Chevron Techron Cleaner any good?
Old 07-25-2007, 07:37 AM
Trilitai's Avatar
Hello guys! I know some of you guys have used Chevron Techron fuel system cleaner. Is it any good compare to other brands? Please share your experience if you used it before. Forgive me if this question appears many times before. Thanks!
Trilitai is offline
Old 07-25-2007, 10:06 AM
SVI30's Avatar
I had a new car with pinging problem even on octane 91 gas. The dealer found carbon on piston tops (yes, with a tiny camera mounted on a goose neck). They cleaned the carbon off with Techron in the tank and drove it at high RPM for 30 miles. So yes I'll say it is pretty good stuff.
I have an old Suburban mostly parked today (due to $3+ gas). I put Techron in once in a while. It has a 44 gallon tank so it takes two bottles per tank full.
SVI30 is offline
Old 07-25-2007, 01:27 PM
mad greek's Avatar
Ive been using techron for 15 yrs. in a nissan/infinity shop & my own max also. It will keep your injectors clean, also the BG intake cleaner will work wonders on carbon buildups.
mad greek is offline
Old 07-26-2007, 01:47 PM
A33Black's Avatar
Isn't the techron supposed to be added already to to the gas at Chevron gas stations?
I usually try to fill up at Chevron stations for this reason.
Or maybe it's just not very concentrated like if you put in a bottle into your tank with a fill up? so maybe the techron from the pump is just for maintenance and not cleaning?
A33Black is offline
Old 07-26-2007, 07:23 PM
pyroz's Avatar
theres no chevron gas station in nyc. sucks for us then.
pyroz is offline
Old 07-29-2007, 10:22 PM
SilverMax_04's Avatar
Correct. The treat rate for fuel system cleaners for most gasolines is not as high as you get by adding a bottle of Techron to your tank.
I do this just before each oil change and change oil at 10K miles (I was changing at 7.5K miles before my powertrain warranty ran out at 60K miles).
Check out my added discussion on this topic on this site (my name is the same on both sites):
http://www.6thgenmaxima.org/forums/v...?p=44237#44237
SilverMax_04 is offline
Old 08-07-2007, 04:06 PM
K20z1_rsx's Avatar
I like BG and Seafoam.
K20z1_rsx is offline
Old 08-07-2007, 04:12 PM
detailerdaveb@gmail.com
maximadave's Avatar
BG and Techron
maximadave is offline
Old 08-14-2007, 06:37 PM
prestoguy's Avatar
is STP any good? im currently using that
prestoguy is offline
Old 08-15-2007, 08:58 AM
maximadave's Avatar
personally I think STP is a waste of money.
Old 09-01-2007, 03:20 PM
boondoxmax's Avatar
None in Boston either, but when I moved to Florida I couldn't wait to try it out. Didn't notice anything special so I figure any gas station is fine and just put some cleaner in once in awhile.
boondoxmax is offline
Old 09-03-2007, 03:34 PM
d00df00d's Avatar
It won't really do anything noticeable unless your engine has a significant problem with deposits.
That said, it's definitely the best stuff you can get off-the-shelf (except maybe Redline SI-1/SI-2).
d00df00d is offline
Old 09-03-2007, 05:40 PM
MichMaxFan's Avatar
I have had GREAT success using BG44K in my van that had an AWFUL issue w/ running right and tripped an injector code twice. Felt like it was running on 4 cylinders instead of 6. Anyway, I was not looking to put a lot into it and tried the stuff at $20 and it cleared it right up. This was after, by the way, I tried the STP at no success. I am sure it was strong for the system, but I figure once should be ok, and the prob has not returned. I will put in the Chevron here pretty soon to try to keep whatever was the culprit under control.
MichMaxFan is offline
Old 09-03-2007, 06:28 PM
talkinghorse's Avatar
AMSOIL has reformulated their "P.I." fuel additive and it's supposed to be very effective at cleaning injectors, reducing intake valve deposits, reducing carbon build-up, reducing emissions, etc. http://www.amsoil.com/storefront/api.aspx
I've tried it and it seems to work well. Recently sold some to a customer who was having driveability problems on his BMW and he claims the fuel additive made a big improvement...came back and bought some more for his Lexus. At $6.85/bottle, my cost, I'm guessing it's more than Techron, but less than BG-44.
talkinghorse is offline
Old 09-03-2007, 06:32 PM
d00df00d's Avatar
Actually, excluding shipping, that's slightly less than Techron from what I've seen.
d00df00d is offline
Old 09-04-2007, 10:21 PM
Divewjason's Avatar
I fully endorse the Chevron fuel injector cleaner.
Divewjason is offline
The Frye
09-02-2021 11:03 AM
MaxLife17
06-27-2019 01:37 PM
MaxLife17
09-08-2015 02:36 PM
Adoubi21
Dyno Discussion and Slips
09-07-2015 09:34 AM
Quick Reply: Chevron Techron Cleaner any good?
