Where to purchase A/C clutch puller KV99232340
Old 07-17-2007, 09:22 AM
Van
Van's Avatar
In the thread entitled "Who has experience with A/C compressor clutch", there's a copy of a few pages from the Nissan service manual which references part number KV99232340 (J-38874) which is an A/C clutch puller tool and I was wondering where I might be able to purchase that tool? I'm doubtful the local Nissan dealer would be of any help or would charge 3 times what I could get it elsewhere for. I haven't had any luck on the internet finding it so far. The parts I got on loan from Autozone were no where near the correct fit or design for the 3 holes in the Nissan A/C clutch plate. I even tried to make my own tool out of an aluminum plate with 3 bolts with hacksawed notches in them and a threaded bolt to pull the clutch off but no luck. I think I just need to get the correct tool.
Thanks,
Van
Van is offline
Old 07-17-2007, 09:30 AM
<3's the all motor section
XJinCT's Avatar
well...a nissan service manual would reference a nissan part number.......soooooo unless you know of a speciality tool that will work, nissan will be the only place you will be getting an a/c puller with that part number.
XJinCT is offline
Old 07-17-2007, 09:34 AM
Maintenance Monster
dgeesaman's Avatar
It will be cheaper and easier to pay a shop to pull the clutch than it would be to find the tool. At the very least consider a universal clutch puller tool.
If you're really interested I can look up the OEM for the Nissan SSTs. I can't remember the name off the top of my head. But they're usually very expensive custom-built tools or just reboxed tools that are commonly available. I spent $35 once for a scale to measure the steering rack sliding force - it was a stupid fish weight scale worth $10.
Dave
dgeesaman is offline
Old 07-17-2007, 12:08 PM
ThurzNite's Avatar
I think Autozone or Kragen rents it out.
Jae
ThurzNite is offline
Old 07-17-2007, 03:07 PM
SVI30's Avatar
This is a tool with three "hooks" and a big "push" bolt in the middle. I think you can make it yourself as following:
1. Find three pan head screws with heads that will fit thru the holes in the clutch plate.
2. Drill and tap 3 holes in a thick aluminum disc 120 degrees apart in a circle and mount these three pan head screws upside down. There are your "hooks".
3. Drill and tap a hole for the "push' bolt in the center.
I have a home made top cap opener made for Borge struts as well as other home made tools.
SVI30 is offline
Old 07-17-2007, 04:23 PM
f550maranello2's Avatar
^^^^ werd this thing u have to make urself.... i had the same problem... nobody rents/sells it so dont waste ur time..
get a piece of meta and do what the man said.... just dont bend the pulley
f550maranello2 is offline
Old 07-17-2007, 04:24 PM
ThurzNite's Avatar
Autozone has it for rent or purchase:
Jae
Old 07-18-2007, 11:15 AM
Van
Van's Avatar
Thanks to all for your input. As I mentioned in my post, I rented the Autozone tools but they were no where near the correct fit and design for the Maxima A/c compressor. I had better luck making my own clutch disc holder, and I got the screw off the end of the pulley just fine using that, but pulling the clutch disc off with Autozone's clutch puller tool was a joke - it's the wrong size and doesn't engage the inside of the clutch disc so there's no way to pull it off. I'll try again making my own tool per the suggestions. I think I need a long tapered bolt in the center of the puller which is small enough to fit in the center hole in the compressor. Then when the bolt is tightened, it should push against the center of the compressor shaft without actually engaging the threads of the shaft and release the clutch disc.
Van
Van is offline
litch
123
01-04-2024 07:01 PM
hcarter1112
42
07-18-2022 03:35 PM
hez8813
03-12-2020 12:06 AM
BkGreen97
04-02-2016 05:47 AM
Quick Reply: Where to purchase A/C clutch puller KV99232340
