clamp to big for battery terminal
Old 12-02-2008, 02:23 PM
T Keck's Avatar
i noticed it a while ago and keep putting off fixing it because its really nbd but now it's starting to bother me, the clamp for the positive terminal on my battery is to big, it's tightened all the way and it still can just slide on and off.
Has anyone else had this problem? how did you fix it
T Keck is offline
Old 12-02-2008, 03:10 PM
mod or sell?
internetautomar's Avatar
the positive side is too big?
normally it is the negative side that is too big. some batteries use a smaller negative post than the positive side does.
internetautomar is offline
Old 12-02-2008, 03:21 PM
99BettySE's Avatar
One of mine is like that too, I believe it's the positive but it's dark out and I'm in my pajamas and I don't wanna go look. It has a sabot-type thing, a little flat piece of metal wedged in between the clamp and the post. It does the job I guess.
99BettySE is offline
Old 12-02-2008, 03:30 PM
T Keck's Avatar
yep, at first I thought it was because of all the things i have running onto the clamp (horn, HIDs, Subs) but i realized they way i have them on there that they are actually making it tighter, i guess I'll try a shim
T Keck is offline
Old 12-02-2008, 06:50 PM
mod or sell?
depending on how much too big it is, you may be able to put some aluminum foil between the terminal and the post to pick up the slack.
Old 12-02-2008, 07:54 PM
z32drifter's Avatar
Check the clamp very close, I bet it is cracked. I found mine cracked and making poor contact a few years ago. I bought a replacement terminal from the parts store and fixed it. I did not buy the generic clamp where you have to hack up your battery cable. I found a clamp like the orignal one and cut the hoop off the old cable. I was able to trim the new clamp so it could be bolted to the remains of the orignal cable. It looks factory and retained the secondary connections and plastic protective cover.
z32drifter is offline
Old 12-02-2008, 10:01 PM
maxx0831's Avatar
i have the same prob. I need to change the postive terminal. I bought the universal clamps. Can I cut everythign close to the old clamp and just put all the wires together and clamp it down on the new one. The reason I asked is, bc I seen 2 black wires that were seperate on the postive terminal
maxx0831 is offline
gigabyte
01-06-2017 06:05 PM
bigfrank
10-01-2015 12:51 PM
MichMaxFan
09-30-2015 09:18 AM
Quick Reply: clamp to big for battery terminal
