Loud Humming Noise while driving: Please Help
Old 05-09-2010, 04:55 PM
foreeyed's Avatar
Hello everyone,
When driving above 40 MPH, the inside of my car gets really loud. It kind of sounds like a humming noise. The sounds softens as soon as I brake. I thought it was due to old tires, however I just got nice new ones and the noise remains. Has this happened to anyone else? What could the causes be?
I have a 2004 Maxima with almost 100k miles
Thanks,
K
foreeyed is offline
Old 05-09-2010, 05:16 PM
gordonych's Avatar
sounds like wheel bearing(s) is toasted
gordonych is offline
Old 05-09-2010, 05:22 PM
potato's Avatar
^ agreed
potato is offline
Old 05-09-2010, 06:30 PM
foreeyed's Avatar
Thanks for the quick reply. How do I confirm it's the problem? Im hesitant to take it to the dealer as they will surly tell me there are other things that need to be fixed
foreeyed is offline
Old 05-09-2010, 07:43 PM
04vqmaxsl's Avatar
Check to see if the noise goes away when you are making long sweeping curves.
Let's say you're making a right hand sweeping turn. The inside front wheel
(right) should not make any noise if the bearing is bad because there is less pressure on that wheel. The same goes for the left if making a sweeping left turn.
This should tell you if a wheel bearing is bad as well as which one.
04vqmaxsl is offline
Old 05-09-2010, 09:15 PM
foreeyed's Avatar
Thank you again. If it's not the wheel bearing, what other causes could it be?
foreeyed is offline
Old 05-09-2010, 09:55 PM
NiZMo1o1's Avatar
Jack your car up one side at a time, secure on jack stands
Shake the wheels from Left to Right 3pm - 9pm ... if theres play , its tie rods
Shake the tires 12 o' clock - 6 o' clock , if theres play , its wheel bearings.
Spin the wheel in motion to hear or feel any viberations.
This will tell if you what needs to be replaced ,
Just for checks make sure the rotation of your tires are correct as well.
NiZMo1o1 is offline
Old 05-10-2010, 01:02 PM
Lovemycar's Avatar
wheel bearing
Lovemycar is offline
Old 05-10-2010, 07:27 PM
randman05's Avatar
Had the Right front go out on mine at 60K miles...lucky me, it was still under warranty..Wondering about the left front now...
randman05 is offline
Old 05-12-2010, 02:30 PM
JD05's Avatar
I just recently had my rear wheel bearing go bad and it was a humming sound the dealer replaced it and it went away.
JD05 is offline
Old 05-12-2010, 04:53 PM
Redstone's Avatar
Definitely sounds like a wheel bearing going bad to me.
Redstone is offline
Old 05-13-2010, 03:57 PM
BzJeep's Avatar
Dang, I have the same humming/vibration around 40MPH (not present above or below that speed).
However, I tried shaking the wheels back and forth when I replaced my struts and there was no play either way... any ideas?
BzJeep is offline
Old 05-13-2010, 06:09 PM
Scott D.'s Avatar
Check your trunk for midgets.
Scott D. is offline
Old 05-16-2010, 02:17 PM
2k1AEMaxRider's Avatar
Are the wheel bearings on the 04's pressed in or can they be replaced at home?
2k1AEMaxRider is offline
Old 05-28-2010, 05:31 PM
Rods03Max619's Avatar
Nice to know!!
Rods03Max619 is offline
Old 07-14-2010, 09:56 AM
Mighty Mouse's Avatar
i'm sure the 04's are no different from the 05's. I purchased one from o'reilly's and had it pressed at carquest. the rest i did it in my garage.
Mighty Mouse is offline
Old 07-14-2010, 05:58 PM
LucKie1nE's Avatar
I purchased my ryde @ 15K miles.. @ roughly 20-25K miles, I had my front RH wheel bearing replaced.. @ 30-45K miles, the front LH went bad but Nissan insisted that they replace both front LH and RH again.. Now, @ 50K miles.. My front RH neeeds to be replaced again.. I think Nissan has a problem with their wheel bearings..
LucKie1nE is offline
hcarter1112
42
07-18-2022 03:35 PM
D Mason
06-21-2016 04:43 AM
uttadms31
09-30-2015 05:24 AM
Kyle Lee Cleveland
09-28-2015 07:58 AM
Quick Reply: Loud Humming Noise while driving: Please Help
