Clay bar didn't remove water spots
Old 06-22-2007, 12:14 PM
bladerunr's Avatar
I used a Meguiars clay bar to try to remove some water spots on my paint but it didn't work very well. The paint is smooth but the water spots are still there. Any ideas on removing the water spots? thx
bladerunr is offline
Old 06-22-2007, 12:38 PM
BigFly_2K2SE's Avatar
Do you have a PC? If so, I would try a light abrasive polish and see if that works. Personally, I am partial to PBs and would try SSR1. If that doesn't do the trick, then I think your problem runs deeper than water spots.
You could probably do this by hand too although it would be A LOT more work.
BigFly_2K2SE is offline
Old 06-22-2007, 04:21 PM
TheKrazyRaven's Avatar
yeah water spots arnt something that a clay bar will take out, you're going to need to use some sort of polish on it
if your gonna try by hand give Meguire's #9 Light Swirl Remover a try, you're gonna need to bust your *** to work it in without a Porter Cable though
TheKrazyRaven is offline
Old 06-26-2007, 11:18 AM
rsly33's Avatar
Try 50/50 water vinegar before anything. Removes waterspots that arent etched perfectly
rsly33 is offline
Old 06-26-2007, 02:13 PM
qbturbo's Avatar
I had the same problem. I used the Meguiar's clay bar w/the Quick Detailer, water spots faded, but were still there.
I had to use the Meguiar's 3-step system after the clay bar to get rid of the water spots:
(1)paint cleaner, (2) polish & (3) Carnuba Wax
No more water stains. If that doesn't work, the 50/50 water & vinegar solution is a method that was suggested too.
Good luck. Depending on your time and how much you want to spend, you might want to try the water and vinegar first.
qbturbo is offline
16_SR
09-09-2015 07:14 PM
Hdnseek
09-09-2015 05:55 AM
Colossus
09-09-2015 05:46 AM
Quick Reply: Clay bar didn't remove water spots
