ECU Pinout cheat-sheets (large images, 1000+px wide)
Old 08-26-2008, 06:22 PM
No more Maximas...
pmohr's Avatar
Some ECU pinout cheat sheets, if anyone's interested. All images are linked to the full-size versions.
I keep a few of these around (the A32 and Z33, both DE and HR) laminated in my box for doing EMS installs and the like. They're very useful laminated, as you can make notes and mark off spots with sharpie, then just spray it down with brake parts cleaner and comes out looking like new.
Didn't even bother with the '99, since I only have the FSM and no concrete pinout details.
If anyone has a pinout for the VG and VE J30s, I'll make up one for those as well.
Red is power, black is ground...
pmohr is offline
Old 08-26-2008, 06:25 PM
No more Maximas...
pmohr's Avatar
350z/G35:
'07+ 350z/'07+ G35 sedan/G37 (likely 370z as well, but not sure)
pmohr is offline
Old 08-27-2008, 07:41 AM
'Trynna' is not a word
mtrai760's Avatar
Very nice. Stuck for usefulness!
mtrai760 is offline
Old 08-27-2008, 05:50 PM
No more Maximas...
pmohr's Avatar
Altimas:
pmohr is offline
Old 08-27-2008, 08:17 PM
tlrmax's Avatar
Do you have it for a 99max?
tlrmax is offline
Old 08-27-2008, 08:33 PM
No more Maximas...
pmohr's Avatar
No, since the ECU pinout in the FSM is incorrect, unless someone cares to give me a link to a known correct pinout.
pmohr is offline
Old 08-27-2008, 08:36 PM
tlrmax's Avatar
oh ok. I am gathering all my info b4 I install my mevi. I was wanting to know which is the rpm ecu pin for my 99.
tlrmax is offline
Old 08-27-2008, 08:38 PM
No more Maximas...
pmohr's Avatar
Should be pin 5, like the rest of the A32s. W/G, IIRC.
pmohr is offline
Old 08-27-2008, 08:39 PM
tlrmax's Avatar
Thats what I figured but my 99 shares many things with the 2000. Thats why I was curious.
tlrmax is offline
Old 08-27-2008, 08:44 PM
No more Maximas...
pmohr's Avatar
As long as it has an A32 ECU and matching harness connector, it should be pin 5.
pmohr is offline
Old 09-14-2008, 03:13 AM
cow88's Avatar
hi can u please tell me whether 06 nissan maxima j31 ecu pinout will be same with Z33de.
also where is the ecu located
thankyou
cow88 is offline
Old 09-14-2008, 01:29 PM
No more Maximas...
pmohr's Avatar
thankyou
J31? What country do you live in? USDM 6th gen is A34.
pmohr is offline
Old 09-17-2008, 08:15 AM
Horizontally opposed.
mowgli29's Avatar
pmohr, have you tried asking the Wiz about this? I mean he did install teh EU on his 99, so maybe he can help. just a thought...
mowgli29 is offline
Old 10-28-2008, 10:40 PM
irax's Avatar
What's KS?
duhhh... knock sensor... i'm an idiot some times
irax is offline
Old 12-12-2008, 12:10 PM
willie Hutch's Avatar
ECU pinout
Do anyone know where I can find a diagram for an 89 Maxima?
willie Hutch is offline
Old 03-11-2009, 01:32 PM
vgkid's Avatar
sorry if im late but i have help for you!!
it was a pain trying to look for it when i needed it
go to page 137-140 to look for whet you need. pic of ecu is on 140
http://www.nicoclub.com/FSM/maxima/1994/ec.pdf
vgkid is offline
Old 07-08-2009, 11:12 AM
Maximeltman's Avatar
Pmohr...Should the ckps sensor pins for a 1999 se 5mt ECU dated 06/08 be on point with the 95-98 or the 2000?
Maximeltman is offline
Old 07-08-2009, 11:35 AM
No more Maximas...
pmohr's Avatar
As in the first post:
No idea. It's not like the 5th gen, it's an A32 style connector; the pins are just swapped around.
And IIRC it's only one of the CKPS', not both that are different.
pmohr is offline
Old 07-08-2009, 02:52 PM
Product_Of_Korea's Avatar
according to dandymax's EU write up its the CKPS(REF). Instead of being pin 44(95-98) It should be pin 46(99).
Product_Of_Korea is offline
Old 09-25-2009, 08:36 AM
Kgkeen101's Avatar
Where can you get the schematics for the whole ECU wiring, what wire does exactly what?
Kgkeen101 is offline
Old 09-25-2009, 05:41 PM
No more Maximas...
pmohr's Avatar
The FSM.
pmohr is offline
Old 10-14-2009, 04:13 PM
Org Lurker
dukelubas's Avatar
Does the ECU receive a ground through it's mounting chassis/screws? or is it grounded through the harness/engine ground? Reason I'm asking, I'd like to run with the ECU not in it's chassis.
dukelubas is offline
Old 10-14-2009, 05:31 PM
No more Maximas...
pmohr's Avatar
The ECU grounds solely through the two bolts on the LIM (well there may be some in the dash harness, never bothered to look).
If you've seen my A32 CEL video, my ECU is laying on the passenger side floorboard without issue.
pmohr is offline
Old 11-18-2009, 05:54 AM
bottz's Avatar
Ok, so I might be off here, but what exactely does the pin-out cheat do for your car. In my case, a bolt on 2000 maxima from NY??
bottz is offline
Old 11-18-2009, 06:15 AM
mowgli29's Avatar
Not a whole lot by itself...
But it can be a very helpful reference when trying to wire up a V-AFCII, E-Manage, etc. for tuning purposes. Getting a good tune could be quite beneficial, IMO.
mowgli29 is offline
Old 11-18-2009, 05:23 PM
No more Maximas...
pmohr's Avatar
Indeed, that question confused me, to say the least.
pmohr is offline
Old 11-20-2009, 11:08 PM
bottz's Avatar
Again, sorry to ask, but Im trying to figure out what the benefits of the pin-out do for a car. I have a bolt on 2000 Maxima SE 5 speed. Please answer with detail, or how to do this, thanks
bottz is offline
Old 11-21-2009, 02:04 AM
No more Maximas...
pmohr's Avatar
It does nothing for the car, they're just pictures.
pmohr is offline
Old 01-02-2010, 04:21 AM
premaire's Avatar
do you have the one for the i35
premaire is offline
Old 01-13-2010, 01:26 PM
MoncefA33's Avatar
All links are dead
MoncefA33 is offline
Old 01-13-2010, 07:16 PM
No more Maximas...
pmohr's Avatar
All links are dead
Indeed, my hosting has been suspended (for the time being). Another DMCA notice from NNA for hosting the FSMs.
pmohr is offline
Old 02-01-2010, 06:47 PM
Maximus681's Avatar
any possible way to get a 99 pin out yet? or still the same answer?
Maximus681 is offline
Old 02-08-2010, 02:53 PM
No more Maximas...
pmohr's Avatar
No '99 pinout until I can get a definite pinout from a member, or I stumble upon a '99 EC harness and some free time.
pmohr is offline
Old 04-09-2010, 09:59 PM
NJ3ndri's Avatar
W/G would be? White w Green Tracer?
I have the all data pinout for the 99 but doesnt really specify (maybe it does and im blind)
NJ3ndri is offline
Old 04-10-2010, 06:37 AM
SiathLinux's Avatar
If you weren't so far away I'd let you use my car for getting the Pin Out for the '99....
(or you could road trip to FL and do it...)
SiathLinux is offline
Old 08-17-2010, 10:31 PM
altimapony's Avatar
hi i have a 2009 altima coupe 3.5 CVT and im having some hard time with the greaddy ultimate e-manage, does someone have the diagram couse i bougth the universal harness and the guy that makes me all the mods ask me to get the diagram please help
altimapony is offline
Old 04-27-2011, 08:44 AM
VQ'rInWLA's Avatar
1 year bump. Can you refresh the pinout pics pls? Need em for a WBo2 install. TIA
VQ'rInWLA is offline
Old 07-18-2011, 06:19 AM
moz-art's Avatar
Thanks for those images, this is really helpful on my research.
moz-art is offline
Old 08-29-2011, 11:04 AM
SERiousracer's Avatar
Very nice, this will come in handy
SERiousracer is offline
Old 12-13-2011, 06:26 PM
bigrak's Avatar
Very helpful, Thanks for sharing!
bigrak is offline
Quick Reply: ECU Pinout cheat-sheets (large images, 1000+px wide)
