Front Motor Mount Removal Tips
Old 07-20-2009, 03:30 AM
magic_max's Avatar
I have a AUTO, and I'm preparing to remove my front motor mount so I can drop the cross member. After reading through the other posts, most say to remove the single bolt through the rubber piece but mine has a wire attached to it (liquid filled?) and wanted to know what the best way to remove the cross member/mount.
Grey wire attached to front motor mount.
Appreciate any tips/suggestions.
Thanks!
magic_max is offline
Old 07-20-2009, 09:40 AM
MOHFpro90's Avatar
Thats for the electronically controlled mount. Other than that, sorry I cant help.
MOHFpro90 is offline
Old 07-20-2009, 10:26 AM
No more Maximas...
pmohr's Avatar
Unplug that wire.
Remove all 3 bolts and nuts, wiggle mount out. Simple as that.
The auto being larger is a bit more of a PITA to wiggle around to get out, but there's no need to drop or lower the crossmember in any way.
pmohr is offline
Old 07-20-2009, 05:25 PM
magic_max's Avatar
Cross Member Removal
Originally Posted by pmohr
Unplug that wire.
I realize that my title and question focuses solely on removing the motor mount. This post is actually related to my oil leak post (http://forums.maxima.org/4th-generat...-oil-leak.html). So what I actually want to do is remove the cross member so I can remove the upper oil pan, but most of the post don't mention the wire on the mount so that kind of threw me off. I'll follow the grey wire up and unplug it.
So just removing the single nut and bolt through the rubber part is ok and drop the cross member with the mount on?
Thanks!!
Old 07-20-2009, 05:29 PM
No more Maximas...
pmohr's Avatar
Correct.
pmohr is offline
Old 07-20-2009, 05:33 PM
f550maranello2's Avatar
Thanks!!
first and for most make sure you are supporting the transmission and engine with something sturdy... because if the engine sinks you are gonna have a nice time trying to align the bolts back to the radiator support
and yes you are correct....you need to remove just the pin that goes through the center of the mount to the engine and rock the whole thing back and forth...
also replace the rear main seal at the same time...
f550maranello2 is offline
Old 07-20-2009, 05:35 PM
No more Maximas...
pmohr's Avatar
There is no need to support the engine or trans, the side mounts will hold everything up just fine.
How would he replace the RMS without removing the trans?
pmohr is offline
Old 07-20-2009, 05:40 PM
yea the side mounts will cause it to sink and shift been there done that
the bottom moon shaped part since it that is what leaks... wrong choice of words....
Old 07-20-2009, 05:42 PM
No more Maximas...
pmohr's Avatar
Sink and shift meaning? Sure, the engine is going to move around a bit with the crossmember off, but it won't cause any sort of issues.
pmohr is offline
Old 07-20-2009, 05:46 PM
it will when he tries to put the cross member back on and the bolts to the radiator support dont align.. besides you dont want all that weight resting on 2 mounts like that
Old 07-20-2009, 05:48 PM
No more Maximas...
pmohr's Avatar
As before, there's nothing wrong with letting it rest on those two mounts. Operating it with the crossmember removed? Of course. But as long as it's stationary, you won't run into any issues.
And as long as you do the rear mount first and get that bolt started, all you have to do is swing it up to reach the radiator support. I've never had an issue with that, across several Maximas.
pmohr is offline
Old 07-20-2009, 05:55 PM
iv done 3 thus far 1 was on my car other 2 were on my friends with the same results... so have fun i guess..
Old 07-20-2009, 09:03 PM
96nismoSE's Avatar
u cant win! let pmohr share his knowledge!
96nismoSE is offline
Old 07-21-2009, 02:48 AM
magic_max's Avatar
Thanks for all the help guys.
vingodine
45
05-21-2016 12:46 PM
homeyclaus
09-03-2015 06:15 PM
Rage Maximus
09-03-2015 12:26 PM
george__
08-18-2015 07:06 PM
Greenmaxspeed
08-08-2015 12:39 PM
Quick Reply: Front Motor Mount Removal Tips
