White smoke coming from tailpipe
Old 01-06-2008, 04:49 PM
LT1PnyKlr's Avatar
Recently Ive noticed that when I start my car in the morning to head to work, white smoke comes out of my tailpipe for just a few seconds then it clears up. It only does this when the car has been sitting for a long time, such as over night. Any ideas or suggestions here?
By the way, its a 99 Inifiniti I30.
LT1PnyKlr is offline
Old 01-06-2008, 09:55 PM
JI30's Avatar
Condensation?
JI30 is offline
Old 01-07-2008, 05:22 AM
Double E's Avatar
If it quickly dissolves into the air, this is normal operation and is just a small bit of steam that is produced from water in the tailpipe from the cool night before.
If it lingers like a cloud for awhile, does not stop or is somewhat blue, you have an issue.
Double E is offline
Old 01-07-2008, 10:20 AM
LT1PnyKlr's Avatar
Its definitely not bluish at all. Its whiter than regular steam that comes out from it being super cold outside. When I first start it up, white smoke rolls out for just a few seconds then its gone. Hopefully its nothing to worry about.
Old 01-08-2008, 06:50 AM
Double E's Avatar
No issue...
Double E is offline
Old 01-10-2008, 01:36 PM
MattB85's Avatar
Sounds like condensation to me...shouldn't be anything to worry about.
MattB85 is offline
Old 01-10-2008, 07:28 PM
Armed and Dangerous
i30ds's Avatar
Condensation.
i30ds is offline
Old 10-03-2008, 07:26 PM
LT1PnyKlr's Avatar
This has been happening a little more lately. Still not a constant smoke from my tail pipes, just a puff for a few seconds then it clears up. I also noticed that instead of just happening occasionally at startup, one time I was driving and it did it. Any ideas what it could be before I take it to the "stealership" and have them check it out?
Old 10-07-2008, 12:02 AM
BikTrash's Avatar
you might want to keep an eye on your coolant level just in case.
BikTrash is offline
Old 10-07-2008, 04:38 PM
B_Eaze's Avatar
White smoke is fine, esp if t goes away. If you get different colors that means your engine is burning something besides fuel.
As long as your not puff out white clouds of smoke then your good, nothing to worry about
B_Eaze is offline
Old 10-09-2008, 09:32 PM
Drockb418's Avatar
ur fine any Nissan that i know always does it, my friends try to scare me by saying a blow head gasket
Drockb418 is offline
Old 10-10-2008, 04:09 PM
ImmaSquashYou's Avatar
http://wiki.answers.com/Q/What_can_c...om_the_exhaust
ImmaSquashYou is offline
Old 05-17-2011, 06:10 PM
mercedesfhe's Avatar
i have 2004 maxima that has the same problem,but with oil coming towards the manifold...... can someone help me pls?
mercedesfhe is offline
Old 05-17-2011, 11:54 PM
ef9
ef9's Avatar
What? What do you mean by "oil coming towards the manifold?"
White smoke denotes water being burnt (or in the case above, boiled in the exhaust system). Blue smoke is oil being burnt, and grey/black smoke means excess fuel.
ef9 is offline
Old 09-19-2011, 09:13 AM
LT1PnyKlr's Avatar
Just a follow up for an old thread.
My car still billows white smoke at times. This typically happens within a few hundred miles of an oil change then disappears until the next one. It can happen upon sitting for several hours or pulling off from a redlight. The car will often feel like its stuttering/hesitating while the smoke is present then it clears right up and the engine pulls just fine.
Old 09-19-2011, 11:52 AM
Just the tip.
JNCoRacer's Avatar
Leaking guide tube seals on your valve covers. Oil is getting in around the spark plugs and burning giving you the smoke.
JNCoRacer is offline
Old 09-19-2011, 02:04 PM
tigersharkdude's Avatar
oil doesnt burn white jarrod
tigersharkdude is offline
Old 05-08-2020, 10:45 AM
Stephanie Jones's Avatar
Mine was doing this. I replaced the valve cover gasket and it was fixed. Common problem for these models.
Stephanie Jones is offline
Old 05-11-2020, 01:22 PM
CMax03's Avatar
Stephanie you do your own wrench turning?
CMax03 is offline
Old 12-03-2021, 12:18 PM
LizJjj's Avatar
Help
i have a 2016… that is smoking from tail pipe. Mechanic says no blown head gasket.. wondering if maybe valve cover ..
LizJjj is offline
BkGreen97
04-02-2016 05:47 AM
doctorpullit
09-10-2015 06:33 PM
Maxima.KsA
09-08-2015 11:33 PM
lux97Max
09-04-2015 05:42 PM
trungg86
09-04-2015 04:58 AM
Quick Reply: White smoke coming from tailpipe
