hole in flex pipe?
Old 03-11-2010, 07:31 PM
missexclusive99's Avatar
hole in flex pipe?
i need to have my flex pipe replaced. my mechanics price is $200 for him to get me one and install it. my brother is telling me i should just get a warpspeed stainless steel y pipe because it wont rust but i have no intention on doing anything to my car like that. my mechanic told me that its a bad idea but i dont know if hes just saying that to get the job. what should i do? is it easy to just go to a junk yard and get one and have my brother (who has the same car and works on his all the time) install it or would i need a mechanic to put it in? let me know your thoughts
missexclusive99 is offline
Old 03-11-2010, 07:38 PM
scmaxima's Avatar
junkyard should do it for about 65 bucks..
thats how much i did mine it took like 20 mins and he even used the tall one that supports more back pressure =]
scmaxima is offline
Old 03-11-2010, 07:39 PM
wait the junk yard installed it for you? ohh well id definitely rather do that and save a lot of money lol
scmaxima's Avatar
oh and you live in NY..
just go to the one by citi field or anything thats closer to you.
good luck
scmaxima is offline
Old 03-11-2010, 08:56 PM
maxx0831's Avatar
I would suggest you get a warpspeed ypipe, I just got mine installed last week and its great..you should check out nycmaximas.org
maxx0831 is offline
Old 03-12-2010, 02:31 PM
defiance's Avatar
yup install of cutting and welding in a new flex pipe just get a new ypipe.
you will replace the flex pipe in the process and gain some power too.
You may even get of few MPG out of the deal
defiance is offline
Old 03-12-2010, 07:10 PM
Goomz's Avatar
since you have no intention of aftermarket parts, flex pipes are easily replaceable but i dunno how much a junkyard would charge you...might be a lot for labor.
Goomz is offline
Old 03-17-2010, 09:07 PM
Well my mechanic had said that if I do get that ypipe I could run into some problems and that I should just keep it stock bc something won't read correctly? Or something like that.. but if its not gonna cause problems then ill just save to get the stainless steel ypipe bc it won't rust....how much do you think it wiwill cost to be installed?
Old 03-19-2010, 08:21 PM
EsQueue's Avatar
Unless you have a cali spec car then your mechanic is full of **** and I would go somewhere else. Do you have a oxygen sensor after the main catalytic converter under the car? If yes then go to another mechanic.
EsQueue is offline
Old 03-19-2010, 08:24 PM
scmaxima's Avatar
dont worry i realized that those mechanics dont know ****..
and no just get a y-pipe.. cheapest that you can find, it adds a lot of power, and will solve your flex pipe, and adds a nice tone
besides you can even do it yourself without any welding cause all youre gonna do is remove the old one and replace it with the new pipe =]
gl
scmaxima is offline
Old 03-20-2010, 04:58 PM
Well after reading all your responses I'm gonna go with the ypipe....thanks a lot for taking the time to answer everyone
Old 11-21-2012, 07:08 AM
ik95's Avatar
Guys- quick questions on this. Will y-pipe give of a loud muffler sound?
ik95 is offline
Old 11-21-2012, 07:18 AM
ShocknAwe's Avatar
no
ShocknAwe is offline
Old 11-21-2012, 07:58 AM
AoD11's Avatar
It will still be silenced by your muffler and resonator it's just less restrictive, it will be louder than stock (unless you're already leaking)
AoD11 is offline
Old 11-21-2012, 08:43 AM
GGENIUS's Avatar
no
what you mean no? ypipe makes it louder than stock by a noticeable amount.
GGENIUS is offline
Old 09-14-2013, 12:33 PM
99zx2's Avatar
Didn't want to create a new thread. Will this affect anything? The ring is broken, but the inside pipe seems intact.
99zx2 is offline
Old 09-14-2013, 12:51 PM
deathwobble's Avatar
When it leaks then fix it. Till then its fine
deathwobble is offline
Old 09-15-2013, 03:55 PM
gruesome's Avatar
My original one somehow collapsed into itself. Not sure off that is the best term for it, but there was steel mesh inside that flex pipe for some reason, The precat went and it did the rest of the job clogging the exhaust so the car basically limped like it was down 5 cylinders.
gruesome is offline
Old 09-15-2013, 09:24 PM
defiance's Avatar
It may be a little louder then stock but it shoudnt be a huge issue. Replace the ypipe or flexpipe when you can
defiance is offline
Old 09-16-2013, 04:04 PM
99zx2's Avatar
Doesn't leak as far as I could tell - no noise and no air coming out under idle or revving it up. Let it chill until the damage becomes obvious. Thanks, guys!
99zx2 is offline
Old 09-17-2013, 02:28 PM
svezarov's Avatar
I had mine in that state about 2-3 years ago and it is just starting to show signs of "leakage". So don't bother doing anything to an exhaust pipe until you have to. The exhaust only gets worst with the time.
svezarov is offline
aw11power
10-10-2021 04:57 AM
Quickywd01
09-21-2016 09:36 PM
uttadms31
09-30-2015 05:24 AM
DC_Juggernaut
09-28-2015 04:07 PM
Quick Reply: hole in flex pipe?
