Changing rear brake pads!
Old 09-03-2008, 07:14 PM
bluebriscoe's Avatar
okay today i was trying to change my rear brake pads.I took the caliper off the i used needle nose to turn the piston.problem is that the piston turned but it did not seem to be going in so i could put it over the pads.What am i doing wrong or did i just not turn it enough times??
bluebriscoe is offline
Old 09-03-2008, 07:47 PM
SoulEater's Avatar
you need to put some pressure when you turn that in
SoulEater is offline
Old 09-03-2008, 10:13 PM
CMax03's Avatar
might be easier with the proper tool...
CMax03 is offline
Old 09-03-2008, 10:28 PM
theStig's Avatar
your local autoparts store has a tool that plugs into those divots on the piston on one end, and take a 3/8" extension to your ratchet on the other end. Even with this, you'll need to push it in and turn it quite a few times to get it in.
theStig is offline
Old 09-04-2008, 03:06 AM
ok ill try that today thanks.
Old 09-04-2008, 01:27 PM
vinco's Avatar
I've had them such that no matter how much I turned and pushed, they just never would go in. What I learned to do in that case is to turn them the other way until they come all the way out and let most or all of the fluid out. Then just put it back in, with the seals fitted properly on the piston and caliper, and it will then turn in and retract easily. Put it back together and bleed it, and it should be just fine.
vinco is offline
Old 09-04-2008, 08:26 PM
Max_5gen's Avatar
The similar effect with less liquid spill could be achieved by putting some clear plastic hose on the bleeding screw and unscrewing it until liquid goes into the hose. Leave it like this and try to turn the piston in again. I found it goes in much easier on one of my calipers where it also refused to move in no matter what.
Max_5gen is offline
Old 09-05-2008, 07:01 AM
vinco's Avatar
Yes, I've tried that, too. Sometimes it has worked for me, and sometimes it hasn't.
vinco is offline
Old 09-05-2008, 12:50 PM
ajahearn's Avatar
Just another thought
You did remove the cap from the brake fluid reservoir? otherwise you are going to have a hard time pushing the fluid back into the reservoir. Hope this helps.
ajahearn is offline
Old 09-05-2008, 01:58 PM
wyche89's Avatar
i don't see how people used needle nosed pliers to twist in that caliper.. i've had a 5th gen and a 5.5 gen, and with both of them the piston was so hard to turn, i would have to exert ALOT of strength to get the thing to turn a small amount using the auto zone tool.. i would think the needle nose pliers would just snap, bend, or just not work
wyche89 is offline
Matt93SE
05-24-2019 02:58 PM
Huttig2009
09-25-2015 03:31 PM
homeyclaus
09-03-2015 06:15 PM
egali045
08-16-2015 01:19 PM
RealityCheck
08-05-2015 06:18 AM
Quick Reply: Changing rear brake pads!
