Catalytic Converter is shot, what are my options?
Old 06-16-2008, 04:00 PM
PearlWhtMaX2000's Avatar
OK so i had a check engine light on, and i got the code pulled from auto zone, and it read P0430. I figured it was on o2. went to my mechanic, and he said i need a new CAT. I don't want to dish out $500+ for a new CAT, i will be selling the car within a month or so anyway. Is there anything else i can do? I was thinking maybe getting some o2 sims but im not sure if that would turn off the Check Engine light.
Any help is greately appreciated
PearlWhtMaX2000 is offline
Old 06-16-2008, 05:17 PM
Grand_hustle17's Avatar
junk yard or Random Technology
Grand_hustle17 is offline
Old 06-16-2008, 05:48 PM
No more Maximas...
pmohr's Avatar
Good luck getting most junkyards to sell you a converter, I don't believe it's legal.
Get one made at an exhaust shop, buy one used on here (check with fanaticrockford), or buy new from an online place, RT (like hustle said), Cattman, etc.
pmohr is offline
Old 06-16-2008, 06:21 PM
maximomo's Avatar
Did the mechanic do an exhaust pressure test?
Just because you got a P0430 doesn't mean you have a bad CAT. If your mechanic just read the code and didn't do a pressure test then you may be throwing money away and still have the same problem.
This code can be caused by an exhaust leak, an intake air leak, a fuel injection issue(like an injector that doesn't close all the way).
maximomo is offline
Old 06-16-2008, 06:45 PM
4DSCDriver's Avatar
Do it yourself. Replacing a cat is not that hard if you don;t mind using exhaust clamps.
4DSCDriver is offline
Old 06-16-2008, 07:38 PM
Bjs470's Avatar
You could always get a "high flow" one off ebay, their like $25 I think. haha
Bjs470 is offline
Old 06-16-2008, 07:41 PM
Hmmm.. well if i get a high flow one, wont that still keep my SES light on?
No he did not do an exhaust pressure test.
Old 06-16-2008, 07:46 PM
Da Roller Coaster!
foodmanry's Avatar
Ugh...so much misinformation on this thread. It is the FRONT PRE-CAT Pearl is having the issue with, NOT the main cat, and NOT the rear pre-cat. His options are as follows:
1. Reset your CEL just before you sell the car. The good..its free. The bad..the person purchasing the car can come after you for selling under false pretenses (the car is working with no emission issues).
2. Install O2 simulator. The good..its cheap. The bad...well nothing really, just an extra part on the car.
3. Install used pre-cat (if you can find one) or new pre-cat. The good...it actually fixes the issue. The bad...can be expensive if you have to buy new.
foodmanry is offline
Old 06-16-2008, 08:13 PM
Willing to learn
oldngivout's Avatar
That was an awesome response to a very old & tired topic.
I applaud you on your correct and concise information.
Hopefully when others have this problem, their search will yield this post.
Thanks.
oldngivout is offline
Old 06-16-2008, 09:56 PM
Its the front pre Cat?? so y did my mechanic say it was mt Catalytic Converter??
If it is the front pre cat, and i get an o2 sim, which sensor do i need to replace with the o2 sim (Cali spec)
Old 06-17-2008, 06:32 AM
Willing to learn
oldngivout's Avatar
Because the front pre-cat is in fact a catalytic converter. That term has become auto slang for this particular component.
As far as the O2 simulator, it must be installed after the front pre-cat. This will fool the ECU into thinking that the front cat is in fact operating properly. This is the only function of the rear O2 sensor. The front O2 sensor controls the air/fuel mixture. It cannot be simulated, it must function properly in order for the engine to run.
Old 06-17-2008, 08:53 AM
hi-tek22's Avatar
ive been getting the infamous P0430 SES lights as well, ive been resetting them for the last 8 months.
So i guess my precat is pretty much bad then?
if so, should i talk about getting it fixed? or should i just opt for a Y pipe?
and with a CATTMAN y PIPE can i reuse my same O2 sensors or would i have to use a o2 sim?
hi-tek22 is offline
Old 06-17-2008, 09:13 AM
I have a warpspeed y-pipe, which i thought eliminated the precats. So to get rid of my SES light, do i just need to get 1 o2 simulator? so is there a particular o2 simulator that i need, because when i went to http://o2simulator.com/ there are a few to choose from
Old 06-17-2008, 06:51 PM
Da Roller Coaster!
foodmanry's Avatar
Y-pipe will only eliminate the rear pre-cat (cali-spec only, on fed-spec no rear pre-cat).
Headers will eliminate the front pre-cat, but if you go with headers you'll need to install an O2 simulator anyways.
To eliminate the code from appearing install the O2 simulator on the O2 located at the front pre-cat. Put your head under the car...you'll see the front pre-cat as it it the front exhaust bend coming down from the engine block. The O2 simulator following that needs to be replaced to eliminate the code from appearing.
Old 06-18-2008, 10:14 AM
so would this universal simulator work? http://www.o2simulator.com/index.php...40041e4ee5081a
It says NOT for primary o2 sensor.
Old 06-18-2008, 10:18 PM
CMax03's Avatar
call warspeed and have them sent you a flanged hi flo cat if that's the problem!
CMax03 is offline
Old 06-18-2008, 10:19 PM
Fang_DH's Avatar
o2 sensor sim. i work at autozone, got the same thing, got a new cat., didn't do anything, threw in the sim. and called it good
Fang_DH is offline
Old 06-19-2008, 03:02 PM
Yeah i think thatis what i am going to do. would this o2sim work: http://www.o2simulator.com/index.php...40041e4ee5081a ?
which o2 sensor do i replace it with?
Old 06-19-2008, 03:31 PM
maxdriver10's Avatar
i'm having the same problem, but instead of putting a new cat or precat in, im just gonna throw in a test pipe...i dont have to go to emissions until march 2010, so i figure by then i'll have enough money lol
maxdriver10 is offline
Old 06-19-2008, 05:39 PM
Da Roller Coaster!
foodmanry's Avatar
Why even waste your time putting in a test pipe? Test pipe doesn't do ****.
Old 06-19-2008, 05:41 PM
No more Maximas...
pmohr's Avatar
Have you priced the difference between a converter and a test pipe lately? The latter is a much easier choice on the wallet.
pmohr is offline
Old 06-19-2008, 05:43 PM
The Whistle go WOOOOO
Weeble1's Avatar
+1... how did it go with Merlyn's car today?
Weeble1 is offline
Old 06-19-2008, 06:11 PM
No more Maximas...
pmohr's Avatar
Didn't get to work on it after we pushed it out this morning (trans, axles, shift cables basically). Hopefully we can get it done during the day tomorrow, as it appears the boss won't be there.
pmohr is offline
Old 06-19-2008, 07:20 PM
Weeble1's Avatar
cool cool
Weeble1 is offline
Old 06-20-2008, 09:25 AM
yeah but a test pipe does not get rid of the SES light
Old 06-20-2008, 10:50 AM
gaby617's Avatar
im also a current victim of the p0430 and autozone diagnosed as a precat issue. took it to a friends shop and he informed me my precat was showing signs but also my intake had a leak and that could be the reason why i get sparatic idle shakes. im waiting to speak to my friend again to try to figure out if the leak is the main culprit and not the precat (precat not performing well due to leak).... cheaper to fix one then both.
gaby617 is offline
Old 06-20-2008, 11:07 AM
yea sorry about that...guess that doesnt help much since you want to sell your car...i've learned to live with mine though
Old 06-20-2008, 08:07 PM
Da Roller Coaster!
foodmanry's Avatar
True, but he will still have the SES light so why even waste his time and money putting in a test pipe? He doesn't have to replace his cat if he doesn't mind the SES light.
Old 06-21-2008, 11:43 PM
so i acn just get any o2 sim,or do i need aspecific one?
would this one work? http://www.o2simulator.com/index.php...40041e4ee5081a
Old 10-14-2008, 04:57 AM
calllka's Avatar
I'm in the same situation, with P0430 and not having $ to replace the cat. Had P0138 and P0139 so replaced the rear O2 sensor with BOSCH from Autozone, and then got the P0430. I think now I'll just put an O2 sim in there. Can somebody explain/show which one I need and where's the best place to buy?
Thank you.
calllka is offline
Old 10-14-2008, 07:43 AM
Thanks for all of your help guys. I sold the car, and the buyer decided to do the CAT himself. If i was to do it, i would just go with an Eastern cat. They go for $150.00 online, and would be about $50 fo install. I havnty heard anyhting bad about them either.
Thank you.
Here is the o2 Sim that you need:
http://www.o2simulator.com/index.php...72eac09e305729
It is a Universal o2 simulator with dual output
Old 10-14-2008, 08:03 AM
calllka's Avatar
Thank you.
calllka is offline
Old 10-14-2008, 08:18 AM
calllka's Avatar
Are there any safety or performance issues with running bad cat and using simulators?
Do I need to put a simulator on both downstream sensors or just the Bank1Sensor2 I recently replaced with BOSCH?
calllka is offline
Old 10-14-2008, 08:38 AM
sergey85's Avatar
it the the two downstream ones. two by the header which cant be replaced and two on the downstream are the ones u want to replace with o2 sim
sergey85 is offline
Old 10-14-2008, 08:53 AM
nycnissans
secondtonone317's Avatar
add headers, problem solved
but o2 sim is your best bet
secondtonone317 is offline
Old 10-14-2008, 09:01 AM
calllka's Avatar
do I need two 02 sims or can I wire up the one to both downstream sensors? Do I cut the wires so o2sensors are disconnected or just tap into them?
calllka is offline
BPuff57
04-16-2020 05:15 AM
09maxshawn11
09-30-2015 10:28 AM
sliptap
09-30-2015 05:57 AM
Redfox
09-28-2015 10:41 AM
carid
09-09-2015 05:06 AM
Quick Reply: Catalytic Converter is shot, what are my options?
