belt squeaks when wet
Old 10-23-2008, 12:03 PM
Cumalot's Avatar
my drive belts squeak whenever it rains, but on dry days, they're fine. what does this mean? is it time to change them? why they don't squeak when it's dry though? if they need replacing wouldn't they squeak regardless wet or dry?
Cumalot is offline
Old 10-23-2008, 12:22 PM
Licensed to Spell
ptatohed's Avatar
Mr. Cumalot. It's been a while, how are you? It’s good to see you still drop by now and then.
Is the undercarriage splash guard which protects the belts from getting wet missing from your car (I know I am famous for removing those and forgetting to put them back). How do your belts (PS and serpentine) look? Dry and cracked or frayed - or fine? How's your tension on the serpentine belt?
ptatohed is offline
Old 10-23-2008, 01:04 PM
Cumalot's Avatar
Wow, yes it's been awhile. I'm good but I'm done with modding though. My car is stock now. I finally kicked the on and off mod bug for about 3 yrs now. How's your car?
I have the undercarriage splash guard there. I haven't check out how the belts look and holding up yet. Last I checked about a few months ago, they looked fine. Tension on the belts are fine as well.
Cumalot is offline
Old 10-23-2008, 02:40 PM
Madmax66's Avatar
Clearly sounds like moisture is getting in there somehow. I recently noticed the grease monkeys I let chg the oil....haven't bothered re-installing the splash guard....and hence...a chunk of it got caught and ripped off. I was driving in a bad storm a few wks ago, and the belt was squeaking quite a bit. I just repaired the splash guard...patched it up nicely w/ some pvc I had lying in my garage. I have yet to drive her in the rain but am confident all will be good. I'd take a closer look at yours...maybe even pop the wheel off ...to ensure it's not unsecured on one side, etc.
Belts should only squeal if they're too tight, too lose, or wet!
Good luck!
Madmax66 is offline
Old 10-23-2008, 03:39 PM
Changeum....
Old 10-23-2008, 06:07 PM
Licensed to Spell
ptatohed's Avatar
Done modding, huh? That's no fun. Did you say you got a 240?
My car's doing well. Of course it's never done but I'm pretty content. I forget if I told you I bought a '99 to replace my '96. This should tell the whole story:
http://forums.maxima.org/6663569-post55.html
Double check all splash guards, belts and belt tension (twist it in a corkscrew fashion and make sure it doesn't go past 90^). If those are cool, then check some of the pulleys themselves that the belt(s) go around. Try some WD-40 on those pulleys (try not to get WD on the belt itself). My SHO needs some WD every now and then. Good luck.
ptatohed is offline
Old 10-28-2008, 12:20 PM
Cumalot's Avatar
ok i found out it was indeed the splash guards. one of them wasn't secure and also was ripped. i need a new one. any idea where i can one besides the dealer? any websites sell it?
Cumalot is offline
Old 10-28-2008, 12:24 PM
Madmax66's Avatar
Thought so. You can find them online easily enough...and cheap...however, w/ the S&H....ur pushing $50 for it. I couldn't justify that so, I repaired mine. Easy enough to modify some pvc type mat'l you prob have in ur garage.....or check out salvage yards (and Org) for a used piece.
Good luck and glad to hear that's all it was.
Madmax66 is offline
Old 10-28-2008, 12:41 PM
DennisMik's Avatar
If its the original belt, it might be worth while to replace it. You could also try a "belt dressing" compound.
DennisMik is offline
Old 10-28-2008, 12:44 PM
foxracing12's Avatar
That belt dressing stuff is junk on modern belts, they do not require any dressing. If a belt is noisy there is something causing it, mine was a cracked up splash guard.
foxracing12 is offline
Old 10-28-2008, 03:40 PM
ClaJa0246's Avatar
My fan belt squeek also
ClaJa0246 is offline
Old 10-28-2008, 03:45 PM
Technically our cars don't have a fan belt. We have electric fans, we have two drive belts though. Make sure they aren't loose, cracked, glazed, etc or that they are not exposed to the elements as stated above.
Old 10-28-2008, 04:05 PM
Sentientbydesig's Avatar
Is it possible that the moisture is causing the belt to expand, and therefore squeal?
Sentientbydesig is offline
Old 10-28-2008, 05:05 PM
I guess in theory that makes sense but I'm pretty sure the material doesn't really absorb moisture. The problem with water is when it's actually covered in water and the belt slips on it's pulley.
Old 10-29-2008, 10:23 AM
hitm4n666's Avatar
my 240sx used to do that to but then i put new belts and retensioned it and it was fine
hitm4n666 is offline
Old 10-29-2008, 11:28 AM
Cumalot's Avatar
i went to nissan and just to find out how much the splash guard would cost. the one on the front passenger side, the vertical one that covers the side. they wanted $65 for it. yike! i think i'm going to just repair mine.
Cumalot is offline
Old 10-29-2008, 02:55 PM
ThreePointO's Avatar
my belt squeaks to. it didnt used to but now it squeaks "quietly" all the time. but the other night it rained real hard and it was squealing like crazy. unfortunately i have no money to fix the problem... o well. pretty much every car i buy has a belt problem.
ThreePointO is offline
Old 10-29-2008, 10:17 PM
Licensed to Spell
ptatohed's Avatar
Just contact Maxima_Joe (ex. fanaticrock). He's the used part king. Great service/prices.
ptatohed is offline
Old 10-29-2008, 11:00 PM
96blkonblkse's Avatar
Belt could need replacing, they tend to do that when it gets colder out. Personally, ive seen techs put some grease on the belts/wd 40 kinda thing, i dont really agree with it, its covering up an underlying issue, but hey you know what, it works, and from what ive seen it hasnt caused any negative side effects.
Check your belt tension though, belts do stretch overtime, which causes some of the noise, if its loose, tighten it down, but your best off to replace the belt.
96blkonblkse is offline
Old 10-30-2008, 10:37 AM
i which the belt wasnt such a ***** to replace. the one thing i dont like about transverse engines, especially v6's is the fact that some **** is so hard to work on because its buried.
Old 10-30-2008, 11:56 PM
Licensed to Spell
ptatohed's Avatar
The serp. isn't bad at all. The PS is a lot harder though.
ptatohed is offline
Old 10-31-2008, 01:42 PM
Cumalot's Avatar
i went ahead and got me a brand new splash guard. again, this is the vertical looking one on the front passenger side. it covers the belt area. i know why water got it there now. i'm missing 1/4 of it! i don't even remember how or why but i cut off like 1/4 of it off. so i only got 3/4 of the back part. maybe the front 1/4 was ripped somehow or damaged beyond repair and so i just cut it off. the slash guard cost me $65 from the dealer. expensive, but oh well, need to get it sometime.
Cumalot is offline
Old 10-31-2008, 01:49 PM
Licensed to Spell
ptatohed's Avatar
Cuma, I told you about Maxima_Joe. It would have been maybe $10-15 shipped. I haven't had that piece on in years. And my belts never squeak. But I usually don't take my '99 out when it rains.
ptatohed is offline
Old 10-31-2008, 01:58 PM
Cumalot's Avatar
well thing is i ordered that part a few days ago before i read your post about maxima_joe. even though it's expensive, now that i'm not modding anymore, it's ok to spend on things like this from time to time. much, much cheaper than my modding days.
Cumalot is offline
05' MaximaMan
10-08-2017 06:36 PM
markevans999
10-25-2015 08:27 AM
homewrecker
09-24-2015 07:01 PM
2kmaximel
09-24-2015 03:55 PM
SusieQQ
09-09-2015 12:14 PM
Quick Reply: belt squeaks when wet
