How should I clean my Rusted Rotors?
Old 11-11-2008, 04:22 PM
Tight_Whip's Avatar
Same as in title: I need to know if there are any good items I can use to clean my rotors, they have alot of rust, I want to make them look new again.
Tight_Whip is offline
Old 11-11-2008, 04:26 PM
Snypa's Avatar
If its light rust and only happens when rain falls on them or some other sort of water, after using the brakes they normally clean off.
Snypa is offline
Old 11-11-2008, 04:31 PM
Tight_Whip's Avatar
The only part of the rotors that isn't rusted is the part that makes contact with the brake. I tried spraying brake caliber paint on the other area's but it only worked for a short time.
I'm just wondering if there is any tips on how to clean the rust, any chemicals I can use, or should I just use sand paper, etc....
Old 11-11-2008, 04:58 PM
Feldman's Avatar
sand paper or steel wool should work fine just don't go crazy, but they are just going to get rusty again unless you pick up a set that has a zinc plating or something else that would inhibit oxidation.
Feldman is offline
Old 11-11-2008, 05:40 PM
allensteiner21's Avatar
you can paint them - otherwise the rust will always come back.
allensteiner21 is offline
Old 11-11-2008, 06:01 PM
whiteSE's Avatar
well when u drive, where the pads touch, it goes away, but why would u worry about the rest?
whiteSE is offline
Old 11-11-2008, 06:46 PM
btvenom's Avatar
He might think it looks ugly? I personally have OCD about how clean my car is inside and out at all times...aka Washing weekly, Waxing Bi-weekly, but anyways rust can be very unattractive to people...although I don't know how one would go painting the whole outside of the rotor, without getting paint on the rest of it...and you would have to take it off the car to do a good thorough job
btvenom is offline
Old 11-11-2008, 09:43 PM
Snypa's Avatar
it comes back even after painting,,...not that quick but eventually.
Snypa is offline
Old 11-12-2008, 05:34 AM
If they are primed and painted correctly the rust does not come back.
I have brembo blanks that I've painted the hub silver. Over 2 years now with not even a hint of rust. Use the right paint and prep is key. If you're trying to recondition used rotors, I'd sand blast them first, then prime and paint with high temp paint or use a caliper painting system.
Old 11-12-2008, 05:53 AM
chillin014's Avatar
I unknowingly bought some zinc plated rotors awhile back and they have kept rust off the hub and other places for a pretty long time. They are starting to accumulate some sort of build up now although I dont think it's rust. I personally don't worry about it though...
pics of this??
chillin014 is offline
Old 11-12-2008, 11:40 AM
It's been a while since I've photo'd my car. I had the ZINC plated x-drilled setup from Stillen a while back too. Never had any issues with rust on them, but the ZINC coating did start to look a bit faded twards the end of their life. I put about 90K miles on them, stupid Metal Master pads ate the rotors up good.
Try some acid brake cleaner on them. Test a spot first, if it looks OK, do the whole hub area with the cleaner and a light scuff pad. That should make them look like new again. Pull the wheels off so you don't damage the finish on your rims.
aw11power
10-10-2021 04:57 AM
uttadms31
09-30-2015 05:24 AM
Socalstillen
09-26-2015 12:01 PM
worldwiderecognized
09-24-2015 06:56 PM
Quick Reply: How should I clean my Rusted Rotors?
