How can I tell If I have a locking or open diff.
Old 04-14-2009, 04:36 PM
vqmaxman's Avatar
I want to know If I have an locking diff or a non-locking diff. I have this
tranny code here: RE4FO4A. I am sure I haev an non-locking but I want to
confirm beofre I do anything else. Thanks
vqmaxman is offline
Old 04-14-2009, 04:43 PM
¯\(°_o)/¯
Greeny's Avatar
Open(non-locking) differential....The "A" is key..
Greeny is offline
Old 04-14-2009, 04:45 PM
vqmaxman's Avatar
so i was right thanks dude.
vqmaxman is offline
Old 04-14-2009, 09:01 PM
Max-e-MO!'s Avatar
What letter designates for Locking?
Max-e-MO! is offline
Old 04-14-2009, 09:04 PM
NISSANMAXIMA91's Avatar
"V" for "VLSD"
NISSANMAXIMA91 is offline
Old 04-14-2009, 09:36 PM
No more Maximas...
pmohr's Avatar
Indeed.
A == Open
V == VLSD
H == HLSD
pmohr is offline
Old 04-15-2009, 09:08 PM
Max-e-MO!'s Avatar
What the in the "Sam Hill" is a HLSD?? Never heard or seen that trans in this web site...
Old 04-15-2009, 09:15 PM
No more Maximas...
pmohr's Avatar
HLSD == Helical Limited Slip Differential.
Basically it uses gears to assure torque transfer instead of a viscous coupling, such as found in the 4th and 5th gen VLSD 5MT (RS5F50V).
There was never an HLSD trans available for the A32, only A33B-A34 6MT, the RS6F51H.
Here's what the diff looks like, notice all of the extra worm gears along the top and bottom:
Some reading: http://en.wikipedia.org/wiki/Limited...rque-sensitive (overview) and http://en.wikipedia.org/wiki/Limited...e_differential (more in depth)
pmohr is offline
Old 04-16-2009, 05:02 AM
Max-e-MO!'s Avatar
pmohr,
Whoever you work for, they are NOT paying you enough, at least not for the knowledge that you have....wow, I'm truly impressed.
Old 04-16-2009, 06:03 AM
No more Maximas...
pmohr's Avatar
pmohr,
Not working right now, so definitely not making enough, heh.
pmohr is offline
Old 04-16-2009, 06:37 AM
mightyMax95's Avatar
pmohr,
quite so. i think he was a nissan engineer in a past life.
mightyMax95 is offline
Old 04-16-2009, 06:50 AM
No more Maximas...
pmohr's Avatar
I sure hope I wasn't the one who designed the placement of the KS, or I'll have to kick my own ***.
pmohr is offline
Old 04-16-2009, 07:03 AM
¯\(°_o)/¯
Greeny's Avatar
Actually, the ks is mounted in the best place to listen for knock, the failure imo is in the k/s design, the engineers/manufacturer of the k/s failed in making the part out of substandard plastic. I've seen several(including my own) k/s on the ve30de engine where the k/s was literally melted down into a indistinguishable heap of plastic from heat damage.
BTW, the VE30DE k/s is the same part# as the 4th gen VQ k/s.. and is mounted in the same place..
Greeny is offline
Old 04-16-2009, 07:04 AM
No more Maximas...
pmohr's Avatar
Yep, seen a few of those myself, nice and melted.
Well it's not so much the KS placement I was complaining about, just the procedure to get to it.
Then again, if I designed the car, everything would be held in place with latches and V-bands, heh.
pmohr is offline
Old 04-16-2009, 07:17 AM
Max-e-MO!'s Avatar
LOLOLOLOL, sorry just couldn't help myself, thought everyone would appreciate the "laughture"
Old 04-16-2009, 07:22 AM
Coolsaber57's Avatar
Sure is a lot of nut-swinging around hurr...
Coolsaber57 is offline
Old 04-16-2009, 08:36 AM
Kevlo for President
Kevlo911's Avatar
In the stickies with details
Kevlo911 is offline
Miket2006
03-01-2021 03:55 AM
howardis
12-11-2019 06:10 PM
MaxiNoob98
17
10-02-2015 10:13 PM
HerpDerp1919
09-29-2015 02:02 PM
Andy29
09-29-2015 05:32 AM
Quick Reply: How can I tell If I have a locking or open diff.
