Where to buy MDF?
Old 04-19-2008, 09:50 PM
Cdg2125's Avatar
Where to buy MDF?
I just need to know where to buy some MDF to build my sub box. Does home depot and lowes carry it or do I need to order it?
Cdg2125 is offline
Old 04-19-2008, 11:34 PM
Chocolate_Boi_1Der
Cant_Get_Ryte's Avatar
either will have it, and go with baltic birch. cheaper, and lighter, just as dense. and did i mention lighter? hella lighter. get some clamps while your at it and titebondII (I use gorilla), you can go without screwing, but i recommend screws regardless. Good luck.
Cant_Get_Ryte is offline
Old 04-19-2008, 11:48 PM
Andrew's Avatar
The do have the MDF at the big orange box. Check the aisle with the lumber. There was a big sign explaining what MDF stood for, etc...
Andrew is offline
Old 04-20-2008, 12:07 AM
AscendantMax's Avatar
go birch if you wanna spend some more money. it's MUCH lighter than MDF. but MDF is fine if you're not concerned about weight. i get my MDF/Birch at lowes or home depot.
AscendantMax is offline
Old 04-20-2008, 09:26 AM
Sold
JSMax's Avatar
Medium Density Fiberboard.
Also you can purchase HDF = High Density Fiberboard. Why? I don't know what you would need that for, but it is available.
cheers.
JSMax is offline
Old 04-20-2008, 10:34 AM
I tend to get a bit irritable
Pearl96Max's Avatar
HD/Lowes has MDF in various sizes. Birch as well but most if not all have the Birch veneer and not true through and through Birch. For that you would have to visit a local lumber yard or a custom cabinet center.
Pearl96Max is offline
Old 04-20-2008, 11:13 AM
eng92's Avatar
I presume the birch veneered material material you are referring to is a particle core and not a plywood core.
If it is lighter (for the same thickness) than MDF then it only has a regular particle board (coarse grained) core. This is the same stuff that cheap cabinets are made from. If you are going to cover it with carpet, you really don't need a fiinish grade veneer on it. Why not just use regular particle board? It is the same stuff minus the veneer and is cheaper. Although the veneer does help to hold the particle board together because the edges tend to crumble pretty easily.
I prefer working with MDF as it will take a profile bit (router) and maintain a clean edge which regular particle board (veneered or not) will not.
eng92 is offline
Old 04-20-2008, 11:17 AM
oh no, it's plywood core.
Old 04-20-2008, 11:31 AM
Pearl96Max's Avatar
As Gordon mentioned it is at least plywood core. I prefer the 'good' cabinet grade 9+ layer actual Birch.
Old 04-20-2008, 11:33 AM
Pearl96Max's Avatar
eng92's Avatar
Are internal voids ever a concern for the box itself generating noise?
It has been a while since I have priced plywoods, but isn't the G1S fir plywood cheaper than the birch?
eng92 is offline
Old 04-20-2008, 12:15 PM
Cdg2125's Avatar
I do plan on carpeting. Which I also need to know where to buy. Don what kind of board is that pic? Looks great. That the birch? how thick?
Cdg2125 is offline
Old 04-20-2008, 12:24 PM
Pearl96Max's Avatar
Yes it is full Birch. 1" front panel 3/4" around. I was almost ashamed to cover it with carpet/laminate though.
Old 04-20-2008, 04:21 PM
Sold
JSMax's Avatar
a nice stain would set that off and make it look really unique. hmmmm further thoughts for my box when it's time....
JSMax is offline
Old 04-20-2008, 05:40 PM
Chocolate_Boi_1Der
Originally Posted by Cant_Get_Ryte
i could have sworn it was less the last time i went? but you may be right...ive been buying half sheets, for the last couple months...
Blah blah blah got it, and yeah baltic birch, thats the ticket 16.86 for a half a sheet and not particle board. Dont touch particle board...Ever... not marine grade that would be the only other discriminator i know of
Old 04-20-2008, 06:55 PM
Andrew's Avatar
cheers.
Thank you. I know what MDF stood for..I was explaining that there was a SIGN in the aisle to help others who DIDN'T know what MDF stood for.
Andrew is offline
Old 04-20-2008, 09:24 PM
Cdg2125's Avatar
thanks Don. Think I'm going to try that idea. 1" up front and 3/4 all around. Not sure if I'm going to carpet or not. Not sure where to find good stuff.
Cdg2125 is offline
Old 04-21-2008, 08:00 PM
Sold
JSMax's Avatar
Must have misunderstood. my bad. I'm sure there are some here that don't know what it is
JSMax is offline
Old 04-21-2008, 08:52 PM
Fast1one's Avatar
Like mentioned above....the birch found at HD/Lowes is not real birch...
DO NOT USE IT FOR SUB BOXES! Most of it is not void free and therefore inconsistent...
Gotta pay to play, real 13ply birch in 5 x 5 panels runs from 40-100 bucks a sheet depending on your location...
Fast1one is offline
Old 04-21-2008, 08:57 PM
Chocolate_Boi_1Der
cool good to know thx
Old 04-21-2008, 09:05 PM
pretty sure the birch they sell at the HD/Lowes in town are real birch.
last sheet i bought was 9 ply iirc, and was 45 bucks. it was void free as well. so i guess it really depends on your location.
Old 04-21-2008, 11:27 PM
Fast1one's Avatar
Consider yourself lucky then
Cheapest I have seen true 13 ply baltic birch was at lumber yards for 70+ a sheet...
Fast1one is offline
BPuff57
04-16-2020 05:15 AM
trsandrew
17
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
Mahmuth
10-17-2015 12:03 PM
JakeOfAllTrades
09-30-2015 03:16 PM
Quick Reply: Where to buy MDF?
