where is fuel pump relay
Old 06-24-2009, 04:16 AM
edwardh1's Avatar
I have read posts that it is under dash on drivers side, but is it
-in the area just forward of the door seam? (if yes, how do you get that kick panel off) and if no,
-is it nearer the steering column??
99 maxima
edwardh1 is offline
Old 06-24-2009, 10:28 AM
96i30azn's Avatar
you mean fuse? that fuse box is right above your left knee sitting in the car. you pull the lid off with your bare monkey paws. i believe you can find a diagram in your owner's manual
96i30azn is offline
Old 06-24-2009, 10:45 AM
Sierra Foxtrot's Avatar
Is there another method to cut of the fuel pump relay other than pulling the fuse, say, a button?
Sierra Foxtrot is offline
Old 06-24-2009, 11:10 AM
edwardh1's Avatar
Thanks but no not the fuse- the fuel pump RELAY that cuts on the fuel pump
edwardh1 is offline
Old 06-24-2009, 03:37 PM
fat_kid's Avatar
why would you need a button?
just remove the fuel pump fuse and viola no gas goes to the engine
fat_kid is offline
Old 06-24-2009, 05:06 PM
edwardh1's Avatar
I want to change out the fuel pump relay- where is it??
edwardh1 is offline
Old 06-24-2009, 05:15 PM
90blkteg's Avatar
Maybe you meant to say " Main Relay "?
90blkteg is offline
Old 06-24-2009, 05:19 PM
90blkteg's Avatar
Ok I don't know if this will help but on the 95 Q45 the main relay is under the hood
90blkteg is offline
Old 06-24-2009, 05:21 PM
90blkteg's Avatar
Look on the passenger side right next to the strut tower it might be there
90blkteg is offline
Old 06-24-2009, 05:29 PM
ATTappman's Avatar
99 maxima
Just forward of the driver's side door. Never taken the kick panel off myself, but it probably just pries off, held on by a couple of metal clips.
ATTappman is offline
Old 06-24-2009, 05:33 PM
90blkteg's Avatar
Look in the driver's side kick panel. There is a small box it says ABS control unit, there are two small relays with it the relay closest to the rear of the car is the fuel pump relay
90blkteg is offline
Old 06-24-2009, 05:35 PM
90blkteg's Avatar
the kick panel pops off you might have to usr a screw driver to help out if it has never been taken off before
90blkteg is offline
Old 06-24-2009, 05:46 PM
edwardh1's Avatar
the kick panel does come off but the relays are not attacked to the box inside the kick panel.
you can see 3 blue square things (the relays?) if you open the fuse panel door which is above the drivers left knee, and next to the steering column. How you GET TO the three relays, and which one is the fuel pump relay is my question. do you pull off part of the lower instrument panel cover, the part above the drivers knees? which my sony camera had not cratered
and the auto zone says different ones for Niles miyamoto or jideco equipped- whats that- mafg of the OEM relay?
edwardh1 is offline
Old 06-24-2009, 07:29 PM
Nopike's Avatar
The ABS control unit, sunroof relay and the fuel pump relay are behind the drivers side kick panel near where you would keep your left foot. it is not in the area above your knee. It appears the two relays may be hidden behind the ABS control unit that is why you don't see them. Why do you suspect this relay is causing a problem?
Nopike is offline
Old 07-07-2009, 05:06 PM
burgundyblues66's Avatar
i dont see it down there at all, i took off the kick panel and there is just the abs box that looks rather difficult to take off. is the relay supposed to be behing there?? and what are the 3 relays higher up next to the knee then?
burgundyblues66 is offline
Old 07-07-2009, 06:10 PM
No more Maximas...
pmohr's Avatar
Do you not believe the fuel pump relay is behind the ABS control unit?
For those three:
pmohr is offline
jmlee44
10-02-2022 02:13 PM
Miket2006
03-01-2021 03:55 AM
salty318
09-29-2015 01:21 PM
salty318
09-28-2015 07:22 PM
Quick Reply: where is fuel pump relay
