"HOW TO" remove fog lights on '96-'99 I30
Old 05-01-2009, 10:06 PM
speed3000gt's Avatar
Can somebody tell me how to remove the fog lamps on the '96+ I30? I've removed the underneath sheilds and cant find the screws/bolts holding the fog lamp in place.... Is there a how to on this somewhere?
speed3000gt is offline
Old 05-02-2009, 09:42 AM
Just the tip.
JNCoRacer's Avatar
There should be a bolt holding the corner fog on. Then you should be able to access the bolts holding on the fogs themselves IIRC.
JNCoRacer is offline
Old 05-07-2009, 12:56 PM
DCP
DCP's Avatar
there is a 10mm bolt holding the corner lamp on, that needs to be accessed from under the car. Once the Corner lamp is removed you will see another 10mm bolt facing toward the front of the car. Remove this bolt, and the foglight will pull out.
DCP is offline
Old 05-11-2009, 11:31 AM
FFxI30's Avatar
After removing the 10mm bolt holding the corner lamp (mine's broken because the body shop put it in crooked and used cheap bolts which are all rusted and broke as soon as I put a socket on it!!), the corner lamp needs to be "popped out" from the front of the car. I use a screwdriver to get between the corner light and the fog light and it popped right out with just a little pressure.
FFxI30 is offline
Old 05-19-2009, 05:19 PM
thanks guys
Old 06-15-2009, 02:33 PM
my98i30's Avatar
What is the purpose of the corner part? Is there a bulb inside? I just got the car and haven't had time to look under/around but it seems useless if looking at the car from the front. Please help me out here.
my98i30 is offline
Old 06-15-2009, 03:37 PM
Navara330's Avatar
If its anything like me 01 i30 its a a turning light that goes on with the turn signal.
Navara330 is offline
Old 06-15-2009, 05:37 PM
adamsanders's Avatar
Yep, that's what it does.
adamsanders is offline
Old 06-16-2009, 09:50 AM
my98i30's Avatar
Thanks. One last question. Is it white? I don't know if I called it the right thing last time. I am talking about the piece right next to the fog light. It's pointed kind of at 45 degrees. I didn't see a colored bulb or anything and thought it would be weird to have a white turning light. If I called it the wrong thing last time, I apologize. What would this piece be for?
my98i30 is offline
Old 06-16-2009, 11:59 AM
defiance's Avatar
Its a turning light that goes on when you flip on the turn signal.
Maximas have the same thing but there's have a more integrated look
to them and are higher up. If the bulb is blown in it it wont light up for that
side...
defiance is offline
defiance's Avatar
and yes it is white
defiance is offline
Old 06-16-2009, 12:54 PM
my98i30's Avatar
Thanks. Yeah, the Maxima's look like it belongs. This just looks like an extra piece of glass they threw in cause they thought it looked cool. I'll check bulbs tonight. Thanks again.
my98i30 is offline
Old 06-17-2009, 01:27 PM
my98i30's Avatar
Are there other headlights that fit the a32 other than the cefiro? This could be from other infinitis, nissans, acuras, whatever.
my98i30 is offline
mvm062
11-30-2020 09:00 AM
MaxLife17
09-08-2015 02:36 PM
A32goldylocks
09-02-2015 06:39 AM
umnitza
09-01-2015 01:03 PM
Viralkill
08-16-2015 05:09 PM
Quick Reply: "HOW TO" remove fog lights on '96-'99 I30
