alternative battery sizes???
Old 10-23-2008, 06:59 AM
AnDyMaN's Avatar
battery is just about to give out and costco doesn't have the 24-f battery size available. anyone using an alternative battery size with no problems??
i was thinking 35 or 34 f sizes with a higher cca and reserve capacity than oem.
could i possibly measure physical dimensions and ratings and make sure its at least the same size as my battery with more power?
costco batteries are prretty cheap and supposed to be good quality.
thanks in advance.
AnDyMaN is offline
Old 10-23-2008, 10:17 AM
Torgus's Avatar
i bought some huge massive one from walmart. cables just barley fit. just test fit.
Torgus is offline
Old 10-23-2008, 03:46 PM
tosheto's Avatar
Mine is very small, but have no idea about the size. Works perfect though!
tosheto is offline
Old 10-23-2008, 03:55 PM
Kevlo for President
Kevlo911's Avatar
As long as it has the right terminals and CCA it will work fine. You can guesstimate what will fit.
Kevlo911 is offline
Old 10-23-2008, 04:29 PM
vernk's Avatar
Yea as long as it fits under the hood you should be ok, make sure the terminals are on the right side or put longer cables on. I ran a Die Hard Gold 900cca in my Geo Metro (it kept the lights from blinking with the system)
vernk is offline
Old 10-23-2008, 04:31 PM
That's Mr. Detail to you
Scottwax's Avatar
If there is an AutoZone in your area, their gold batteries are great. Higher than stock CCA too. Had one in my Accord, even with underdrive pullies and Texas summer heat, I got 4 1/2 years out of it, where the last one only lasted 3. Still had some warranty left so I replaced it with a new one for about $35 or so.
Scottwax is offline
Old 10-23-2008, 05:03 PM
¯\(°_o)/¯
Greeny's Avatar
OMG!! Hahahahahahaha!!
Greeny is offline
Old 10-24-2008, 05:01 AM
Oh baby, SIZE does matter!
Old 10-26-2008, 01:18 PM
nafddur's Avatar
Optima red's are super cheap - even less than I could locate anywhere on-line - at Sam's Club. I just put a 35 (not sure if that's the same one my Max takes) in my Murano for under $150, including tax.
There was a $25 rebate that helped with the price too, though.
nafddur is offline
Old 10-27-2008, 06:59 AM
Torgus's Avatar
mine from walmart was like 35 bucks after the core...855 cca i think, big sucker.
Redtops arn't cheap...compared to a normal battery that is and not much better(marketting bull****).
i could buy 6 batts or one redtop...hmm i wonder what would last longer and perform better...
Torgus is offline
Old 10-27-2008, 11:28 AM
808MAX-SPEC's Avatar
I don't know too much about batteries but I like the fact that Optimas are gel type batteries. I hate dealing with acid based batteries.
808MAX-SPEC is offline
Old 10-27-2008, 01:02 PM
Torgus's Avatar
i thought optis weren't 'gel' batteries...?
"A gel battery is typically a modification of a conventional lead-acid automotive or marine battery. A gelling agent is added to the electrolyte to reduce movement inside the battery case. OPTIMA Deep Cycle batteries are able to deliver and receive higher amperages than gel cell batteries, due to the far-higher internal resistance of gel batteries. Most gel batteries can't handle engine starting duties, but OPTIMA Deep Cycle batteries can."
Torgus is offline
Old 11-10-2008, 01:18 PM
Licensed to Spell
ptatohed's Avatar
I really doubt you could get an 885 CCA battery for $35. ?
Any 12V battery which fits will work. I'm using a motorcycle battery and it works fine.
ptatohed is offline
Old 11-10-2008, 01:51 PM
Torgus's Avatar
walmart in braintree, ma
it was 35 and change after the core. i know it was well under 50. bought it last summer.
Torgus is offline
Old 11-14-2008, 03:39 PM
pezfallout's Avatar
Any battery that will let your hood close will work. However, depending on your charging system, cheaper batteries with fewer CCAs will not tolerate as much abuse and will fail faster in the event of a fading alternator.
pezfallout is offline
Old 11-16-2008, 07:24 PM
FallenOne's Avatar
But of course! And may i suggest that when you change your battery' you go ahead and take a good look at your ground points as well. I just redid my Wires and replaced my battery yesterday, as the one i got from NAPA was defective 500 CCA when it was supposed to be 850... so yeah it was under a year warenty so i cant complain too much. But back to my point. i was drawing too much current at IDLE and my voltage hit 12.3 which drew from the battery so i slowly helped to Nuke it. so. Sand Them Grounds, and Decorrode Them Terminals!
FallenOne is offline
Old 12-19-2010, 01:47 PM
burtonmaina's Avatar
660 is the OEM Cold Cranking Amps. Mine is again on its way out 5 years later.
This time I'll try an aftermarket.
burtonmaina is offline
Old 12-19-2010, 11:41 PM
Licensed to Spell
ptatohed's Avatar
That was worth a 2 year bump, thanks.
ptatohed is offline
Old 12-20-2010, 04:20 AM
Leo_Koneval's Avatar
Guess I will also chime in about my size.
Before I had a small one too, it just barely fit. But now I've gotten about 2 inches longer and it fits just right on the battery tray.
I also got a battery withe higher CCA and it cranks a lot faster than the OEM CCA
Leo_Koneval is offline
Old 12-20-2010, 12:25 PM
asand1's Avatar
I just found my new sig
asand1 is offline
Old 12-21-2010, 02:13 AM
Old 01-04-2011, 12:34 AM
DAJOHNGUY's Avatar
DAJOHNGUY is offline
TallTom
50
07-08-2022 09:54 AM
Miket2006
03-01-2021 03:55 AM
bigfrank
10-01-2015 12:51 PM
Quick Reply: alternative battery sizes???
