VAIS Fix
Old 04-07-2009, 07:11 PM
maxdriver10's Avatar
VAIS Fix
I read somewhere that the VAIS is basically designed to fail and that you lose top end hp when it breaks...there's an easy fix that I read about on vqpower.com under the how-to's and wonder if anyone had tried it/noticed any difference once it was fixed?
maxdriver10 is offline
Old 04-07-2009, 07:24 PM
No more Maximas...
pmohr's Avatar
Have you searched?
Yes. Many people. Hell, the article was written by an orger.
pmohr is offline
The Whistle go WOOOOO
Weeble1's Avatar
NWP block off plate. Plain and simple. I did it... Feels good. Search it. There is a ton of info on here about it.
Weeble1 is offline
Old 04-07-2009, 07:25 PM
Weeble1's Avatar
Originally Posted by pmohr
Have you searched?
DAMN YOU WALKING MAXIMA! You beat me to it.
Weeble1 is offline
Old 04-07-2009, 07:28 PM
sorry lol my internet is down and am doing this from my phone so I thought I'd try and use as little data up as possible
Old 04-07-2009, 07:29 PM
I have a 5.0 gen and I don't think NWP makes a VAIS blockoff plate for that model year
Old 04-07-2009, 07:30 PM
No more Maximas...
pmohr's Avatar
Indeed, it's only for the VQ35.
pmohr is offline
Old 04-07-2009, 07:32 PM
Weeble1's Avatar
I don't either, Same general idea but you just leave the stock plate on.
Weeble1 is offline
Old 04-07-2009, 07:47 PM
Lol but I don't think there is a stock plate?!
Old 04-07-2009, 07:50 PM
Weeble1's Avatar
oh, I thought there was. I thought you just take out the flapper.... ok I'll shut up now.
Weeble1 is offline
Old 04-07-2009, 07:54 PM
haha no I appreciate the responses...I haven't taken anything off yet so I'm just assuming there's no stock plate...I wish NWP made stuff for 2000-2001s...
Old 04-07-2009, 08:01 PM
No more Maximas...
pmohr's Avatar
There's really nothing to make, the 00VI is a great IM as it is.
The 00VI has butterfly valves in each runner, unlike the single valve in the 3.5 UIM.
pmohr is offline
Old 04-07-2009, 08:02 PM
phxgold's Avatar
i love the block plate this simple thing is really amazing.
phxgold is offline
Old 04-07-2009, 08:13 PM
Sooo basically preforming the VIAS fix on my 2000 would be better than a block plate?
Old 04-07-2009, 08:17 PM
No more Maximas...
pmohr's Avatar
Comparing apples and oranges here, so neither of them is 'better' than the other.
pmohr is offline
Old 04-07-2009, 08:21 PM
Lol okay this is more definitive...it's better to do the fix than do nothing? Will I be able to feel any change (even minimal is good). Sorry for the continued quest. I did search but didn't come up with much.
Weeble1's Avatar
ooooo got ya
Weeble1 is offline
Old 04-07-2009, 08:22 PM
Weeble1's Avatar
+1, I love mine
Weeble1 is offline
Old 04-07-2009, 08:24 PM
And not to be a noob with questions but why doesn't the VIAS run all the time, why only come on after 5000k? (only 1500k to redline)
Old 04-07-2009, 08:32 PM
It's business time.
Progress's Avatar
Do you know you VIAS is not working?
Progress is offline
Old 04-07-2009, 08:33 PM
No more Maximas...
pmohr's Avatar
Seems like a very simple decision to me, either leave a part broken or return it to working order
Don't even know why you wouldn't...
It doesn't work that way. You need to search a lot more.
pmohr is offline
Old 04-07-2009, 08:45 PM
I did and thats what was said in the thread so I'm assuming the thread was incorrect...and I'm not sure if it's not working or not but I don't feel as if I'm making the power I should be at certain times so was wondering if this might be one of the culprits
Old 04-08-2009, 06:01 AM
phxgold's Avatar
part of the problem you are experience is the throttle regulation. have your ecu remapped so when the throttle is opened up its really opened up. it does some good to completely open up the airway but unless your have the ability to completely open up the throttle your quest for power is still being hindered by the computer as it is still trying to perform to stock parameters. The o2 sensors are constantly reading whats comming thru the exhaust. it does not know things have been changed do it makes its own adjustments accordingly to try to match the factory parameters. thats why bolt ons dont do alot unless you reset the parameters to match the mods. your bolt ons cause the computer to work against themselves in essence. Once the new parameters are set when you open up the throttle it really opens up increasing response.
phxgold is offline
Old 04-08-2009, 06:22 PM
Where do I have that done, and what do I tell them? To remap the ecu so that the throttle body is truly wide open?
Old 04-08-2009, 06:24 PM
I also plan on still checking out the VIAS...my car is 9 years old lol so there's a good chance it could not be working properly
No more Maximas...
pmohr's Avatar
You don't. That issue doesn't concern you, since you don't have a DBW TB.
The previous poster must've somehow thought you had a 5.5, even though you made a thread about an 00VI fix
pmohr is offline
Old 04-08-2009, 06:34 PM
Uh DBW TB? Lol thanks for all the help and info I'm going to take it apart Friday to see if it's broken, if it is I'll fix it if not then that's even better lol oh and never mind realized DBW TB means drive by wire throttle body
Old 04-08-2009, 08:37 PM
phxgold's Avatar
mybad thought it was a 5.5 guess i should listen more than I talk
phxgold is offline
gigabyte
01-06-2017 06:05 PM
D Mason
06-21-2016 04:43 AM
maxinout93
10-31-2015 02:04 AM
leatherneck
09-30-2015 09:16 PM
Quick Reply: VAIS Fix
