Change Rear Spark Plugs 96
Old 02-02-2008, 10:27 PM
MaximaMark123's Avatar
The front 3 plugs are easy to do, no prob.
The rear 3 plugs are not covered in the 2 books I have like they don't exist. How do you get to the 3 rear plugs?
I tried removing the small cap over the red plastic coil and could not move the coil to get to the plug underneath. Do I need to remove the metal tube and all 3 coils at once?
Help?
MaximaMark123 is offline
Old 02-02-2008, 10:55 PM
Maxima.org Insomniac
98SEBlackMax's Avatar
Your not reading those books well enough.
Those are the fuel injectors not the spark plugs...
If you need to replace the three rear INJECTORS than you need to remove the upper intake manifold.
To replace the front 3 spark plugs take off the silver colored plastic cover that says VQ on it.
To replace the rear 3 spark plugs there are gaps in the upper intake manifold to take them out.
98SEBlackMax is offline
Old 02-03-2008, 02:24 AM
pmi3096's Avatar
Wrong section!!
but this link should help sorta show were you need to look. http://www.vqpower.com/v2/readarticle.php?article_id=76
pmi3096 is offline
Old 02-03-2008, 06:01 AM
Go back further twards the fire wall and look down between the intake runners. You'll see the plugs for the 3 rear coil packs. The pic's you have are showing the fuel rail and injectors, not the spark plugs.
You'll need a longer extension to get down the rear spark plug tubes to access the plugs.
Old 02-03-2008, 09:04 PM
Fadrvr's Avatar
three seperate threads on this kids injectors. He thinks they are spark plugs. So close to flaming.
Fadrvr is offline
Old 02-03-2008, 09:37 PM
VANGtastic97's Avatar
hahahaha. he's sloooooowly learning
VANGtastic97 is offline
Old 02-03-2008, 10:33 PM
aussie983's Avatar
OMGWTFBBQ
aussie983 is offline
Old 02-03-2008, 10:38 PM
Blackwind's Avatar
take the 405 to I5 to the slawson cut off, get out and cut of your slawson. then go 2 blocks left past the throttle body and BAM you found the other three plugs.
Blackwind is offline
Old 02-04-2008, 05:26 AM
Product_Of_Korea's Avatar
lol yeah i already told him what the pics are in a thread that was bumped from 2005
Product_Of_Korea is offline
Old 02-04-2008, 05:46 AM
Also on the rear drivers side coil you will have to take the bracket off that supports the evap canister purge control valve 2 12mm nuts( someone please correct me if i am wrong) hope this helps you out.
Old 02-04-2008, 09:39 AM
According to this thread........
http://forums.maxima.org/showpost.ph...2&postcount=17
you give the impression you know how to change spark plugs?
Explain......
The Wizard is offline
Old 02-04-2008, 09:49 AM
tvis's Avatar
Kids + Maxima's = bad
tvis is offline
Old 02-04-2008, 12:52 PM
Navin R Johnson's Avatar
Help?
Ya just remove everything...You should be smoking a cigarette too.
This has too be a joke right? I seen some crazy things in forums, but if you can't tell the difference between a fuel injector and an ignition coil you should NOT be working on your car. DANGER!! Will Robinson DANGER !!!
Navin R Johnson is offline
Old 02-04-2008, 01:02 PM
ajcool2's Avatar
Funniest thread evar LMAO!
ajcool2 is offline
Old 02-04-2008, 01:20 PM
i has college
EnervinE's Avatar
Explain......
HAHA nice catch!
EnervinE is offline
Old 02-04-2008, 01:36 PM
oem ftw!
CRiME's Avatar
Yes, Definitely remove the metal tube. Before you do that, be sure to light up a nice, fresh cigarette and have it in your mouth while pulling the tube out.
CRiME is offline
Old 02-04-2008, 05:20 PM
sparky1562's Avatar
Use a metric screwdriver to.
sparky1562 is offline
Old 02-04-2008, 05:29 PM
91parkave's Avatar
watch out for the muffler bearings to. you have to remove those before you can get to the spark plugs. a metric hammer will do the trick though.
91parkave is offline
Old 02-04-2008, 05:43 PM
Blackwind's Avatar
HAHAHA!! "hey mom i found my special purpose!!"
Old 02-04-2008, 05:46 PM
The self-oil changing max
mevjen's Avatar
dude, you should really clean those spark plugs, they look pretty fouled...
mevjen is offline
Old 02-04-2008, 11:48 PM
Old 02-06-2008, 10:08 AM
Explain......
Still waiting for a response.....
Old 03-24-2008, 05:47 AM
phatboislim's Avatar
glad i searched..just a friendly bump for any fresh maxima owners out there trying to do their spark plug change...post #3 holds the info needed
phatboislim is offline
Maxboy23
08-21-2015 11:02 AM
Turbobink
08-15-2015 07:20 AM
Balkins
08-12-2015 06:39 AM
1992maximase30
08-05-2015 09:27 PM
maxima297
08-03-2015 12:50 PM
Quick Reply: Change Rear Spark Plugs 96
