Definitely a battery issue
dash10299 is offline
Old 07-13-2010, 07:24 PM
6.5affiliate's Avatar
The same happened to me until the car freaking died. Coincidentally, I have an 07 too and the battery died at about the same mileage that you have.
6.5affiliate is offline
Old 07-14-2010, 08:56 AM
JD05's Avatar
Mine did the same thing last week then wouldnt start i went to a auto parts place put the new battery in and now its back to normal, starts good. I got 61000 miles out of my battery.
JD05 is offline
Old 07-14-2010, 02:53 PM
Lovemycar's Avatar
That's so funny I Have 2004 48K stock battary works great
Lovemycar is offline
gigabyte
01-06-2017 06:05 PM
bigfrank
10-01-2015 12:51 PM
Quick Reply: Low Battery or Something Else?
