P1800 - VIAS Control Solenoid Valve Circuit Open
Old 06-03-2007, 06:24 PM
nismopc's Avatar
Ok, so I removed the VIAS unit a couple weeks ago and used a DIY block-off plate to see if the mod the Altima guys had been doing is worth trying. Well I did not like the loss of low-end when driving around town and did not really notice any high end improvement, so I put the VIAS unit back in later that day.
Ever since then I have been getting the following code...
It does not set off the CEL, but the code is in memory. I've erased the code with my scanner on multiple occasions, but the code keeps returning. I have also noticed that my car appears to be sluggish now. WOT seems to take forever to get in the upper RPM range now.
Anyone have any more details to what this means or what steps I can take to see what is causing this to occur.
nismopc is offline
Old 06-03-2007, 06:28 PM
Check the harness and verify it is plugged in and still functioning. Also, try checking your vac tubes to verify that they are not reversed.
NmexMAX is offline
Old 06-03-2007, 06:33 PM
nismopc's Avatar
I'll check the harness to see if loose, but I did not have to disconnect that. All I had to do was disconnect the vaccuum line that goes to the VIAS unit and plug it with a screw.
When I swapped the unit back in, I removed the screw used to plug the line and put the line back on the unit.
nismopc is offline
Old 06-04-2007, 12:09 PM
nismopc's Avatar
Update: I read over the FSM for testing procedures. Checked the connector and it was fine, then pulled the fuse that according to FSM supposedly controls the solenoid to see if blown. It was not, so I put it back in.
Went inside and went to bed.
Woke up this morning, checked codes on my scanner and P1800 code was gone. I drove 60 miles to work, then at lunchtime, drove around and checked codes again. P1800 showed up in PENDING DTC's, BUT driveability issues are gone????
nismopc is offline
Old 06-05-2007, 06:08 AM
Puppetmaster's Avatar
Any updates? Sounds like you may have fixed the open circuit, since the VIAS is working again (based on your driveability comment).
Puppetmaster is offline
Old 06-05-2007, 09:54 AM
nismopc's Avatar
Well, I haven't scanned the DTC's since yesterday afternoon. On my way home last night I did have a "spirited" drive home, so I will check the DTC's after work today and see if the code still exists.
I am wondering if the solenoid and/or valve is not working properly causing the random code and since it is a pending code, it has to occur so many times before it is considered by the ECU as a saved code (issue).
nismopc is offline
Old 04-16-2008, 07:41 AM
maxximaa's Avatar
Any updates on this? because i have two!! of these codes.
One is P1800 AND one is P1800 Pending.
What does it mean when it says "pending"?
maxximaa is offline
Old 03-08-2009, 02:32 PM
ridinwitha35's Avatar
Bump? Is there a part you have to replace for this P1800 code?
ridinwitha35 is offline
Old 03-08-2009, 03:36 PM
VQP0WER's Avatar
If your vacuum hoses are fine, replace your VIAS. It's right next to the throttle body.
VQP0WER is offline
Old 03-23-2010, 12:26 PM
vvtli78k's Avatar
hi does anybody have a picture of this valve or diagram w/ exact location... i got a CEL also today and it is a P1800... i would like to fix it myself if possible thanks
vvtli78k is offline
Old 03-23-2010, 04:58 PM
Ghost_54's Avatar
I borrowed this shot from another thread on the block off plate/VIAS delete.
here's the link, some good info throughout the thread
http://forums.maxima.org/5th-generat...r-5-5-gen.html
Ghost_54 is offline
Old 08-15-2010, 03:04 AM
Nismo215's Avatar
sorry to be a noob but what does it mean to cap it off? like to have it cover with something or remove it? as to remove the vacuum tank
Nismo215 is offline
Old 11-06-2010, 07:09 AM
Max19473's Avatar
Hi Guys,
Does anyone know the model number for the VIAS control solenoid?
Thanks for the postings as they are very helpful.
Max19473 is offline
Old 10-30-2011, 10:17 AM
Stylez_Benji's Avatar
my car has the same issue....i have to get it inspected but 2 cose came up:
p1800 - solenoid valve
p0345- cam position sensor
so should i just change both? because my battery connection n everythin else is good
Stylez_Benji is offline
Old 02-17-2013, 12:32 PM
yellowjacket03's Avatar
Anyone know where I can purchase the VIAS Control Solenoid Valve. I would prefer not to purchase from the dealership.
yellowjacket03 is offline
Old 03-13-2017, 10:25 PM
Nikole Widenoja's Avatar
Change the cam sensor ASAP
Change the cam position sensor as soon as you can! It may cause your car to shut off while you are driving! Mine shut off at speeds up to 35 mph. The emergency brake will come on, the vehicle will shut off completely and mine wouldn't turn back on for at least a minute afterwards.
It's fairly cheap to replace as far as parts go, and is also fairly easy to replace other than being difficult to reach if it is position 2. This is a recalled part, so it may be covered by warranty.
Nikole Widenoja is offline
Old 03-22-2020, 05:18 PM
Jose Hinojosa's Avatar
anybody knows where can i buy a vias solenoid connector plug for 2003 nissan maxima?
Jose Hinojosa is offline
Old 03-22-2020, 05:20 PM
you can try this k5t46673
Smackasmith
02-01-2016 12:40 AM
Max139617
09-20-2015 07:25 PM
Max139617
09-20-2015 07:09 PM
tardrex
09-11-2015 07:35 PM
dcam0326
09-07-2015 07:26 AM
Quick Reply: P1800 - VIAS Control Solenoid Valve Circuit Open
