Rear Timing Chain Cover Leaking
Old 10-22-2008, 01:35 PM
t_ahan's Avatar
Well my rear timing chain cover started leaking to the point were it drips even when the engine is turned off. I really dont want to pull the engine out cuz then i have deal with the obx 2 piece headers with the rear manifold one pipe with the y pipe, and plus i would have to do the radiator support cuz when i put the cross member back last time i saw the bolts twist in the radiator support becuz that nasty rust,so i know as soon as i take them out they wont go back in......ok well i have been told with my milage 198k+ that stop leak would just give me poor oiling and eventually cause an internal problem, so they told me to try brake fluid or half a qt of ATF...i dont want pull the motor till i get a 5sp trans to do the conversion and jus do it all but that wont be till next spring or summer.i put an autometer oil pressure gauge jus to be on the safe side n see when it drops low. WIL THE ATF OR BRAKE FLUID BE ANY BETTER THAN THE STOP LEAK????
t_ahan is offline
Old 10-24-2008, 05:30 AM
doublea's Avatar
You will have to remove the timing chain cover, clean everything and use a good silicon to seal the cover and re-torque all those bolts, but you may get away by just re-tightening all the bolts. My 2 cents.
AA
doublea is offline
Old 10-24-2008, 06:47 AM
'Trynna' is not a word
mtrai760's Avatar
This has nothing to do with advanced performance, moved to the 4th gen forum. Also, no, adding ATF or brake fluid to your oil will do nothing to fix your leak, if anything, it would make it worse.
mtrai760 is offline
maxprivate
Forced Induction
21
07-08-2017 09:48 AM
maxinout93
10-27-2015 01:29 PM
Huttig2009
09-25-2015 03:31 PM
egali045
08-16-2015 01:19 PM
Quick Reply: Rear Timing Chain Cover Leaking
